04-04-2010, 04:47 PM
2007 25' International CCD FB
Rochester
, New York
How to remove old wheel bearing grease?
it's time to repack the wheel bearings...
I've read three methods for cleaning the bearings before repacking them with fresh grease:
1. just wipe away the old grease with paper towel
2. use brake cleaner
3. use brake cleaner then wash with soap and water.
My question is -- what method do you use?
Mike & Joan
WBCCI #1521 New England Unit
06 Chevy Duramax/Allison
04-04-2010, 04:54 PM
Corona
You must usea grease solvent.
Gasoline works grgeat.
04-04-2010, 04:56 PM
Mineral spirits works good. Or use any commercial parts cleaner solution followed by an alcohol rinse then air dry.
1972 25' Tradewind
Norfolk
, Virginia
Rinse the parts in cheap gasoline in a plastic coffee container (one for each wheel so as to not mix up the components) outside for ventilation.
Um... I don't think the enviromental or dermatologist people would approve so we'll call that a joke.
but it would work...
04-04-2010, 05:13 PM
banjobill
2000 30' Limited
battle ground,
don't use gasoline...
it is a highly effective solvent, but it is very dangerous, even the crappy fuel we get today. if you do not have a solvent tank, buy some cans of brake clean and use that-wipe the majority of the grease off first with the paper towels, then use the brake clean. do not spin the bearings when dry, regrease using the old palm of the hand trick or a bearing packer.
be safe, first
bill
04-04-2010, 05:28 PM
Rochester
, New York
thanks for the fast response... so far everyone uses a solvent to clean away the old grease, with one poster recommending an alcohol rinse.
Has anyone had good results just wiping away the old grease? If not, why?
Mike & Joan
04-04-2010, 05:36 PM
2004 25' Classic
Prescott
You are trying to clean ALL the old grease off. This would include the old grease in between the bearings. Just wiping them does not really clean them. You need some type of solvent to do it right.
Julia & Bob
W/ Deedee & Boo
AIR #30685
04-04-2010, 05:45 PM
Why don't you wipe off as much as you can. Then clean them with solvent and see how much old grease and crud you missed?
04-04-2010, 05:47 PM
2016 23' International
Centennial
I use the brake solvent and a soft bristle brush. Then, blow out with an air compressor. Repack by hand.
Steve "Centennial Man"
04-04-2010, 05:51 PM
Rochester
, New York
The expert mechanic in a how-to video I watched just rolled the bearings on paper towel which removed most of the grease between the bearings. I understand that this technique cannot remove all the old grease, but it seems to remove most of it. Not unlike draining old oil during an oil change removes most but not all of the old oil.
Does even very small amounts of old wheel bearing grease contaminate the new grease?
Mike & Joan
04-04-2010, 06:31 PM
1999 23' Safari
Perrysburg
, Ann Arbor
Wiping / rolling can't nearly get it all. And what is left may well have the most dirt/ abrasive in it. It also leaves grease thay may or may not be incompatible with the grease you're about to use to re-grease. Solvent is the only way to get it all out. Gasoline very dangerous due to flammability and toxicity concerns; mineral spirits / kerosene somewhat less so, but take longer to dry.
Experts recommend never using compressed air to blow / dry the solvent out of bearings, as this could cause spin at high speed and galling, etc. I do it anyway, making REAL sure to have rag / paper towel pressure on all parts so nothing can move. Then a littlefinal air dry in the sun while I take a break before repackng.
04-04-2010, 07:00 PM
Lin
, Ne
Wash with solvent or gas and blow the bearing out to clean and dry it, you may have to wash again and dry if grease comes out when you blow out with air. One of the reasons to blowing it out is the air will blow out the dirt inside the bearing. Do not mix up the bearings, they go back in their original position, keep them with the hub they come out of. You can get away with just wiping the inside of the hub clean though. Dont buy a cheap grease when you repack your bearings, it could cost you dearly.
04-04-2010, 07:15 PM
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
repacking
When repacking the bearings, DO NOT dip them into your grease tub.. Use the old palm of the hand method so you don't contaminate the whole tub of grease.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
04-04-2010, 07:38 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
one other part of repacking the bearings is to inspect the bearing rollers and race. if you leave old grease, you can't inspect the bearing properly.
Ricky
04-04-2010, 07:44 PM
Absolutely. A critical part of the re-packing process is a thorough visual inspection. Here's what we found last Fall.
http://www.airforums.com/forums/f437...eck-57131.html
William C. Swinney
04-04-2010, 10:01 PM
1978 31' Excella 500
Genoa
, Nevada
Ok, next: Who's grease do you prefer to use to repack the bearings with?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
04-05-2010, 05:14 AM
2014 25' Flying Cloud
Cuddebackville
, New York
I can't believe that spinning dry bearings with air or by hand for a few seconds under no load would cause any harm.
Isn't it kind of hard to resist?
04-05-2010, 06:08 AM
1999 23' Safari
Perrysburg
, Ann Arbor
I don't think spinning them by hand under no load can cause any harm - anyway, I can't resist. But I don't air-spin 'em.
They are ground to very tight tolerances and are precision hardened; just a little nick can start bad things to happen. I've had bearings fail, once on a rented trailer far from the nearest paved road, and now I take no chances with them. They are one of the few "show stoppers" in RVing, and I don't want my show stopped!
04-05-2010, 07:22 AM
Lin
, Ne
Now that question can lead to looong arguments! But if you want to use the absolute best lubricants that beats them all without a doubt use this stuff. Lubrication Engineers - LE History
Ive used their products for over 20yrs and it still impresses me. Not having to buy a single ball joint, tie rod, bearing, transmission, or motor has saved me sooo much money over the yrs. You can buy it by calling the company.
04-05-2010, 07:24 AM
Lin
, Ne
You can spin them with air but just not at a high speed!!! Only slowly.
