Old 02-06-2024, 06:15 PM   #21
1967 17' Caravel
1979 28' Airstream Excella 28
Wheat Ridge , Colorado
Have visited the Boeing factory lately? LOL
Brett Hall
Wheat Ridge (Denver) Colorado
https://www.TimelessTravelTrailers.com
Brett - TTT is offline   Reply With Quote
Old 02-06-2024, 06:16 PM   #22
2008 22' Safari
Originally Posted by jefflew View Post
I have Dexter Nev-R-Lube. As I understand it, it is sealed and there is no need to re-pack with grease. Why do you ask?
I was just wondering if anybody has been inside that drum since mfr.
I didnít realize you had Nev-R-Lube.
Old 02-06-2024, 06:21 PM   #23
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by JeffKim View Post
So, they offered sympathy, but little else? I thought the brake/axles are all one assembly from Dexter and Airstream just bolts them on.
What else would Dexter do?
There isn't any real damage.
The OP can keep the nut.
Because these are Nev-R-Lube there isn't a parts expense to remove the drum.
Action
Old 02-07-2024, 09:43 AM   #24
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
Action
No apparent damage, but I wouldn't want a nut beating on my brakes and hoping it didn't do anything.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 02-08-2024, 02:01 PM   #25
2023 27' Flying Cloud
Quick update.
On further inspection, I can see that the starwheel (the teeth) is quite worn (compared to the other 3 brakes on my AS), and I have to assume it is because the loose nut had a role to play there. When I compare those brakes to the others, it looks a lot dirtier.
That said, Dexter initially insisted that it was debris that came through the adjuster hole (which is why they asked me to buy the dust plug).
I've since shared with them that it is IMPOSSIBLE for the nut to have entered through the adjuster hole - it is far too big to fit through the adjuster hole. Their response was "improbable but not impossible"...
What I would like them to do, at a minimum is to comp me for a professional inspection of the brakes and if they find anything wrong with it, to make me whole.
Anyway, in the process of filling out the warranty form online and lets see how this goes.
jefflew is offline   Reply With Quote
Old 02-08-2024, 02:33 PM   #26
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You might replace the star wheel adjuster.
No matter who pays for it, brakes are kind of a safety thing. (Well not kind of ...)
It may have been possible for the nut to be jambed or partially jambed between one of the shoes and the drum. There may be witness marks in the drum from that if it did happened. If that did happen, there may have been a period when the shoe or shoes did not make contact with the drum during braking.
Action
Old 02-08-2024, 02:37 PM   #27
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You also might volunteer an inspection. Dexter has a location in Plant City FL.
https://www.dexter-distribution.com/florida-branches
It is more or less a wherehouse. And it has a nice large flat parking lot.
This is so they could see for themselves. Well via one of their branches.
Action
Dometic Cook Top: LOOSE PARTS 2019 27FBQ International Loose Hardware Ray Eklund Stoves, Ovens & Microwaves 1 12-17-2023 12:07 PM
Basecamp Lug Nut Socket - found it! otisb Base Camp 0 09-15-2020 08:59 AM
Found a nut sitting on the step pwlldvd 2016 - Current Flying Cloud 23 12-17-2018 08:24 AM
Loose lug nut lucybear Wheels, Hubs & Bearings 2 08-06-2017 04:25 PM
Loose Ball Nut - CAUTION Driver1 Hitches, Couplers & Balls 22 06-01-2008 12:16 PM
