Old 06-23-2021, 11:28 AM   #1
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Dexter Nev-R-Lube Bearing R&R
Dexter Nev-R-Lube drum or disc brake bearing replacement procedure using a screw type bearing press.
If you’re a DIY’er with a good set of tools and a bit of I can do it up your sleeves this is a doable workbench task all you need is the screw press set and snap ring pliers. No hammers needed.
This R&R does require special tools. 1 7/16” socket, small and large snap ring pliers and a bearing removal and installation tool set. See Tool Set. This thread focuses on the actual bearing R&R after the drum or hub has been removed from the trailer.
Bearing removal with a hydraulic press that should be pretty simple but having a press ring that contacts the new bearing cone or ID for installation is not acceptable. Any press force applied to the cone or ID is a down the road failure. Not tightening this bearing to the correct torque spec 145-155 lb-ft per the Dexter document is another source of a down the road failure. See the Dexter doc for the periodic Nev-R-Lube bearing inspection procedure.
Removal.
Use a large snap ring plier and remove the bearing retaining ring. This is a robust snap ring, handle carefully. See Snap Ring.
Clean the snap ring groove and hub bore. The old bearing will come out on the wheel side of the hub.
Select a push plate from the set that pushes on the old bearing but is small enough to not touch the hub, select a receiving cup just large enough to allow the old bearing 76mm OD to be pushed into it without jamming. Select a cover plate for the receiving cup and insert the press screw, thrust washer under the nut and then the nut. Make sure to lubricate the threads liberally with grease and between the nut and the thrust washer. Center the push ring, receiving cup and press screw in the bearing. See Removal A, B and Tool and Bearing.
Now it’s wrench time. Hold the screw head and turn the nut drawing the bearing into the receiver cup. If it doesn’t move reset the screw press centering it carefully.
Installation.
Carefully clean the hub bore removing ALL debris. Any debris that prevents the bearing from fully seating into the hub bore may prevent installing the snap ring and will require removing the new bearing damaging it in the process.
Apply a very light film of grease on the hub bore and bearing OD.
Position the new bearing in the hub bore and assemble the tool set that pushes on the CUP, the OUTSIDE RACE ONLY. These plates have recessed centers that do not apply the force thru the cone but only on the cup. See New Bearing A and B
With the threads lubricated and the tool centered it’s back to the wrenches and turn the nut pressing the new bearing into the hub bore.
When the bearing bottoms out in the hub bore, you’ll feel it, ALL STOP when the nut can’t turn anymore.
Remove the press tool and apply a light film of grease in the snap ring groove and carefully install the snap ring. It should snap right into the groove if the bearing is fully seated in the bore. See New Bearing C.
Prior to replacing the new bearing on the axle apply a film of anti-seize grease to the axle and a light film on the ID of the bearing. Tighten the nut to 145-155 lb-ft.
Refer to the Dexter Hub Drum Bearing doc pages 3-4 attached below.
Gary
Nev-R-Lube flyer info.
https://www.dexteraxle.com/user_area...lit-215-00.pdf
Dexter bearing servicing info, Nev-R-Lube see pages 3-4
https://www.dexteraxle.com/user_area...ctionSheet.pdf
Example of the tool set I used.
https://www.harborfreight.com/front-...-pc-63728.html
ID:	398028   Click image for larger version
ID:	398030   Click image for larger version
Name:	Tool and Bearing.JPG
Name:	New Bearing A.JPG
ID:	398032   Click image for larger version
Name:	New Bearing B.JPG
Name:	New Bearing C.JPG
ID:	398034   Click image for larger version
GCinSC2 is offline   Reply With Quote
Old 06-23-2021, 11:34 AM   #2
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Nev-R-Lube Bearing Repairs
Gary,
Nice job...thanks for sharing!
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 07-02-2021, 09:08 PM   #3
SilverLife's Avatar
2017 22' Sport
2021 27' Globetrotter
Geographicly , Unbound
Sometimes Never Lubed
Thanks for that informative post. Plan on repacking x4 soon.
SilverLife is offline   Reply With Quote
Old 07-02-2021, 09:29 PM   #4
DFlores's Avatar
1968 22' Safari
Buda , Texas
Thanks, good information
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 07-03-2021, 06:13 AM   #5
dznf0g's Avatar
Oswego , Illinois
Thanks Gary. Where did you procure your tool set? Cost? I was charged $20 to carry the hub into the shop for the bearing R&R. Wondering what the tool payback is.
-Rich-
Old 07-03-2021, 06:22 AM   #6
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Looks like it was $119 here’s his link.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 07-03-2021, 06:35 AM   #7
dznf0g's Avatar
Oswego , Illinois
Sorry, missed the links.
-Rich-
Old 07-03-2021, 06:35 AM   #8
GCinSC2's Avatar
Maybe a couple of beers or better someday if I'm lucky.
As I've already borrowed this tool years ago and successfully did the job on my VW this became a challenge and project. And to show it can be done you don't need to replace a usable hub or drum if it's a bearing issue.
Yup it's a Harbor Freight set. Others exist but this one was 4 miles down the road.
That hub is already promised to a fellow Slider as a carry along spare. I carry a spare more out of luck that I have it, why not carry it. And I do carry the special tools to do a complete hub R&R just because.
Gary
Old 07-03-2021, 06:48 AM   #9
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Thanks, Gary! Saved to my "how to" files.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 07-03-2021, 06:52 AM   #10
dznf0g's Avatar
Oswego , Illinois
Gary
Yeah Gary....labor rates are high these days. I'm thinking that's a 6 pack job.....12 pack if you have a "helper".
-Rich-
Old 07-20-2021, 09:46 AM   #11
HopJockey's Avatar
Mesa , Arizona
About to do the same task on our 2017 Classic. Two of the bearings on our trailer look like grease is seeping from the bearing. Seems like breakdown waiting to happen
Was quoted $90 (1 hour) in labor to press out 4 old and press new 42mm bearings.
Name:	bearing grease.jpg
HopJockey is offline   Reply With Quote
Old 07-20-2021, 09:54 AM   #12
GCinSC2's Avatar
HopJockey,
Any symptoms to go along with the observation? Noise, failed Dexter rock in-out test etc.
As long as the shop presses the new ones in on the OD only that's $90 to the good.
Gary
Old 07-20-2021, 03:36 PM   #13
HopJockey's Avatar
Mesa , Arizona
HopJockey,
Gary
Gary,
No other symptoms noted only because I didn't check for them. The visual had me worried once I saw the two bears that weren't weeping grease. We're going on a long 7,000 mile trip in Sept and I wanted piece of mind. New tires (costco Bridgestone), Timkim bearings, turned drums (both surfaces), 4 new brake assemblies and shocks (yeah, one shock mount missing a nut and one shock leaking).
Entire project cost approx: $2,110
Tires: Bridgestone Dueler tires: 700
Timkin Bearings 4ea: 690
Shocks, 4ea: 190
Drum Turning: 130
Brake Assembly Backing Plates, 4ea: 400
I can only imagine how much this would have cost me at the dealership and how long of a wait, versus doing myself.
Drums came out nice (pic)
Old 07-20-2021, 04:01 PM   #14
GCinSC2's Avatar
HopJockey
Looks like a successful project is at hand. Excuse me if you know or read about this but std brakes or self adj will need initial adjusting.
Looking good.
Gary
Old 07-21-2021, 07:19 AM   #15
2019 25' Flying Cloud
Houston , Texas
Very nice write up. Thanks!
DCPAS is offline   Reply With Quote
Old 04-23-2023, 09:59 AM   #16
TeddyK's Avatar
Boston , Ma
Great info!
2005 25’ Safari Special Edition (International Package)
Sendel 16’s, Michelin Cross Climate, Shell on interior update (floor frame solid) Ampere Time lith batts, Victron Controls, Champion Dual Fuel 3400
WD Eaz-Lift 2 -1200lb bars 2-anti sway brakes
TeddyK is offline   Reply With Quote
Old 07-28-2023, 12:24 PM   #17
2017 30' International
Charlotte , North Carolina
I just wanted to publicly thank Gary for this informative post.
Last year on a trip to Yellowstone, we had a brake shoe retaining pin fail on the curbside rear axle. I found out by checking hub temps at a rest area stop, found the wheel didn't want to turn and the adjusting star had been relocated, pulled the hub, removed all the brake parts stirring around in the hub, and continued on with 3 brakesets instead of four. Found a complete backing plate brake assembly in Bowling Green KY (manual adjust) for $127 and it was an easy bolt-in replacement at the next concrete pad camping site.
Fast forward to a few weeks ago returning from a short trip and noticed that hub was showing 20 degrees higher than the others on TPMS. Checking it, the brakes were fine, run-out felt good and hub turned fine, but wheel was noticeably hotter to the touch than the others.
I concluded the brake incident last year baked out enough grease from the bearing that I needed to replace it.
Thanks to Gary, I simply ordered the part he specified from Summit Racing in this thread. (I have dealt with them for years as they sell the unique Wildwood brake rotors that fit the bespoke hats on my old racing Mazda.)
Pressed out the old bearing and pressed in the new one and I believe all is well.
I disassembled and found not a lot of grease around the bearings, but no marks on any races or the bearings. I would like to believe I caught it perfectly before it pooped into the fan.
But the real message here is appreciation to Gary for his spot-on technical info. Thank you, Sir.
Al
Al U. Minium is offline   Reply With Quote
Old 07-28-2023, 04:24 PM   #18
GCinSC2's Avatar
Al
Al,
You made my day. Thank YOU!
Hey, if you ever head out of CLT headed to MYR we're just a few miles away from McLeod Farms the big peach and strawberry destination. We have a backyard private Camp Hickory and a welcome spot at the campfire for you folks.
Regards,
Gary
Camp Hickory with Tom and Wendy (center) and Linda
Name:	IMG_9395 - Copy.jpg
Old 08-01-2023, 12:45 PM   #19
Thanks for that offer! Familiar with McLeod/McBee route down to Myrtle Area, we have camped at Huntington Beach a number of times!
Take care,
Al
Old 04-15-2024, 05:32 PM   #20
2018 30' Flying Cloud
Hutto , Texas
Originally Posted by HopJockey View Post
Gary,
Shocks, 4ea: 190
Drum Turning: 130
Hi - what TIMKIN bearings did you use - I’m finding the ones for my 2018 flying cloud 30FB online ( Timkin Set49 ) and they are about 35 a piece ?
Eswaroop is offline   Reply With Quote
Dexter E-Z Lube (not NevR Lube) Axles Al and Missy Axles 14 02-21-2022 07:55 AM
Nev R Lube bearing question n2916s Wheels, Hubs & Bearings 0 06-10-2021 08:29 AM
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 04:48 PM
Dexter nev-r-lube failures Jammer Wheels, Hubs & Bearings 44 04-26-2015 07:42 AM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
