Old 04-15-2024, 07:51 PM   #21
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Nev-R-Lube Bearings
Originally Posted by Eswaroop View Post
Hi - what TIMKIN bearings did you use - Iím finding the ones for my 2018 flying cloud 30FB online ( Timkin Set49 ) and they are about 35 a piece ?
You've got it right on the Timken Set49. Prices can range all over the place...especially if you buy the Dexter boxed parts. etrailer carries a Dexter replacement kit pn K71-997-00...that's listed as a 42mm Cartridge Bearing, Spindle nut and Lockring. The kit actually has 6 parts:
Hardened Spindle Washer 42mm
Spindle Nut
Snap Ring
Torque Spec label
Bearing
Retaining ring
You can find the same kit on Amazon, they're both close to $300 for the kit.
If you just need the bearing the 2010 PT Cruiser uses the same 42mm bearing as our Nev-R-Lubes. Gary GCinSC2 did the research on this many moons ago. Here's a link to his post: https://www.airforums.com/forums/f46...ml#post2693213
We're on a five week adventure and experienced a bearing failure that sidelined us for 5 days. I got the bearing from the local O'Reillys Parts Store...the other components I had to order from an online source. Despite all the Truck and Trailer industry in Oklahoma City, nobody had the spindle washer, nut or snap ring I needed. The bearing was easy to get and much cheaper than the Dexter option. It's the other parts that hold the hub on that can be challenging to find if you need it right now to get back on the road.
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 04-16-2024, 02:52 AM   #22
2018 30' Flying Cloud
Hutto , Texas
Spindle Nut
Snap Ring
Torque Spec label
Bearing
Retaining ring
Tom - S/OS #025
Thanks Tom! - I thought itís just the bearing that really needs to be replaced if performing as a maintenance job - the rest of the parts are reusable - if the wheel separated in a failure then the other parts are needed Iíd presume
Eswaroop is offline   Reply With Quote
Old 04-16-2024, 05:39 AM   #23
STREMN's Avatar
As long as the other parts aren't damaged in some way you can reuse the components securing the hub on the axle spindle. You don't have to have a catastrophic wheel loss, but the other parts can also be damaged in a bearing failure.
Based upon our experience I'd also carry a spares' set of the washer, nut, and snap ring just because they're usually not readily available for purchase locally. They're small, light and easily stored and "unobtanium" when you need it for the fix right now.
Tom - S/OS #025
Old 04-16-2024, 08:26 AM   #24
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Large snap ring removal
has anyone found a snap ring tool that works for the large snap ring in front of the sealed bearing? That was my biggest hurdle in replacing the bearing
rbs is offline   Reply With Quote
Old 04-16-2024, 08:19 PM   #25
STREMN's Avatar
Harbor Freight sells a snap ring pliers set that worked for me. You need something 9" to handle that big snap ring.
Tom - S/OS #025
Old 04-17-2024, 03:11 AM   #26
Hutto , Texas
The reason why Iím asking about he bearing is that I just bought a 2018 flying cloud 30FB from the local dealer here and just a couple of weeks later the service team there recommended replacing the bearings - these are the pictures shared - thereís grease weeping from the bearings - I checked all the wheel hubs for play and thereís none - see pictures attached
Old 04-17-2024, 03:14 AM   #27
Hutto , Texas
When I went back and complained that it shouldínt have passed their used RV inspection checklist they claimed they were fine and just were a recommendation based on the age of the bearings. So they declined to cover their replacement essentially
Old 04-17-2024, 03:15 AM   #28
Hutto , Texas
Tom - S/OS #025
Great idea - where do I find a spare set of those ? ( minus the bearing - since the kit is 130 dollars but bearings are only 35
Old 04-17-2024, 05:05 AM   #29
STREMN's Avatar
Online purchase is probably your best option. Do a search on the following Dexter Part Numbers and select the best option for you:
005-147-01 Washer 42mm hardened 1"ID
006-183-00 Spindle Lock Nut 1"x 14 pitch
069-096-00 Snap Ring Inside
069-095-00 Retaining Ring Outside
092-002-00 Label - Torque Value Settings
031-073-03 Dexter Bearing
Dexter Kit - K71-997-00 includes all these parts, but it's $$$. Dexter also sells parts online. I find their site confusing and more expensive than other retail parts sites.
The first 3 parts are your critical components.
Tom - S/OS #025
Old 04-17-2024, 06:27 AM   #30
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Tom - S/OS #025
actually purchased and used the Harbor Freight, the problem is the pin size. The snap ring opening is (from memory) about .100" while the pin size on the large snap rings all seem to be .125", which I ended up grinding down to make work.
Old 04-17-2024, 07:03 AM   #31
2019 25' Flying Cloud
Houston , Texas
Tom - S/OS #025
Great information. Thanks.
DCPAS is offline   Reply With Quote
Old 04-17-2024, 07:20 PM   #32
STREMN's Avatar
I bought the Harbor Freight kit and used it as is. Picked the large set and it worked for the large snap ring for me without adjustment. Maybe we've got different tools. Anyhow that snap ring that holds the bearing in the hub is one beefy unit and you'll need a large tool to seat it in the groove.
Tom - S/OS #025
Old 04-19-2024, 08:09 AM   #33
Hutto , Texas
Timken set49 USA vs S Korea comparison
So I ordered 4 bearings from homedepot ( they sell these set 49 bearings for about 35 a piece ) and one more from -Amazon
Three out of four bearings from Home Depot were US made and fourth was from South Korea
One bearing from Amazon was from South Korea
I donít have anything against Asian products but the S Korean bearing seems flimsier - less grease and less sturdy it moves side to side when pressed - maybe I can post a video - get the US bearings if you can
Also I ordered the national bearings version 513058 from Amazon and they are made in China - they at least for visual and physical inspection seem sturdier and held up better - almost as same as the U.S. made timkens except they spin a bit tighter - donít know if thatís good or bad
ID:	442865   Click image for larger version
Dexter E-Z Lube (not NevR Lube) Axles Al and Missy Axles 14 02-21-2022 07:55 AM
Nev R Lube bearing question n2916s Wheels, Hubs & Bearings 0 06-10-2021 08:29 AM
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 04:48 PM
Dexter nev-r-lube failures Jammer Wheels, Hubs & Bearings 44 04-26-2015 07:42 AM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
