Old 04-01-2023, 12:28 PM   #1
1972 Argosy 24
Saint Louis , Missouri
Changing tires on a 1972 Argosy (No Hub on Rim?)
We're replacing the tires on our 1972 Argosy before the season. We came to realize there is no hub and the lugs are lug bolts so you have to line up holes in the rim with holes on the axle/part that holds the wheel on the trailer. The hole in the center of the rim is bigger than the axle, so you have to lift and finagle the tire to line up the rim holes to the holes for the lug bolts. Obviously this is a difficult task to do when it's sitting here at the house, I can't imagine doing this on the side of the road somewhere. Is there a trick to lining up the holes on the rim with the holes on the axle? I used a board to pry the tire up and get a lug bolt in, once you get one in the rest are easier. Does anyone have any tricks for this?
delpatstl is offline   Reply With Quote
Old 04-01-2023, 12:58 PM   #2
"Cloudsplitter"
Thumbs up Welcome aboard...
What I did with our Safari...jack up the trailer so the tire will be 3" off the ground when mounted, roll the tire up to the wheel and align it as close as possible, sit on the ground and straddle the tire with both feet and use them to lift the wheel the 3"...raise, move and lower and raise until lined up.
FWIW...I still use the method with stud & lug wheels...I'm Old.
I do it at least once a year...
"You don't know where you've been until you leave, enjoy life" RLC
Old 04-01-2023, 01:17 PM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Make a pilot stud out of a bolt of the same diameter and pitch just cut the head off. Thread it into the 12:00 position and hang the wheel on it. Install stud bolts then remove pilot stud.
I also use a shovel under the tire/wheel to act as a lever to lift the wheel and position the wheel.
Gary
GCinSC2 is offline   Reply With Quote
Old 04-01-2023, 02:32 PM   #4
1972 Argosy 24
Gary
GREAT IDEA! Also like the idea of using a shovel as the lever. Thank you!
Old 04-02-2023, 09:13 AM   #5
2012 23' FB International
Woodstock , Ontario
I’ve haven’t been able to lift a tire onto the hub for a few years but I can sit on the ground and I stretch out my legs to cradle the tire and lift it with them. Both hands free to manoeuvre the tire onto the hub
JCWDCW is offline   Reply With Quote
Old 04-02-2023, 11:53 AM   #6
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
That's how my Dad taught me to do it as a kid on the farm. You do have to keep in mind that you're placing part of your body under the trailer, so make sure there's no chance it can fall on you.
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
Changing Tire Pressure When Changing Load Rating smithcreek Tires 22 05-16-2019 06:04 AM
15" rim vs. 16" rim ? Easyrider06 Tires 154 12-18-2015 04:18 PM
Tires and Rim Load Range Capability--Please Help KYAirstream Tires 31 07-27-2014 11:00 AM
Looking for hub caps for my 1972 Argosy jungleterry All Argosy Trailers 12 01-03-2012 08:01 PM
Hub caps for standard 14.5" rim Jephellis Wheels, Hubs & Bearings 3 07-31-2011 05:16 PM
