Old 06-30-2021, 09:23 AM   #1
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Centramatics for AI, front wheels, 3500 Extended chassis
Does anybody know if I can get Centramatic balancers for the front on the AI on the Sprinter 3500 Extended chassis? I wasn't able to locate them on the site, but maybe I'm reading it incorrectly.
Wheels: 16 inch Alcoa
Tires: LT 215 / 85R16
Six bolt pattern
205 mm bolt circle (middle of opposed bolts)
THanks!
Lynn
ACI Big Red Number 21043
Old 06-30-2021, 09:32 AM   #2
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
I would give them a call:
https://www.centramatic.com/
I called them about my mid 2000's GM SUV because I got mixed answers about my fronts and a 30 second call confirmed it was a no go.
panamerican is offline   Reply With Quote
Old 07-01-2021, 09:56 AM   #3
eubank's Avatar
Airstream - Other
Thanks. I contacted them. They do not produce Centramatics that will fit on the Sprinter. For owners of the Interstate or the Atlas, that means we're out of luck.
But all is not lost. I'm going with balancing bead instead. A bit harder to install, of course, but so be it. THere are also a couple of different beads manufacturers, so there, Centramatics.
Lynn
Centramatics for 14" wheels BDandTTs Wheels, Hubs & Bearings 24 06-12-2012 09:07 AM
Extended Length I-3500 RoadJager Sprinter and B-van Forum 58 04-02-2012 10:39 AM
Centramatics didn't fit my 1980 Airstream with aluminum wheels Nuvite-F Tires 4 02-03-2012 10:09 AM
Will Centramatics fit on these OEM 15-inch wheels? Phoenix Wheels, Hubs & Bearings 24 12-19-2010 03:49 PM
