Old 03-04-2024, 07:17 AM   #1
2020 16' Caravel
Ann Arbor , Michigan
Brake and Nev R Lube bearings inspection
I'm in the process of getting my 2020 16ft trailer in working order for a trip in April to be in Ohio during the eclipse.
This is my first time looking at brakes and bearings. I know I should have done this every year. I actually bought new brake assemblies and decided I don't need to use them yet because there's plenty of life left in my brake pads. The Nev-R-Lube bearings look good and the wheels turn smoothly. What I don't know is should I apply lube anywhere before putting the drum back on? There does seem to be grease on the axle. Should I wipe all that away and apply any new grease?
And I've logged about 28k miles with this trailer.
Thank you!
onefiftyfour is offline   Reply With Quote
Old 03-04-2024, 07:43 AM   #2
dznf0g's Avatar
Oswego , Illinois
I would remove the bearings, clean the spildles, get some anti-seize compound and lube the spindle shaft. Someone didn't apply anti- seize when mine was built and I had a horrible time getting the bearing off some years later. I had to buy a hydraulic puller to get it off.
Also, check the bearings for lateral runout and replace if excessive.
-Rich-
Old 03-04-2024, 02:48 PM   #3
2020 16' Caravel
Thanks for the reply. I'll have to research removing these Nev R Lube bearings. I was under the impression that wasn't easy. And also lateral run-out. The drum seems to rotate evenly.
Old 03-04-2024, 03:31 PM   #4
dznf0g's Avatar
Oswego , Illinois
No, it's easy. One large nut and the whole hub slides off the spindle. Unless, some bonehead didn't lube the spindle when it was built. Now, if you have to replace the bearing, it must be pressed out of the hub. Still not hard. Any shop can do it in 20 minutes, including pressing in the new one. Or, you could buy a tool set and do it at home.
-Rich-
Old 03-20-2024, 09:45 AM   #5
2019 27' Flying Cloud
Wilmington , NC
I believe Rich means remove the bearing/hub/drum assembly and not remove the bearings out of the hub. Please correct me if I am wrong, Rich.
There is a popular youtube video that indicates that the large snap ring needs to be removed to remove the assembly. This is not the case unless you want to remove the bearing from the hub.
Bob Thomson is offline   Reply With Quote
Old 03-20-2024, 10:48 AM   #6
2020 16' Caravel
Thanks, Bob and Rich,
I've removed the hubs/drums to look at the brake pads. I think what I've learned is that the grease I see around the bearing is just there to prevent seizing of the hub/drum from the spindle (Nothing spins around that grease?) The bearing itself does not require lube. I won't remove the bearing from the hub/drum unless it shows (or is time) that it needs to be replaced.
-Eric
Old 03-20-2024, 11:25 AM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Leave em alone
Nev R lube bearings Flyfsfrank Wheels, Hubs & Bearings 18 04-16-2024 06:38 AM
Pulling the hubs and bearings on a Nev-r-lube axle Jammer Wheels, Hubs & Bearings 14 07-26-2021 03:58 PM
Do I have Nev-R-Lube bearings? wmb Wheels, Hubs & Bearings 6 10-26-2018 07:12 PM
centramatics and nev-R-lube bearings gtc6452 Wheels, Hubs & Bearings 14 08-09-2013 09:59 AM
