I believe you are good. However not quite clear on what you typed.
Unclear as to this meaning, " would spin with some friction and then glide a bit"
If you mean the brakes make slight contact in some places of the rotation of the wheel and in other places of the rotation spins free, this is desired. Assuming you have drum brakes, the drum is never perfectly round. And the brake shoes are not perfectly arched in a circle. So some places in the drum rotation (with brakes off) the shoes should make very light contact and other locations spin free. This eliminates the brake shoe travel. So when the brakes are applied by the TV the braking action will come in swiftly.
In addition. "Could it be the tire is not seated correctly on the hub?"
The tire is mounted to the wheel. The wheel is mounted to the hub. IF The lug nuts or bolts (which type depends on the year) are torqued correctly the wheel IS seated to the hub.
>>>>>>>>>>>>>>>Action
