Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels, Hubs & Bearings
Old 08-08-2022, 03:38 AM   #1
nyx
Chelsea , Quebec
Bearing part number 2016 25ft International
I am in Porte aux Basques Newfoundland and there are no RV trailer dealers withIn 100 miles. I need to get a bearing changed out. Does anyone know the part numbers for the bearings. Any suggestions on where else I can get the job done other than a dealer? Any help would be much appreciated.
nyx is offline   Reply With Quote
Old 08-08-2022, 04:21 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Doesn't have to be an RV dealer to get this done. Any place that works on trailers of similar size should be able to help do a bearing service. Around here there are lots of places which sell & service utility trailers, and I'd suggest you seek out similar places near you.
On a 2016 trailer are you sure you need new bearings and not just a good service (clean & regrease?) If a service is all you need, then you just need to get the new seals.
If you can still see the tag on your axle under the trailer, get the numbers from it. The folks at Dexter can verify the exact bearings & seals you'll need for your axle from those numbers.
https://www.dexteraxle.com/Contact/
Richard
11018
richard5933 is offline   Reply With Quote
Old 08-08-2022, 04:34 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you please review your owners manual and look for a description of the (assumed) wheel bearing. Does your trailer have traditional greaseable bearings or does it use Nev-R-Lube bearings? Big difference, not interchangeable and the Nev-R-Lube requires more shop service type replacement procedures as opposed to the older greaseable units.
Gary
GCinSC2 is offline   Reply With Quote
Old 08-08-2022, 07:09 AM   #4
1997 28' Excella
Daniels , West Virginia
Airstream customer service in Ohio provided great info to me by email.
Numbers for bearings,races,seals
rich e is offline   Reply With Quote
Old 08-08-2022, 09:07 AM   #5
Niagara Falls , Ontario
Industrial hardware supply and wholesale auto parts places will often have bearing catalogs with cross ref from various manuf. to provide suitable replacements.
hairyclive is offline   Reply With Quote
Old 08-08-2022, 07:04 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
There is a CARQUEST AUTO PARTS in that location.
Removing the bearing and taking it in may get you a replacement if it is standard bearing.
Plus the part number may be stamped on it as well.
Action
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
Need Bearing Seal Part Number for '66 Safari rhmorgan Axles 11 11-26-2008 11:39 AM
Need Bearing Seal Part Number for 2000 30' Excella Cracker Wheels, Hubs & Bearings 3 06-09-2008 06:19 PM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
