Old 10-14-2020, 10:34 AM   #1
2017 22' Sport
Clayton , Idaho
Bambi 22' sport - "loose" lug nuts
Hello, I have a "new to me" 2017 Bambi 22', purchased used in southern CA Feb 2020.
I have learned a bit & have plenty more to learn...
I have taken 2 500+ mile trips-zero issues...
I recently repacked wheel bearings - after reviewing youtube videos & info here, bought tools, grease, etc. Everything went perfectly. Good learning experience.
I noticed that on one wheel - all 6 lug nuts were slightly loose (?).
The other wheel - all 6 were tight. I used a breaker bar w 19mm socket to remove, did the bearing service and tightened using my new $150 torque wrench. 100 lbs. The same 6 lug nuts - originally "loose" STILL have about 1/16" play - after tightening to 100 lbs. ???
Any info appreciated.
Thank you.
Bambi22_ID is offline   Reply With Quote
Old 10-14-2020, 10:44 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
I'm gonna give you a bump
PLUS, check if you have the chrome caps/covers on the lug nuts, maybe they are loose.
Search lug nut covers on this site and see what comes up.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 10-14-2020, 11:32 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Suggest a fine tooth comb and find the red X before towing anywhere.
Majorairheads comment about loose lug nut covers is very good. Please clarify what is loose.
My other ideas and concerns.
Any repair history on hubs, studs, lug nuts or even a wheel?
Can you raise trailer and remove both wheels at the same time ?
Inspect and measure length of studs on all studs.
Install lug nuts and turn them on till they bottom out. All going on same depth on stud?
Compare good vs not good find the difference.
Please report back with more info.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-17-2020, 01:37 PM   #4
2017 22' Sport
Clayton , Idaho
Hey, thanks for taking the time to reply. In reading "here" it seems that the chrome covers are a bit loose? The lugs nuts all "wiggle" about 1/32".
All 6 - exactly the same, on one wheel only (Bambi). I tightened correctly, by hand, then w breaker bar and finished w torque wrench @ 100 ft lbs. studs look perfect. clean, no rust, no lube.
I feel confident they are tight. I WILL be checking tightness on the road, you can bet. Think this is a non issue and appreciate the info.
Gary
Old 10-17-2020, 02:28 PM   #5
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I would check them before every trip just to be safe. If you got any grease on the lug threads or on the rim where the nuts seat, that can also help loosen them off.
I think the torquing double check is the best remedy for this and fortunately you have a single axle so not as many forces working on the bolts.
My owners manual also states 110 ft-lbs for aluminum wheels and 100 ft-lbs for steel wheels. If you have aluminum take the torque up to 110.
I have solid lug nuts on my 2019 Sport and this might be a way to go if you are running into issues with caps.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 10-17-2020, 03:59 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I would replace the two piece lug nuts. I just ordered a new set for my trailer. 24 chrome solid lug nuts was under 20 bucks shipped.
CRH is online now   Reply With Quote
Old 10-17-2020, 04:06 PM   #7
Long Island , New York
Thumbs up
Bingo! . . . replace ASAP.
"solid lug nuts stainless" -- https://www.google.com/search?q=soli...=airforums.com
Welcome to the forum!
Happy trails,
Peter
Old 10-17-2020, 04:21 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Bongo.....McGard tried & Tru made in USA
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 10-18-2020, 12:36 PM   #9
EZ on da bong der Bob . . . .
Peter
Old 10-18-2020, 12:53 PM   #10
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Steps to follow
- clean off all threads, inside and outside-
- replace the nuts with new ones
- you can add a but of anti seize compound, but not too much
- look at the manual as the 14, 15 and 16 " wheels all have unique torque values.
torque that correctly.
you can use the trucker's tip. get the plastic lug nut covers. add them to all nuts and point them all in the same direction. It does matter where they point, just that all wheel are the same.
If a lug nut comes loose, you will notice that the pointer has moved.
waninae39 is online now   Reply With Quote
Old 10-18-2020, 04:25 PM   #11
Not sure your post is what you meant to convey . . . are these corrections in order?
Originally Posted by waninae39 View Post
. . . It does not matter where they point, just that all lug nut covers on each wheel are the same.
Do the bold italic corrections make sense?
Peter
McGard Lug Nuts @ Lock nuts PSU1981 Wheels, Hubs & Bearings 1 12-13-2018 07:13 PM
Loose Lug Nuts Heads Up. mythbuster88 Wheels, Hubs & Bearings 91 05-11-2017 05:15 PM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts sepezlover Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
