02-25-2020, 06:44 PM
#81
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by DavidsonOverlander
Yes, don't use a torque wench, it's not worth the bother to hire someone else to do this job!
I do, however, use a torque wrench to check tightness after I've driven a bit. Is there a reason I shouldn't be using a torque wrench for that? I'm not loosening and re-torquing.
Well you can use the TW if you like, but remember, if you are using a ratcheting 'click' style the ratchet feature is used for righty tighty threads. I wouldn't use it to change a wheel.
I use my manual cross wrench because I have already torqued the lugs and I'm only checking tightness.
To can only torque a nut/fixture to a set value once, loose to tight.
But like most things Airstream it's better to have a routine and do it, than not have a routine at all.
TETO
AZ...I don't use a 'breaker' bar, I use a cross wench, like my name...see above.
02-25-2020, 07:02 PM
#82
2017 20' Flying Cloud
Williamson County
Just my humble opinion and experience. Torque using calibrated torque wrench then use the manual cross bar to recheck TV and Airstream prior to launch at every stop. I checked the crossbar wrench against a torque wrench and a firm application is very close to 100 ft-lbs. Never had a really loose lug nut, but occasionally get 1/16 turn.
02-25-2020, 07:32 PM
#83
2016 30' Classic
Houston
An unreasonable request? You are the customer - demand it! The standard is there for a reason.
02-26-2020, 07:03 AM
#84
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you are going to do what Airstream *says* you are supposed to do, you will use a torque wrench to check the tightness (without loosening) the bolts on the wheel. You will do this at the stated mile points after a wheel goes back on.
I actually spent some time at the factory digging into this. They *do* intend for you to do it as described (using a torque wrench on a tight bolt). Their claim is that they had wheels come of in transport outbound from the factory. (like one or two a year). Once they started doing this, all of that stoped.
Yes it's wrong, yes it works (apparently).
02-26-2020, 07:13 AM
#85
2002 25' Safari
Dewey
Hi
That was their advise to me when I had axle work done last year. BTW, never found a loose nut (except the one behind the wheel )
Richard
02-26-2020, 07:26 AM
#86
1964 26' Overlander
Milton
, ON
Hi
Why is it considered to be wrong?
02-26-2020, 07:55 AM
#87
Ravenna
, Ohio
Originally Posted by azflycaster
I also use a torque wrench to verify the tightness of the lug nts. I do not loosen them, I just crank the wrench until it clicks. The nut almost never moves meaning the nut was tight.
I would think that using a breaker bar could cause the nut to be over tightened which could cause a lug to fail.
^ correct
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
02-26-2020, 08:27 AM
#88
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Even the Xspurts are confused...
From the Tire Rack website....
"When rechecking torque value, wait for the wheels to cool to ambient temperature (never torque a hot wheel). Loosen and retighten to value, in sequence using the torque procedures listed above."
....And then again 50-100mi down the road? 🥴
I'll say again, a 'breaker bar" NEVER gets near my wheels.
I only use a click torque wrench to tighten and my bob-cross lug wrench to check they are still tight.
Another 'opinion'...or informed knowledge?
https://www.askbob.aero/content/can-...-proper-torque
"Determining the degree of tightness in a joint by using a torque wrench to measure the breakaway torque is not accurate and leads to incorrect conclusions. Beware of inspectors carrying torque wrenches."
02-26-2020, 08:34 AM
#89
2021 25' Globetrotter
Jamestown
, Rhode Island
I would respectfully disagree with Airstreams advice on checking torque. Every automobile manufacturers procedure I have ever encountered mandates that the fastener first be loosened. This is because of the different coefficient of friction between a fixed object and a moving object. If you observe the torque necessary to move a typical lug nut torqued to 80 pounds feet from a standstill, you would see that the initial torque needed to move the nut is far in excess of 80 pounds. Once moving the number settles into the “real” range.
Here is the Tire Racks page on the subject.
https://m.tirerack.com/tires/tiretec...jsp?techid=107
Loving our 2021 Globetrotter 25 and our 2022 Ford F-150 King Ranch 5.0!!! Plenty of payload, not even close to axel limits and it drives and rows beautifully…
02-26-2020, 08:39 AM
#90
2016 30' Classic
Houston
What's the benefit of not torquing as AS recommends. Yes, there may be alternative views from other sources. That said, why take the chance however small you may determine the risk to be?
02-26-2020, 01:08 PM
#91
2019 19' Flying Cloud
Canyon Country
From what I understand from Torgue is that it prevents the lug bolts from breaking. Torguing ensures that all 5 or 6 lug bolts share same amount of pressure and carry equal load weight. if two or 3 came loose that leaves the rest of bolts to carry the load weight and they WILL snap off the drum! Saw that happen before in camper and cars.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
02-26-2020, 09:20 PM
#92
Jamestown
, Rhode Island
Because by definition, not loosening first means you have no way of knowing that the torque of the fastener is correct. It might be or it might be loose and you would never know...
02-27-2020, 06:06 AM
#93
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I guess I have never done the rechecking correctly in 20 years of pulling. The idea of loosening and retightning 1 lug at a time does seem to be the best idea. That way the wheel is still being held in the proper position by the other lugs. I have not had a loose trailer wheel or broken a lug nut either. So I think close enough really is.p when it comes to wheel lugs.
02-27-2020, 06:12 AM
#94
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
.....in addition.
You torque a wheel cold.
"On the road" hot wheel re-torque could cause the wheel to be loose when it cools down...
Cheese and crackers got all muddy...it ain't roket seance.
02-27-2020, 07:27 AM
#95
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah
, NSW Australia
What!
The nuts are torqued in the first place - with a torque wrench and not by a 400 pound gorilla with single digit IQ using a 6 foot breaker bar - or more commonly, a rattle gun. Thereafter at the suggested intervals you use the same torque wrench to check that they are still at least tight to the original torque. That is it.. If they don't rotate before the wrench clicks then by definition and common sense, they were not loose enough to matter a damn.
Why would you loosen and then retorque every nut or even worse, use a long breaker bar to nip every nut up just a tad. Nuts come loose sometimes, but they don't turn themselves up tighter, and if they do, so what
BTW, The only way to measure whether the nuts are tight enough is to measure the stress/strain in the stud. Torque gives you a very rough measure provided the threads are clean and dry, the nut faces are smooth AND provided the 400 pound gorilla hasn't slopped some unidentified gunk from that bucket sitting on the ground all over the hub and studs, because if he has, a given torque could easily have overstretched the studs by a factor of two or even three to the point where all the carefully engineer-calculated factor of safety is completely negated. (some vehicles specify lubricated studs but most require clean and dry and I doubt whether any specify lubricating the clamping face of the nut
02-27-2020, 09:34 AM
#96
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Waiting for the click with a TW has NOTHING to do with torque, you are only confirming tightness.
With the possible consequence that every 'click' raises the breakaway torque of the fastener you are 'clicking' on.
Get one...they don't click, but are wonderful for installing and removing a wheel.
For checking tightness put the correct end on the nut, grab each end and go>>> errrr.
02-27-2020, 09:41 AM
#97
1964 26' Overlander
Milton
, ON
What I don't understand is, if you use the cross wrench to check torque how do you know you're not over-tightening the nut? It seems like you're just relying on experience and how tight it feels.
02-27-2020, 10:29 AM
#98
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Once again....🤓
You are NOT checking TORQUE.
You are checking to determine if the wheel nut is LOOSE, if you find that is, then loosen, cool and torque again.
02-27-2020, 11:18 AM
#99
2017 16' Sport
N/A
, N/A
I agree with the article you reference, no offense to Bob X but his article is more specific to aircraft and may account for differences and tolerances of metals used.
02-27-2020, 11:28 AM
#100
2017 16' Sport
N/A
, N/A
Originally Posted by Tireman9
^ correct
A Breaker Bar is ok to loosen, saves your tendons, but I can’t imagine using it to torque or assess correct torque values.
