Old 06-03-2021, 06:31 AM   #1
Spotsylvania , Virginia
91 classic broken wheel stud
I have a brokem wheel stud on my 91 classic limited, I believe the axles are original. Can the stud be replaced? What are my options?
hokie is offline   Reply With Quote
Old 06-03-2021, 06:52 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
hokie,
Pics always help.
I'd say yes the stud can be replaced. Remove wheel, brake drum, now support drum right at the stud that needs R&R, like a couple of deep sockets. The socket allows stud to drop thru but supports drum.
Now it's part number research time or match up at local auto parts store. Find the old grey bearded guy and ask him to match it.
To install, clean hole in drum for stud, insert stud. Now on wheel side put several washers over stud, apply a decent daub of grease on washer and in this case on the threads, turn lug nut or new same size nut on stud, now just start tightening the nut and maybe turn drum over and give the head a modest hammer tap if needed. Tighten until seated. Clean off the grease on the stud from installation.
Replace drum and tire and check that wheel torque several times to assure tightened to toque spec.
This link might help if a Dexter axle.
https://www.dexteraxle.com/results/9...nting-hardware
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Shock mount stud broken? CBWELL Shocks 0 05-05-2019 08:27 AM
Broken Wheel Stud gsmithii Wheels, Hubs & Bearings 12 10-11-2010 01:09 PM
Broken wheel stud 65 Caravel kevinkatz Wheels, Hubs & Bearings 7 07-07-2009 06:31 AM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 06:34 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
