Old 02-10-2025, 02:34 PM   #1
1985 29' Sovereign
Black Mountain , North Carolina
Your opinion about my existing hitch
Hello ASers-
I would like your learned opinion re my existing hitch, keep or replace?
I have a 1985 29ft RB Sovereign, which i have owned about 4 years.
Photos of existing hitch attached (hopefully).
TV is Suburban 1500 with tow package.
I am planning on checking my hitch set up with the weigh scales very soon.
Have recently had two new Dexter axles put in and raised body 1 inch.
Run Maxxis ST235/80R16/1 tires on AS trailer.
Noticed some wiggling recently with some tractor trailers and brisk, but not strong winds.
If the facts lead to a new hitch, I am favoring a Blue Ox from what I have read.
Thank you for your assistance.
Marvin Davis
North Carolina
ID:	450889   Click image for larger version
ID:	450891   Click image for larger version
0007 is offline   Reply With Quote
Old 02-10-2025, 02:55 PM   #2
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
I pulled a 34' for about 10 years with the same hitch. TV was a 2500HD GMC and had no problems with sway or any other bad feelings! Only reason I now have a Hensley, my brother-in-law gave me his as he didn't like it for pulling his cargo trailer. The Husky Center Line has never been "popular" hitch, but I preferred it over the Reese Strait Line and Curt I had before. Most important is to have the bars properly matched to the tongue weight. JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 02-10-2025, 04:10 PM   #3
2019 22' Sport
High River , Alberta
You've raised the trailer a couple of inches perhaps, between the new axles and the wide 16" tires.
If the hitch hasn't been adjusted, you may be putting more weight on the back axle of the Suburban. You may need to raise the ball mount on the shank. However, I would start by adding tension on the bars to move more hitch weight to the front tires of the tow vehicle.
The rearward cant of the ball mount looks good. Don't make it vertical.
I recommend watching this video; it will give you the best understanding of how and why:
AlbertF is offline   Reply With Quote
Old 02-10-2025, 08:49 PM   #4
Moreland , Georgia
Take the instructions, and walk thru the entire setup and adjustment checking each measurement and adjustment.
Since you have raised the trailer, you will probably need to raise the hitch one hole on the shank, but that is to be determined by measuring as shown in the instructions.
Charles
'03 Ram 2500 CTD, 5.9L HO PacBrake six speed std cab long bed Leer top and 2008 BigfootRV 21RB trailer.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 02-26-2025, 10:14 AM   #5
1996 30' Excella
River Falls , Wisconsin
Hitch for AS
We purchased a 1996 30’ Classic Excella 3 years ago and it came with a Hensley hitch. Didn’t know what a Hensley hitch was or how it worked, but did a little investigating. After towing “Faith” for over 60,000 miles in every conceivable situation, except Alaska, we had to replace the hitch last year. I would have nothing else other than a Hensley hitch no matter what kind of trailer I was towing. Never have sway and at times I forget she is behind me. And for those who say it is hard to hook up, give me a call and I will walk you through it.
Ksorenson is offline   Reply With Quote
I need your opinion HuntAnn Member Introductions 12 01-10-2007 07:36 PM
Your opinion is needed!! thenewkid64 Our Community 61 09-26-2005 01:36 PM
Dealers in So Cal ??? Your opinion please Iver Commercial Listings 8 07-27-2005 02:53 PM
trans flush - your opinion baldeagle Tow Vehicles 44 03-09-2004 05:17 PM
Your Opinion, Asking $ 22,500.00 DreamStream Trailer Values 10 03-01-2004 10:18 AM
