Old 08-19-2018, 02:15 PM   #1
JJTX's Avatar
2018 19' Flying Cloud
South of Austin , Texas
What would you do? 400-600LB rated hitch...
I have a WDH system rated from 400-600LB tongue weight, however the bambi 19 is 550LB with LP and Batteries, and otherwise dry trailer.
So this is almost maxed out and theres nothing in the trailer yet.
We camp very light most of the time, but I believe we'll be at the max of this hitch system without much effort.
Would you go then next size up, 600-800 rated hitch?
Or keep this one and use it?
Thanks for your opinions.
JJTX is offline   Reply With Quote
Old 08-19-2018, 03:09 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Scales will tell the whole story but I think you will be fine to keep the one you have.
In the words of my good friend Rob, better not the “over bar”. At least as far as weight distribution goes and not miss spent youth.
Old 08-19-2018, 03:30 PM   #3
JJTX's Avatar
I need to scale it for sure. I'm going to try it and see how it handles and check the weights before any long trips.
Old 08-19-2018, 03:30 PM   #4
Mollysdad's Avatar
Try it.
There's a certain amount of adjustability. If you can't make the trailer level, then you needed a bigger capacity.
Old 08-19-2018, 03:31 PM   #5
JJTX's Avatar
Originally Posted by Mollysdad View Post
Try it.
That makes sense. I forgot theres a relatively to it.
Old 08-19-2018, 03:59 PM   #6
2007 27' International CCD FB
San Diego , California
Stick with what you have. It's the perfect size. Look at the rating as weight class, rather than weight capacity. The next size may put necessary stress on your trailer tongue.
Boondocking Rig: '07 27FB Ocean Breeze "See Turtle"
Lexus LX570 on 33's - $1k 300Ah Lithium Upgrade - Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift
pteck is offline   Reply With Quote
Old 08-19-2018, 04:16 PM   #7
JJTX's Avatar
That was the reason I was not sure going up to the 800LB rated one was a good idea.
Old 08-21-2018, 10:32 AM   #8
JJTX's Avatar
I just found out the husky centerline ts brand does not work on the bambi 19.
The frame is three inches tall. Must be 4" for this system.
Back to the drawing board
Old 08-21-2018, 08:39 PM   #9
2004 19' International CCD
Longmont , Colorado
We just downsized on our 19’ from the 10000# equal-I-zer (it came with) to the 6000# equal-I-zer. It rides much smoother and feels much better overall. We just went to Vail to a dry camping spot and filled the water about 2/3 full. We found that put us too close to our max tongue weight, but moving one battery to the rear compartment brought the tongue weight back in line.
A 600/6000LB hitch should do well.
cstein is offline   Reply With Quote
Old 08-22-2018, 04:07 AM   #10
JJTX's Avatar
I went with the EZ HITCH brand. 800/8000. Found it locally. My opinion was that since the hitch puts down 550 with it dry, that staying with the 600 would max it out.
I called EZ hitch, and they told me the same thing. The idea that the 800/8000 would make the ride rough was not accurate in their opinion. He said, if you went to a 10K system, the bars wouldnt flex as much and you would notice that. But most of the time, I will be at 600 at the tongue
WD hitch, better to be under rated or over rated? cgseanp Hitches, Couplers & Balls 32 08-31-2018 03:09 PM
ST-D rated tires vs ST-E rated tires Eagle & Bear Tires 6 11-15-2017 10:16 AM
15 '' D rated verses 16'' E rated Tires hodges53 Tires 9 07-25-2014 07:16 PM
Should I worry? Hitch receiver rated 400# tongue but trailer 459# amm3824 Hitches, Couplers & Balls 10 04-03-2011 09:59 PM
Size of 600lb Reese Trunnion bars? glacierrunne Hitches, Couplers & Balls 5 08-09-2010 08:07 PM
