Old 06-30-2023, 10:06 PM   #1
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
What to expect with a longer shank on the hitch?
So in putting a new hitch on the truck I find I need a longer shank. I am finding one that would definitely work and give me the ball height I need that adds 6 inches between the truck and trailer. Another option is one that might lower my trailer height an inch but only adds 2 1/2 inches to the distance between the truck and trailer.
My question is: what should I expect adding 6 inches of tongue length? Is having the trailer an inch lower on the tongue but with a shorter tongue length better?
Basically what have folks experienced?
I tow with an F250 diesel and have a 2007 FB 27 ft. trailer. We load and travel with food for two weeks at a time, so loads are towards the upper end of things which is why I am asking about real life handling experience.
Any insight is welcome. Wondering trailering as well as backing changes.
The new hitch is a Reese Dual Cam II and receiver hitch on the truck is a Curt class V hitch.
Thanks to all in advance.
bweybright is offline   Reply With Quote
Old 06-30-2023, 10:25 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I have a 14" long shank. I had another hole drilled at 12". I use that shank for both the AS and a dump trailer. I don't notice any big difference going forward. I notice a difference backing...the longer shank gives me room to turn quite a bit sharper. The longer shank also allows me to drop the tailgate without it hitting the tongue jack.
CRH is offline   Reply With Quote
Old 06-30-2023, 10:51 PM   #3
Interesting....I would be going from a 12 in shank to an 18 inch shank. I already appreciate the tailgate benefit. More wondering the backing into tight campsites and road bounce on highways. Actually wondering if it would minimize the bounce I get now? Hmmmmm.
Thank you for the quick response. I look forward to much insight and input.
Old 06-30-2023, 10:53 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
18" shank? Never saw one.
Old 06-30-2023, 10:56 PM   #5
EQ90-02-4500
Now you have.
A good day when you learn something new every day. Now you got learned something new.
I should have said length, not drop. I give you that. My bad there.
Old 06-30-2023, 11:00 PM   #6
But my initial post did say length, not drop.......just to clarify.
Old 06-30-2023, 11:01 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
The overall length for that model is 18". The pin holes are 14" apart. The Curt I use has the same specs...I just stuck a tape measure on it.
Old 06-30-2023, 11:07 PM   #8
It all depends on what measurements you are needing it seems to be to me. I am aware of the pin hole measurements. and they fit my need. But, it will extend the space between my trailer and the truck by 6 inches.
I think we are talking the same thing....just what measurements we are using. So an email\website communication conundrum
All good. Just wondering what I should expect putting the hitch 6 inches out from where they live now.
Lots of weird measurements for shanks on the sites.....just trying to figure it out.
Old 06-30-2023, 11:09 PM   #9
I would be interested in knowing what Curt shank you use. I need the length, but would be happier with 1 1/2 inches shorter drop.
Old 06-30-2023, 11:10 PM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine is a Curt 17122. You could put your head on and have the bottom cut off.
Old 06-30-2023, 11:12 PM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
Screenshots:
Old 06-30-2023, 11:13 PM   #12
2018 28' International
Fayetteville , Georgia
I switched an 18 inch shank, (14 inches ball mount-to-pin hole) towing a 2018 Serenity 28 with an F250 diesel and a Fastway E2 hitch, 1000 lb bars. I added one additional washer (6 total) and when hitched have one inch compression on the rear, and zero rise in the front. 1100 lbs tongue weight. Tows like a dream. No sway, no bounce. Generally you try to keep the shank extension as short as possible, but no towing issues from my setup.
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 06-30-2023, 11:16 PM   #13
Thank you. I will check it out. I appreciate the input.
A side note is I need the shortest drop I can get now as backing it into my shop I go through a dip and then she shop rises.
Part of my decision is that I am likely doing the lift at Jackson Center this September....so I open to thoughts.
I do appreciate your input and have added your shank to my short shopping list.
Old 07-01-2023, 08:44 AM   #14
Mollysdad's Avatar
I found different manufacturers measure differently.
One might measure between the pin hole and the mounting holes, while another measures overall length.
I look at e-Trailer for the shank because they provide videos with a tape measure! Then shop around.
When I'm king, all manufacturers will measure the same.
Old 07-01-2023, 10:20 AM   #15
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
One of the classic mods done by pro's when setting things up to minimize sway:
You shorten the shank.
The easy (but not complete) explanation is that the further back the ball is from the truck axle, the more leverage there is. That increases the likelihood of oscillatory sway.
No, this is *not* the only consideration when setting things up. It is just one of many on the list of things to consider.
uncle_bob is online now   Reply With Quote
Old 07-01-2023, 11:48 AM   #16
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Hi
Exactly, when I changed hitch Can Am wanted to shorten the shank, as they do for many setups, the purpose is to reduce sway. But if they did then my tailgate would not fully open, and I never had any hint of sway, so we left it as it was and I still never experience any sway.
Andy did explain that different AS models will vary in their tedency to sway, it's a question of weight distribution which varies according to the floorplan, and to how it is loaded; but my 28' RBQ model is not known to sway.
Hermes is offline   Reply With Quote
Old 07-01-2023, 05:51 PM   #17
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
RE: What to expect with a longer shank on the hitch?
Greetings Bob! This is going back more than 27 years for me, but I transferred the hitch head from my GMC G20 Conversion Van with rear mounted spare tire to my next similar tow vehicle, a 1995 Chevrolet K1500 Z71 Extended Cab Pickup with all of the heavy duty trailering options as well as the full-bore luxury interior. The Conversion Van had always had issues with porpoising and instability, and I blamed the van resulting in its replacement after two years. Similar issues were again noticed with the new setup, but I hadn't focused in on the hitch. I was at the International Rally in Boise, Idaho (1998), and after three years of struggle with less than ideal towing manners, the Reese Towing Products representative identified my problems almost immediately -- the long extension of the ball mount was a perfect storm of sorts -- just the right amount of distance between the tow vehicle's rear axle and the center point of the rear axles on the trailer -- this was causing my porpoising. Second, and not directly related to the porpoising, he found that the hitch shop that had helped me select my Reese Strait Line Hitch with Dual Cam Sway Control over sold my weight distribution bars -- I had 1,000 pound bars when all that I needed were 750 pound bars. After swapping out the hitch head and weight distribution bars for the correct components, the trailer's manners returned to those expected of an Airstream. I was also able to have the crack that had opened up in the interior skin of the trailer above the door repaired that had opened up during the time that I towed with the over rated weight distribution bars -- in the 27 plus years since, I haven't had a recurrence of either issue. I now make it a point to insist that my hitch shop adjust my hitch installation on a new tow vehicle such that the ball mount is as close to the tow vehicle's rear bumper as possible to keep that distance at a minimum.
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 07-01-2023, 07:37 PM   #18
Adiredneck's Avatar
2014 27' FB Classic
Cambridge , New York
Images: 8
I use a combination of an Equalizer and AirSafe hitches, which puts my ball almost 21" behind the receiver. I've noticed no change in handling (other than the improved comfort of making the suspensions independent). It might make it a little harder to back up, but I sucked at that even before the AirSafe...
I tow a 27 FB Classic with a 2015 Ram 3500 diesel, so I hardly notice that I'm towing, anyway.
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 07-01-2023, 09:26 PM   #19
Very good information to research, thank you. With my shorter shank I often get porpoising on the modern concrete highways, black top not so much, with 800 pound bars. The joy of black magic hitch configuration. T
Thank you for your thoughtful input. I have a month to figure it out.
Old 07-01-2023, 09:39 PM   #20
I am wondering about that added length for backing up in state parks, etc..... I have a crew cab....part of my concern. You have a classic, heavier than mine I think.
I am really torn. I don't have sway issues now except when coming down mountain passes and the trailer wants to pass me a bit. I need a new tongue jack and the extra 6 inches lets me have more options.....
And the extra tailgate space.... You have me pondering.
Longer Shank or Lift Kit? AirF22 Towing, Tow Vehicles & Hitches 13 03-22-2022 08:55 PM
Longer shank. Mollysdad Hitches, Couplers & Balls 20 07-30-2018 05:14 PM
Had to get longer Equal-I-zer shank Bgibbs Hitches, Couplers & Balls 0 03-02-2017 10:45 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 12:48 PM
