07-05-2023, 05:54 PM
#21
2014 27' FB Classic
Cambridge
, New York
I really like my combo. With the extra length between receiver and ball, you can actually make sharper turns when backing up. I think my backing issues are more a result of operator error than hitch length...
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
07-15-2023, 04:00 PM
#22
2018 19' Flying Cloud
South of Austin
Originally Posted by bweybright
My question is: what should I expect adding 6 inches of tongue length? Is having the trailer an inch lower on the tongue but with a shorter tongue length better?
Your shank lengths are not real relevant. What is important is a level trailer ride. Or if anything slightly down, never up.
07-15-2023, 04:41 PM
#23
2024 30' Globetrotter
Houston
I believe longer shank length lengthens the distance between the ball and the TV rear axle, which in turn then adds to the amount of front end lift and rear squat when the trailer weight is added. This then means more weight distribution is required to restore the TV from axle load.
09-26-2023, 08:13 PM
#24
GB
2016 27' International
1997 34' Limited
Saint Cloud
Picture of Equilizer with AirSafe hitches together
Originally Posted by Adiredneck
I use a combination of an Equalizer and AirSafe hitches, which puts my ball almost 21" behind the receiver. I've noticed no change in handling (other than the improved comfort of making the suspensions independent). It might make it a little harder to back up, but I sucked at that even before the AirSafe...
I tow a 27 FB Classic with a 2015 Ram 3500 diesel, so I hardly notice that I'm towing, anyway.
Can you provide a picture of your setup with both the Equilizer and AirSafe hitches?
I have an Equalizer Hitch with an 18" shank length that I used for my 27FB and F150.
New Tow Vehicle. F250 Crew Cab 2.5" receiver needs advise on setting up the equalizer hitch and Airsafe.
Still want to open the tailgate so I need a longer shank or will the AirSafe hitch solve that problem?
Gil
"Everyone buys on emotion and justifies with logic.
That is why I own 2 Airstreams... I needed them."
09-27-2023, 08:03 AM
#25
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
There are two very different measurements on a shank.
One is how far above or below the receiver it can go ( = vertical measure).
The other is how far *behind* the receiver it puts the ball ( = horizontal measure).
Moving the ball further back ( the horizontal number) will impact sway. That's just the basic physics of how sway works.
09-27-2023, 08:36 AM
#26
2017 16' Sport
N/A
, N/A
I haven’t measured the distance with the Hensley Hitch that puts the receiver well back from the ball, but no sway there.
09-27-2023, 11:29 PM
#27
2007 22' International CCD
Corona
Ditto on any Propride system…
09-28-2023, 02:27 AM
#28
2019 28' Flying Cloud
Broward
Increasing shank length is generally not a good idea, as it gives the trailer more leverage with which to push the tow vehicle around. The greater the distance from the tow vehicle's rear axle to the hitch ball, the less stable your rig will be.
09-28-2023, 10:28 AM
#29
2016 28' International
Trois-Rivieres
, Quebec
The geometry of the Hensley/Pro Pride prevents sway and compensates for whatever effect shank length could have. The loading of the trailer is also a factor with rear loading increasing sway conditions.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
09-28-2023, 11:02 AM
#30
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Exactly.
With a "normal" hitch setup, moving the ball back *is* a problem.
09-28-2023, 11:23 AM
#31
Broward
Unfortunately, this is untrue. Yes, a Hensley hitch will prevent trailer sway, but the stability problem affected by shank length is not trailer sway, it's tow vehicle oversteer. A Hensley hitch does not prevent oversteer.
09-28-2023, 11:38 AM
#32
2022 25' Flying Cloud
NCR
, Ontario
longer shank length lengthens the fulcrum length
that is the main item to reduce in stable towing.
the fulcrum length for 5th wheel or big truck is ZERO
its best to reduce this for more stable towing
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
09-28-2023, 03:23 PM
#33
2017 16' Sport
N/A
, N/A
Maybe not, but the trailer will track with the vehicle, no sway, less chance of loss of total control.
09-29-2023, 08:45 AM
#34
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
..... welcome to why we need a much better set of terms to sort all this out. I've always wondered why some bunch of papers didn't get written defining new terms for these effects.
