Old 05-20-2020, 08:29 PM   #1
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
San Marcos , Texas
Images: 38
Send a message via AIM to kevinkatz
What is your lowest clearance?
I am interested to know what people have as the minimum clearance under their trailer. How far is it from your lowest point to the road surface? What do you think that the minimum is for safety?
Asking this because I am working on a 1949 Curtis Wright and considering putting the spare under the trailer.
kevinkatz is offline   Reply With Quote
Old 05-21-2020, 09:30 AM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I'm not hooked up at the moment so I can't measure exactly, but it matters a lot where the low point is relative to the truck. The further forward, the better. My spare tire is under the front of the Airstream just behind the A frame, and that's the lowest point on the unhooked trailer. I thought it might be a problem originally, but it's near impossible to bottom out there due to the geometry with the truck. My WD hitch spring bars are actually far lower and would hit first.
TheGreatleys is offline   Reply With Quote
Old 05-21-2020, 10:06 AM   #3
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
San Marcos , Texas
Images: 38
Thanks. I am also concerned about road debris like disintegrated truck tires.
Old 05-21-2020, 08:05 PM   #4
2018 25' International
Slidell , Louisiana
The low point on my 2018 25'FB International is the front of the spare tire brace at 6 3/4 inches. On the back, the skid plates are at 10 inches. With some trigonometry I estimate I can navigate a 15% grade change dip/swale without hitting anything. The tire brace will hit at about 18-19% grade with the weight distribution tension helping to keep the front up. The rear skids hit at 16%.
My forward tank pan is 10 3/4 inches and will high center on a 7% grade change ridge.
Brian
Old 05-23-2020, 09:36 AM   #5
2020 25' Flying Cloud
Brookfield , Connecticut
Lowest clearance
Does anyone have the rear clearance measurements for a recent 25RB? We are currently looking at recent models and trying to determine whether we will need a lift kit to get up our driveway.
Redlac is offline   Reply With Quote
Old 05-23-2020, 12:23 PM   #6
Slidell , Louisiana
Use the grade numbers I provided, they are far more accurate than just using the vertical clearance. The rear skid is at 9 7/8 inches. If you have a positive grade change (swale) over 15% you will have clearance issues. If you have a negative grade change (ridge) over 7% your pan will high center scrape.
Brian
Old 05-25-2020, 10:02 AM   #7
Thanks Bayou Biker,
The left side of the driveway is 14.1% and the right is 15.3% so I'll favor the left and have some plywood available in case I get close. We'll be putting your theory to the test next weekend as we just purchased a 2020 FC 25RBT.
Old 05-26-2020, 09:18 AM   #8
Slidell , Louisiana
You may have issues with your WD tension bars though if you don't remove them. Mine are 7 inches to the ground minimum and at 15% tensioned up, they need another 1/4 inch to clear. If I go off the curb at an angle to reduce the grade change they clear.
Brian
Old 05-28-2020, 10:36 AM   #9
Thanks Bayou Biker,
I will probably remove them before backing into the driveway. That may raise the rear end as well.
Vintage 1972 airstream inernational lowest reserve eBay Watch Airstreams on eBay 0 12-01-2012 09:00 AM
Easiest/lowest passes between Saratoga, WY and Steamboat Springs, CO bonginator On The Road... 0 05-26-2012 08:36 PM
lowest rated rvparkreview boondockdad On The Road... 6 07-24-2009 11:52 AM
Lowest Gas Prices! Silvertwinky On The Road... 0 12-08-2008 05:35 PM
Lowest Purchase Cost for a new Cyclo and pads??? macsfriended Cleaning, Stripping & Polishing 6 09-19-2005 04:55 PM
