Old 10-20-2021, 08:26 PM   #1
Canyon Lake , Texas
WDH Recommendations: 23' Globetrotter/F150
I am buying a 23' Globetrotter FBT that I plan to tow with an F150 Powerboost. It is just my wife and me. My F150 has 11600 towing capacity, 1160 max hitch weight, and 1535 lbs of payload capacity. After allowing for myself, my wife, and cargo in the F150 bed, I will have about 900 pounds of payload capacity for the trailer.
Any thoughts on the following weight distribution hitches:
1) Andersen WDH for this combination (seems to have some benefits: ease of use, novel anti-sway, and porpoising).
2) ProPride. It seems the best solution for anti-sway and has effective weight distribution, although some people complain about porpoising?
3) Other recommendations?
4) Any thoughts on the Hayes sway control combined with option 1.
My trailer towing experience has been with less than 20' trailers and 500 lbs hitch weight.
CordovaBob is offline   Reply With Quote
Old 10-20-2021, 09:18 PM   #2
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
Every major brand has loyal followers. I think the key is proper setup, whichever WDH you choose.
I use the Blue Ox Sway Pro with my 1/2 ton truck and 23 FB trailer. I’m very happy with it. I just towed across west Texas in very high cross winds and it performed beautifully. It’s lighter than some of the other hitches, it’s quiet, and it’s easy to connect and disconnect. I experienced a double tire blowout last Sunday - both curb side tires at 65 mph. Everything stayed stable during an emergency stop on 2 tires.
The ProPride is very interesting, but it’s very expensive and may be overkill for your application, in my opinion.
Your weights and capacities should be fine, but you’ll have to pack carefully and not get crazy. For comparison, my truck has a payload capacity of 1,479 lbs. When fully loaded for a long trip when I bring my generator and fuel, I can get close to that limit.
Good luck with your choice!
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 10-20-2021, 09:28 PM   #3
2017 25' International
West Lake Hills , Texas
Maybe less is more on this case.
The ProPride will eat into the remaining 900# of payload. I’d try something lighter. The ProPride weighs ~200#. The Equalizer is a good hitch too. I used it for a while on a 25FB.
Fungus is offline   Reply With Quote
Old 10-20-2021, 10:10 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard...👍
A PPP hitch will not CAUSE porpoising, any hitch improperly used can make it worse.
But it will work very well on the larger Airstream in your future. 😂
It's not so much what hitch you choose, it's that it's installed properly, you understand how to use it, and it's matched properly to the TV.👍
Sweet Streams...
Tahawus
Love for the Adirondacks
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
RLC
Old 10-21-2021, 02:00 PM   #5
1996 25' Excella
Tillsonburg , Ontario
I intend to pul a new to us 23FB with myJeep GC
It comes with a Hensley but if I had to supply the hitch I would just use an Easylift
I pulled a 25 with that hitch with no issues whatsoever.
JCW
JCWDCW is offline   Reply With Quote
Old 10-21-2021, 04:49 PM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Be sure to deduct the actual weight of whatever hitch you decide upon ... from your 900# estimate.
Also see if you can find a friend with a tongue weight scale - you will likely be VERY surprised; the published specs are way under actual reality !!! For our 25 EB, they were off over 250#
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2022 Ford F350 6.2 V-8 on order ; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 10-21-2021, 09:50 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Look at a Hensley "Cub." They are designed for lighter TT/TV combinations. It would not be overkill if it adds safety, .ie., impossible to allow sway.
guskmg
Old 10-21-2021, 10:49 PM   #8
2017 28' International
Jim Falls , Wisconsin
I pull a 28’ with a Propride. Had a Blue Ox. Didn’t like it. Too much bow affect. With a Propride I barely feel that big truck going by me. But a 23’ might be a bit different. Porpoising isn’t caused by the hitch. It is caused by the rear of the truck being a bit bouncy. The F150 has a problem with that. I bought a Roadmaster suspension system for my F150 and that was eliminated. Others have put on Bilstein shocks. I recommend doing one or the other. I would do that for whatever hitch you get.
Daquenzer is offline   Reply With Quote
Old 10-28-2021, 03:06 PM   #9
JJTX's Avatar
2018 19' Flying Cloud
South of Austin , Texas
I use a Fastway E2 trunnion. They are rated up to 10K trailer weights.
You can buy one on amazon and save some cash, or get one in the store such as Crestview RV in Selma. 6K 8K and 10K models. Just be aware the online version usually don't have hitch balls installed.
I actually bought a HUSKY on amazon first, however my 19CB trailer frame was too small for it. Went with Fastway E2 and I got it at Crestview RV there in selma.
JJTX is offline   Reply With Quote
27 Globetrotter and old EazLift 10000# WDH dannko Hitches, Couplers & Balls 10 08-06-2021 11:34 AM
Blue Ox WDH on a F150 HD Pilot Hitches, Couplers & Balls 43 10-19-2020 02:20 PM
F150 or 2017 F250 or 2018 F150 Diesel? wponder Tow Vehicles 63 09-12-2017 10:49 AM
Reese Dual-cam WDH vs. Equal-i-zer Hitch AndyPenny Hitches, Couplers & Balls 20 02-18-2008 12:22 PM
Newbie WDH question/advice myoung Hitches, Couplers & Balls 41 01-09-2006 11:12 AM
