Originally Posted by RxDiesel
Thanks for the helpful posts, guys, particularly the video link. That said, lots of airbags comments, but not much on the enhanced bump stops: Timbren or Sumo. I understand they only engage under load - which, as the video explains well, is redistributed with a WD hitch to the front and trailer. I see the attraction of airbags for 'level', but any thoughts on the Timbren/Sumo bumpstops, a relatively inexpensive [if you install yourself] add on to address leveling for a heavy load on the rear axle ......?
Given the choice between airbags and enhanced bump stops, airbags are the better solution for 2 reasons
1) Airbags are engaged through 90% of the suspension travel
2) Their augmentation of spring rate can be adjusted for load
Bump stops are just that, meant more for off-road type use where they serve as a jounce stop to prevent harsh bottoming out. They only engage through the compressed portion of the suspension travel under normal ride height, more like an overload spring. Not adjustable and if setup for towing for example, may not be ideal for unladen use as it will limit useful suspension travel and comfort. Yes, these are enhanced ones trying to grab some of the towing market, but their utility is probably still more useful for the heavily laden overland/off-road crowd.
