Old 09-29-2020, 08:54 AM   #1
Lake Mills , WI
Vibration dampening
What is the deal with vibration dampening hitches? Is this something I should consider upfront or is this something used to remedy a specific problem? I'm purchasing a Flying cloud 23FB and will tow it with a Durango or GLE 450.
tlars is offline   Reply With Quote
Old 09-29-2020, 09:02 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Most, if not all, of these devices are not compatible with weight distribution hitches.
Richard
Old 09-29-2020, 09:05 AM   #3
"Cloudsplitter"
Welcome Aboard 👍
What has worked for us...don't buy anything until you have determined you NEED it.
For us, those hitches are just another "gizmo".
We have a 2500 Burb with a very compliant suspension unnecessary for us.👍
If you have a TV with a HD suspension...it's a choice.🥴
More important...don't 'over hitch' by getting higher rated weight distribution bars than you actually need.
Example...we have a tongue weight of 1200lb, we move a total of 720lb,(560 back to the Burb front axle, 160 back to the AS axles.) using 1000lb bars.
Old 09-29-2020, 09:37 AM   #4
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
I have an AirSafe and it works with WD and it does make the connection a lot more smooth. If 1/2 ton truck, it's not necc, but 3/4 ton and above, it really makes a difference.
A Durango or GLE would not need a dampener as it's already a pretty smooth ride.
panamerican is offline   Reply With Quote
Old 09-29-2020, 10:21 AM   #5
2007 27' International CCD FB
San Diego , California
Agreed with others. Not necessary for a smooth riding tow vehicle. Especially for a passenger car type tow vehicle as you're proposing. These are really meant for oversprung tow vehicles such as HD 3/4 and 1-ton. Where they are using too much truck, and are carrying relatively too little payload, resulting in a jarring ride. I would worry about how the jarring ride effects the driver and passengers before the trailer
There's cons to using such a thing as they also tend to push the ball further rearward. Such that it minimizes effective wheelbase by decreasing the wheelbase to rear-overhang ratio. Worse for sway and porpoising.
pteck is offline   Reply With Quote
Old 09-29-2020, 11:32 AM   #6
2009 34' Panamerica
2005 28' Classic
Very true.....
Sound dampening AKNate Full-Timing 12 10-31-2019 12:14 PM
Tranny Tailshaft Vibration? swebster Mechanics Corner - Engines, Transmission & More... 31 02-22-2006 06:33 PM
Intermittent Chassis Vibration Chaplain Kent Mechanics Corner - Engines, Transmission & More... 29 10-29-2005 09:49 PM
Furnace Vibration and Noise flyfisherman Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-16-2005 07:37 PM
1997 "B" generator vibration & noise TuckerT Sprinter and B-van Forum 0 10-06-2004 06:42 PM
