Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-14-2020, 08:44 PM   #1
2020 20' Bambi
Clayton , North Carolina
Using Blue Ox WDH without tension bars?
Hi wise sages, If I want to pull the 20’ Bambi from the storage lot to street in front of my house, which is a 2 mile trip at speeds of 0-35/40 mph, I should be able to do that without rigging up the tension bars, right? I verified 2020 Bambi 20’ has 540 lb tongue weight with a Sherline I bought and my 2020 Tundra has a payload capacity of about 1350 lb and will have no cargo. Just want to bring to house to wash roof and install a second 90W Zamp solar on the roof and a Victron Smartsolar MPPT 100/30.
smsasf is offline   Reply With Quote
Old 08-14-2020, 09:03 PM   #2
2017 23' Flying Cloud
Bartlett , Tennessee
I bet your receiver has a 500# tongue weight limit without WD. Do you feel lucky?
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 08-14-2020, 09:06 PM   #3
2007 22' International CCD
At slow speeds, see how it handles. If it’s squirrelly, pull over and put the bars on. No biggie. I move my 22 footer short distances with no WD tension at slow speeds with a Tacoma. Like around the block or so. Just be cautious and careful.
Old 08-14-2020, 09:11 PM   #4
2020 20' Bambi
Tow package with Class IV receiver hitch and 960lb tongue weight limit.
Old 08-15-2020, 08:03 AM   #5
If that is 960# without WD, then you have your answer.
Bobbo and Lin
Old 08-15-2020, 08:27 AM   #6
2018 25' International
Slidell , Louisiana
You won't have any trouble at all at speeds under 50 mph. The stability speeds for your combination with no hitch support are well over 60. You have the tow package so suspension won't be squishy either. Enjoy the safe pleasurable drive.
Brian
Old 08-15-2020, 09:15 AM   #7
2020 20' Bambi
Brian, thanks. As I mentioned, I just wanted to be able to tow from storage lot to my house, less than 2 miles and speeds less than 40 mph (1/3 of distance in neighborhood under 25 mph) so I can work on solar changeout things in front of house, and then return AS to storage lot without having to go through coupler-ball lockup, jacking up, putting on tension bars, etc.
I actually have an additional 2 5/16 ball but I have not purchased a simple drop-down receiver hitch to use for this simple tow and was just concerned if there would be any issue using the Blue Ox without the tension bars. My AS only weigh 45% of my max tow weight rating. And when I set the coupler on the ball prior to using tenion bars the back end only goes down 1/2-1”. So I figured ok. But wanted to hear from you folks before I screwed up something.
Old 08-15-2020, 11:48 AM   #8
Slidell , Louisiana
Ah yes, I understand now. The hitch head and Shank are fine without the bars too as you have heard.
Brian
Old 08-15-2020, 05:52 PM   #9
tkowalyk's Avatar
2013 27' FB Classic
Clermont , Florida
Images: 11
Why wouldn't you want to put on the bars? It's a 5 minute exercise, and will help prevent the possibility of tour jack bottoming out.
I have an F250, and would use my bars. I have not used the bars when pulling up 50 feet on my property when moving it to wash it (like I did today)
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 08-15-2020, 08:54 PM   #10
2020 20' Bambi
Thanks, you offer something to consider. But from where my AS is stored to my house the county roads and residential streets do not have any dips where I would be concerned about bottoming out. Even so, in order to not lift the BO drawbar and hitch ball 2-4 times I am considering buying a simple Reese 2” drop drawbar and placing my extra 2 5/16” ball on that for the simple back and forth to home tows. On the 5 minutes, North Carolina humidity and direct sun still makes my T-shirt fairly wet after 5 minutes. Anyway, the various advice has nelped me understand the pros and cons. thanks again.
Old 08-16-2020, 06:13 AM   #11
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
I take my tension bars of quite a bit for slower speeds like that. It makes a lot less noise and less wear on the entire system.
Mikebrady62 is offline   Reply With Quote
Old 08-16-2020, 07:18 AM   #12
Slidell , Louisiana
The low point on mt 25' is the spare tire support bar. It will scrape transiting my driveway swale (14% grade) if I don't have the bars with at least partial tension.
Brian
Old 08-16-2020, 07:19 AM   #13
Baltimore , Maryland
Brian, can you tell us how you determined at what speed he can travel safely? What simulator? Can you provide the specific data for the tow vehicle and trailer that you used? Forum members would like to know how you are to able come up with such specific information to be able to accurately predict stability on they’re rigs.
Warning Message
Caution! Most advice given here is nothing more than a subjective opinion. Please reference the vehicles owner manual for instruction on towing and hitch use which is based on physics, facts, and research.
Profxd is offline   Reply With Quote
Old 08-16-2020, 07:26 AM   #14
Bruce B's Avatar
2021 25' Globetrotter
Jamestown , Rhode Island
their...
Loving our 2021 Globetrotter 25 shopping for the next tow vehicle and 2020 GMC 2500 Sierra Denali Duramax.
Bruce B is offline   Reply With Quote
Old 08-16-2020, 07:43 AM   #15
Slidell , Louisiana
The 2020 Tundra at it's towing limit passed the SAE handling test for sway damping and cornering so its an easy call. Extrapolating up puts the the stability speeds north of 70 at a minimum. Don't even have to sharpen the pencil for this one.
Brian
Old 08-16-2020, 08:13 AM   #16
Originally Posted by Bruce B View Post
their...
Thank you!
Warning Message
Old 08-16-2020, 08:16 AM   #17
But what about the trailer and it’s loading condition? COG position and yaw inertia? It passed the handling test with a specific known trailer loading condition. So you guessed and made assumptions on this data?
Warning Message
Old 08-16-2020, 09:35 AM   #18
Slidell , Louisiana
It's an Airstream which are difficult to shift the COG too much and I have faith the OP knows a thing or two (of the COG is that far out, WD tension won't help much anyway) but, if it helps your ego to believe I'm wrong, knock yourself out.
Brian
Old 08-16-2020, 09:46 AM   #19
Antsville , FUBAR
COG for an AS is most important when their unhitched, TW takes precedent & while there being toed. 🤓
Old 08-16-2020, 10:18 AM   #20
2017 20' Flying Cloud
Williamson County , Texas
I have had no problem towing my 20' FC Bambi with my GMC Canyon without the WD bars maybe 60 miles at 65 MPH, light wind. Surely your Tundra would have an easy time of it. Without WD bars my front rises about 1/4", with bars drops about 3/8". Someone mentioned exceeding tongue weight, but WD does not change allowable tongue weight as far as TV is concerned.
2018 GMC Canyon V6 Mallet Supercharger
SYC2Vette is online now   Reply With Quote
Blue Ox WDH on a F150 HD Pilot Hitches, Couplers & Balls 43 10-19-2020 02:20 PM
Keeping our WDH bars & Sway Control accessible ers Hitches, Couplers & Balls 1 08-12-2020 08:19 AM
Newbie Question - Pull out without tension bars? Wgsouth Towing, Tow Vehicles & Hitches 12 04-16-2018 11:43 PM
Touareg+25FB without WDH ? Timofeevich Tow Vehicles 42 11-27-2013 04:49 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
