Old 07-30-2021, 03:57 PM   #1
Strafford , New Hampshire
Trailer RVR Valet
Does anyone have the Trailer Valet RVR5 or similar model? I am trying to get my trailer into my garage. it will need to go into a tight spot. It appears this trailer Valet is just what I need to maneuver into place. Just wanted to get some feed back before I put out the money. It is an investment but cheaper than building another building.
My Garage is a three bay with enough Clarence. My truck would not be able to move it into the corner like I need it to.
Stacy
swschoell is offline   Reply With Quote
Old 07-30-2021, 04:00 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
A front hitch on your truck will enable much more maneuverability than a rear hitch. They also cost a lot less. That is the simple alternative. Without more information on what your exact situation is, it will be hard for posters to help much.
Gene
Old 07-30-2021, 04:15 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
It probably would help if we knew what AS trailer you have. Since there is a *very* large range of trailer and tongue weights, some really are not going to work with this or that model.
Old 07-30-2021, 05:12 PM   #4
2016 16' Sport
Miami , Florida
I have the manual XL and it works great with my 16. Slow but great. If you don’t have far to go I’d consider this.
Shiny16 is online now   Reply With Quote
Old 07-30-2021, 10:29 PM   #5
I have a 1974 27’ Overlander. My garage is N oversized 3 bay with two oversized doors. The garage is 20 deep by 40 wide. I need to move the trailer in through one side and move it to the opposite side. Once inside I believe the trailer will sit kitty corner across two bays , leaving room for my truck in the third bay.
Old 07-30-2021, 11:08 PM   #6
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
I move my 30’ FC Bunk with the Trailer Valet XL, works great.
https://youtube.com/shorts/y74JNXBcdRE?feature=share
- Stewart
s1000pre is offline   Reply With Quote
Old 07-31-2021, 06:22 AM   #7
2016 16' Sport
Miami , Florida
Originally Posted by swschoell View Post
I have a 1974 27í Overlander. My garage is N oversized 3 bay with two oversized doors. The garage is 20 deep by 40 wide. I need to move the trailer in through one side and move it to the opposite side. Once inside I believe the trailer will sit kitty corner across two bays , leaving room for my truck in the third bay.
The 5 is limited to 550 tongue weight. I would think you need the 9 but I donít know your tongue weight.
Honestly the remote units look really neat but unless you have some physical limitations I think the XL and a good drill or just using it manually would be fine for you application.
If your on a flat surface itís very easy to move by hand cranking and allows you lots of control. It doesnít sound like you have far to go.
Trailer Valet XL Trailer Dolly CWSWine Tow Vehicles 0 07-09-2019 11:04 PM
Trailer Valet on Bambi Sport tjwoods1 2005 and newer - Bambi all models 47 05-08-2019 06:05 AM
Trailer Valey RVR NoResults Towing, Tow Vehicles & Hitches 2 03-13-2019 03:43 PM
Seasoned RVr new to Airstream Raminc General Repair Forum 1 09-18-2018 11:08 PM
Trailer valet (two available) Gsmblue Airstream Classifieds 0 10-28-2015 12:44 PM
