05-22-2021, 11:33 AM
#21
2016 19' International
Ft. Pierce
All great advice. I’ll only add that you should refer to your manual to familiarize yourself with all the ways your vehicle controls speed and braking. I live in Florida and I get out the book before I head west so I can refresh myself with what works when. Enjoy your trip!
05-22-2021, 01:57 PM
#22
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The least obvious thing running in the mountains (at least to me): paying attention to the wind conditions. Mountains can block the wind, they also can focus it. Coming around this or that and getting socked is not at all uncommon. This applies just as much in the east as in the west .....
05-23-2021, 09:21 AM
#23
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Originally Posted by Mollysdad
IF the OP's Tundra is the 5.7 with a tow package, then yes, it has tow/haul, and I'm not aware of overdrive. (that we control)
I leave mine in tow/haul all the time while towing. Although I might not be able to tell leaving a gas station, the Tow/Haul changes the shift points so you stay in lower gears longer.
We do the same with our Tundra. Tow/Haul, and I keep set at 5th gear max. On steep declines I drop it to 2nd gear. No problems! Tundras are amazing.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
05-23-2021, 09:32 AM
#24
2018 28' Tommy Bahama
Silver City
, New Mexico
While all that advice is helpful, flip on your hazards while you are slowly and safely making your way to the lower altitude. The hazards will likely alert the jockey behind you to change lanes before he/she mates with your AS.
Class A Safari Trek 2830 - SOLD; TC Lance 1010 - SOLD;
TT Arctic Fox 30U - SOLD; TT Forest River Mini - SOLD;
Class B+ Pleasure Way Pursuit - FS; $$$$ - GONE
If it ain't broke I can break it
A dime still makes a pretty good screwdriver
05-23-2021, 02:09 PM
#25
2021 27' Globetrotter
Fort Lauderdale
Engine break by forcing higher RPM, just like cruise control, don’t operate the trailer’s brakes. On a downhill, reducing speed only with the engine and without assistance from the trailer’s brakes gives a lot of work to your hitch, so you may want to chose the best, the one that will help you keep sway under control when the trailer wants to maintain speed (or by gravity, accelerate) and your TV is resisting that force. Even the best hitch (PP3 IMHO) may not be enough if, for instance, the descent includes a sharp curve. In that case, BEFORE THE TURN, I a apply the TT brakes by hand. They say here that the TV capabilities are of what they can stop even more than what they can pull. They are right and, again in my opinion, they need the help of the TT brakes as well. 90% of my towing is in the Rockies.
GT 27 2021, F250 2022 Platinum- 2022 Tesla X - 2021 Ford Mustang Mach E - 2022 Tesla 3 - PP3 hitch
GSD Sigrid - Fort Lauderdale, FL; Denver and Summit County, CO.
05-23-2021, 03:21 PM
#26
Cloudland2
2016 25' Flying Cloud
Trenton
, Georgia
I was looking up the Appellation Mountain Range in my World Book Encyclopedia and see they are just east of the Salutations Range. You should be fine.
Dave & Carolyn
WBCCI #2584
05-23-2021, 07:34 PM
#27
2021 27' International
Canton
, Georgia
Ever try spell check?
05-23-2021, 07:46 PM
#28
2012 28' International
Prince Edward County
, Ontario
There is lots of good advice above. I also suggest the Mountain Directory to be used in route planning. There are two books, East and West.
https://mountaindirectory.com/shop/
05-24-2021, 07:30 AM
#29
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you *do* use the trailer brakes a lot, you will destroy them. I have a lot of data (and a lot of bills ) to back this up. They simply are not made to do a lot of braking all the time.
05-24-2021, 07:51 AM
#30
Spokane
I really agree with this. In theory the TV brakes will slow the TV and the brakes on your trailer will slow the trailer. They need to work in tandem for optimal effect. I do like the boost function on my Prodigy controller. On those steep trips out of the mountains I do "boost" the trailer brakes. I never use the trailer brakes alone. Just as it is unwise to expect your TV to do all the work, you shouldn't do the same with the trailer.
I bought my '06 in '09 and it had very few miles on it. I take it in every 10K miles for a bearing/brake maintenance and with over 50K miles in, the brakes are still in good shape. Get the controller set up correctly and the system works together to get things stopped safely.
05-24-2021, 09:12 AM
#31
Bompagene
Pahrump
, Nevada
Snub braking
30 years of OTR trucking and many miles of RVing in mountains. Yes, slow before descent. Hazard lights. All of the advice from everyone is spot on.
This link might help explain the braking technique that WORKS! https://www.dieselhub.com/towing/snub-braking.html
I used this dropping down 9 % grades with a tanker full of hazardous waste, yup it works.
05-24-2021, 09:32 AM
#32
2013 31' Classic
billings
, Montana
All the new diesels have excellent an engine brake...th lining on the trailer brake shoes is only .20 thick....
05-24-2021, 10:57 AM
#33
1987 29' Sovereign
Flagstaff
Keep in mind the appellation is Appalachian, not to be confused with apparition.
05-25-2021, 10:15 AM
#34
Fort Lauderdale
How much is ‘a lot’?
Hi
Not a lot, just enough to keep control. You don’t want the TT pushing you. I rather don’t wear neither brakes down, but it beats having an accident.
The article on snub braking is very good, yet it does not address brakes on the trailer, only on the TV…
Now, on a worst case scenario, when you see the TT swinging from one side to the other and your knuckles are white, I read here somewhere that to straighten the convoy you simultaneously apply brakes to the TT while actually ‘accelerating’, stepping on the gas: that should stretch out, align TT and TV. sounds reasonable.
05-25-2021, 11:07 AM
#35
Little falls
, New York
The brakes certainly should not be used. You know. Why would they come as standard equipment (required by LAW) and actually used.
Well that’s Kind of like an airstream itself. It will immediately self destruct if it is actually removed from under cover and enjoyed.
I see your point. Heavens to Betsy. It might get scratched.
05-25-2021, 11:17 AM
#36
Salem
, Oregon
Originally Posted by GCinSC2
Glenn,
OK I'll kick it off. Got brakes?
A pre trip verification that all trailer brakes are up to their assignments? Don't assume, prove it.
Gary
Hi, my most recent brake inspection showed that I was stopping with three trailer brakes. This is the third time in 16 years that I found a broken brake wire.
Keep your down hill speed low and controllable. It seems to me that most loss of control accidents are caused from going down hill, too fast, on a curve, and passing a truck.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
