Old 03-07-2021, 06:57 AM   #21
Half a Rivet Short
Carlisle , Pennsylvania
Hi
All of the WD hitches get a bit excited going over very uneven terrain or through sharp turns. Forward or reverse is not the issue. They are designed to do their thing when you are at normal "highway" angles between the trailer and TV. Releasing the springs when you are going to do something odd reduces strain on the hitch, on the TV, and on the trailer. With most designs it also reduces the amount of noise involved. You have enough horsepower in the TV to execute the maneuver ( no matter how nutty) without any noticeable "feedback" from the hitch.
Indeed strain outside the normal limits, is going to translate to increased wear and tear. Very extreme situations may damage things ( think pulling into a 45 degree slope ....).
Old 03-07-2021, 07:11 AM   #22
1996 25' Excella
Tillsonburg , Ontario
I have damaged two antisway bars backing up. The front coupler gets pinched
JCW
JCWDCW is offline   Reply With Quote
Old 03-07-2021, 07:46 AM   #23
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
JCW
? Add on Friction or WD bars
And the fault there is?
I went over the ppp 'limit' once when backing, my BAD. Lesson learned.
FWIW...still don't remove the bars, just pay more attention and back slower.😂
Obrigado, ť hora de descansar.
Tahawus
Old 03-07-2021, 08:55 AM   #24
SailorSam205's Avatar
South East , Michigan
interesting comments about backing into sites. On a trip last year, I had a guy come over as I was setting up camp to check out my hitch. He had watched me back in and said to his wife, as I was doing it, "he isn't going to make it, he didn't allow enough room for the turn". I nailed it on my first try (I guess I'm getting better). He had never seen a Propride hitch and seemed impressed by it.
My understanding is that the Propride and Hensley hitches allow for tighter turns going forward and reverse than do other hitches due to the geometry the hitch provides. Going forward, a trailer will more closely match the track of the TV.
Al
2017 29' SOB, 2019 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 03-07-2021, 09:16 AM   #25
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
Equalizer square bar twisted while backing up. Thats why I moved to the Blue OX several years ago...the chain prevents the torsion that occures with the Equalizer in a tight manuver backing up; this is a better design, than the square bars...few articles on this also. The taper bars provide more downward sway tension/ control while towing also. IMHO of course...
2017 28' Twin Flying Cloud
Old 03-07-2021, 09:28 AM   #26
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
Dunedin , Florida
I have the Eazlift WD and sway bar set up by Andy at CanAm. I do loosen or remove the sway bar when backing in so it doesn't get broken/bent/make noise. The set up is easy and since the bars are rounded they do not get bent. And as for weight, the bars are relatively lightweight and easy to hook up. The hitch is heavier but most are. Been using them for 5 years now.
"All good things are wild and free."Henry David Thoreau
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 03-10-2021, 03:44 PM   #27
Birmingham , Alabama
Can you tell me why you did not like the Hensley - I am buying a new Classic 30 in May and the dealer has recommended Blue Ox. There is a lot to consider and any insight you can share would be great
Lovecamping is offline   Reply With Quote
Old 03-10-2021, 03:52 PM   #28
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
ProPride!
sheriff1 is offline   Reply With Quote
Old 03-10-2021, 06:01 PM   #29
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
I have a Blue Ox, but, I'm towing a 20'..... For a 30', I'd consider a ProPride (if you go that route, go w/ ProPride over Hensley, as it is the more updated design).
What's your tow vehicle?
-Leslie
LNBright is offline   Reply With Quote
Old 03-10-2021, 06:43 PM   #30
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Originally Posted by JMynes View Post
I like my Equal-I-Zer.
Weight distribution and sway control all in one. Hitching and un hitching are so easy even I can do it.
Same for us ... now three AS that we have used the same hitch! We did have to change the drop once ... dealer exchanged / traded it for us at no cost. One nice feature on the EQ brand is that it is not vehicle specific ... we have used it on an F150, Ram 3/4, Chev 3/4, Chev 1/2, and now back to a Ford Expy.
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 03-12-2021, 10:39 AM   #31
aaryno's Avatar
1972 31' Sovereign
Tucson , AZ
sounds like hensley and pro pride are where itís at but itís outside the budget for now so iím going with an integrated 4-point wdh with sway control. i appreciate the great discussion!
aaryno is offline   Reply With Quote
Old 03-12-2021, 02:11 PM   #32
2019 22' Sport
Carlsbad , California
Nobody mentioned Andersen? Solves most problems raised, and should work well with a vintage trailer size/weight
Prettygood is offline   Reply With Quote
Old 03-12-2021, 06:36 PM   #33
1986 31' Sovereign
Miami , Florida
I mentioned it in post #2
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 03-12-2021, 09:18 PM   #34
2019 22' Sport
I stand corrected, there was a brief mention of Andersen in post 2
Weight distribution hitch and/or sway control chaeha Towing, Tow Vehicles & Hitches 14 10-11-2018 04:52 PM
Sway control and weight distribution for a 50's Flying Cloud ? GaŽl Towing, Tow Vehicles & Hitches 0 02-26-2018 01:10 PM
Weight Distribution and Sway Control on Vintage Airstream 64Lincoln Hitches, Couplers & Balls 16 10-23-2015 08:03 AM
sway control and weight distribution for 22' safari? JeffVH Hitches, Couplers & Balls 12 01-29-2009 05:21 PM
I need sway control AND weight distribution? TBKP's Overlander Hitches, Couplers & Balls 19 07-03-2003 08:54 AM
