01-12-2019, 07:24 AM
2021 27' Globetrotter
Dallas
Sway bar for Basecamp X
I recently purchased a 2019 Basecamp X. I am considering adding a sway bar, so I am interested in your opinions and experiences on whether it would be helpful, needed, not required, or ...
Thank you in advance for response.
01-12-2019, 08:36 AM
2007 27' International CCD FB
San Diego
Hi sswanson15. Any particular reason you're looking to add a sway bar?
Or are you talking about an anti-sway hitch?
01-12-2019, 08:45 AM
Retired.
, At Large
Anti-sway weight distribution hitch is not available that is compatible with the basecamp. Sway bar only.
01-12-2019, 08:51 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard!! 🥂👍
Yes...do it. Light, single axle...the BCamp will benefit.👍
Im done with adulting
Lets go find Bigfoot.
01-12-2019, 09:27 AM
San Diego
Ah. Nomenclature difference.
You're looking for an anti-sway hitch, without WD.
An anti-sway bar typically refers to a component that is fitted to car axles which help it from rolling/leaning in corners.
01-12-2019, 09:37 AM
1994 30' Excella
Kiefer
, Oklahoma
Andersen Hitch
This hitch is a lite weight anti-sway hitch with load distribution. It works really well with an Airstream Base Camp.
01-12-2019, 10:17 AM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
He did post in Running gear, axles, wheels....and not in hitches?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
01-12-2019, 10:18 AM
1991 25' Excella
Santa Ynez
Do you torpedo the propane tank cover?
Will Rogers
Alan
01-12-2019, 10:30 AM
Fayetteville
, Arkansas
We have towed trailers over the years and believe sway bars add to the safety equation. We always rig for sway bars.
01-12-2019, 10:56 AM
2022 25' Flying Cloud
NCR
, Ontario
get an easy-lift WD and sway bar
i would not us an As and a TV without both
01-12-2019, 01:34 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Unless towing with a Fiat 500, is this a concern with such a short and lightweight trailer?
01-12-2019, 02:03 PM
Retired.
, At Large
Then I guess you will never tow a Basecamp. I will repeat myself, for those that didn't read all the posts before commenting:
There is no WD hitch available for Basecamp trailers. Sway bay only. There is no place to install snap up brackets, as the trailer is manufactured.
01-12-2019, 03:32 PM
2022 20' Basecamp
1968 17' Caravel
Los Osos
Anti-sway bar. You'll never need one until you do.
01-13-2019, 06:38 AM
1994 30' Excella
Kiefer
, Oklahoma
Originally Posted by overlander63
My neighbor has a Basecamp & a car trailer.
He uses his Andersen on both trailers.
He told me, the Andersen works well.
01-13-2019, 02:09 PM
1999 35' Cutter Diesel Bus w/slide
Fullerton
Just a quick note that the Equalizer is a good option giving you both load distribution and sway control, it is mountable on the Basecamp.
01-13-2019, 04:59 PM
1994 30' Excella
Kiefer
, Oklahoma
Picture this!
01-13-2019, 05:41 PM
San Diego
Nice Flatingair. Definitely looks to be compatible with WD bars.
I think the Anderson would be an incredible pairing with the Basecamp-X. Because of it's lightweight and easy to setup nature. But more importantly, because of it's adjustable WD/sway control feature. As a Basecamp-X is suited for off-road use, being able to lesson the WD/sway tension is huge IMO. Something that many hitches including the one pictured there and my Equilizer cannot do on the fly.
I've used Anderson and Equalizer hitches before. Again, I think the Anderson to be perfectly suited for this.
01-13-2019, 06:00 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
As mentioned by others, if the BaseCamp coupler as the same as those used on other Airstreams the Anderson WD system is not compatible.
Ray B.
