11-16-2016, 03:32 PM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
Reese Trunion WD System
We are evaluating moving up to a 23D; it has a Reese trunion WD system . Our TV (08 Expedition Limited w/ class III tow package) will require a WD system to accommodate the increased hitch weight. If you have a Reese system, what is your experience....easy to set-up and effective? WD would be new to us as we don't use one on our 19' Bambi.
11-16-2016, 04:07 PM
Oswego
Reese dual cam is my back up system. I ran it for a couple years prior to getting my Hensley. Over the years, I have also used an EQ, as well as a draw-tite. Reese is my #2 favorite.
-Rich-
11-16-2016, 05:09 PM
2004 25' Classic
Prescott
Have been using the Reese Duel Cam set up for the past 9 yrs. with no problems what so ever. I did change out the 1,000 lbs. (to rough on some roads) for 800 ones and that made a big difference in smoothness (even though our tongue weight is just over 1,000 lbs.). Once you get it dialed in, you're good to go. I did mark each bar RT and Left to always use the correct bar. I have been very happy using this set up
Julia & Bob
W/ Deedee & Boo
AIR #30685
11-16-2016, 05:32 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
There is more than one type of Reese hitch that has trunnions. I've used the trunnion system for the last 25+ years, on several different Airstream trailers. I think it is a good system, stronger than those bent bars.
I have had the snap up bracket type with a separate friction sway control. I use this system on both my 25' and my 34' now. I like this system.
I have also had the dual cam system. I did not like it.
Alan
11-16-2016, 08:01 PM
2021 16' Bambi
2021 22' Bambi
North Port
The only WD hitch I've ever used has been Reese systems. I have both the old style and new style dual cam with built in sway control and they do exactly what they are supposed to do. I can attest to the system keeping the trailer in a straight line, or putting it back into a straight line. When I set up the new hitch on my 30' Bunk my adjustment was slightly off, which actually caused the trailer to sway. This wasn't noticed upon my initial adjustment, but once I got on the interstate and up to speed you could feel the trailer being pulled from one side to the other. A final adjustment of the saddles completely cured the sway.
Its a nice simple system and can quickly and easily be hooked up.
11-16-2016, 08:06 PM
2013 31' Classic
billings
, Montana
We have a Reese duel cam , it does a good job with our 31' classic, I like it better than the high dollar hitch that was on our old classic...
11-17-2016, 05:08 AM
Mantua
, Ohio
Isn't a class 3 receiver only rated at 6000 pounds trailer weight?You might be overloaded.
11-17-2016, 05:32 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Class III with WD
According to Reese Class III with weight distribution design capabilities is rated at 1,000 lbs tongue weight and 10,000 Gross Trailer Weight.
Ray B.
11-17-2016, 05:47 AM
Mantua
, Ohio
Okay.
11-17-2016, 06:54 AM
1976 31' Sovereign
Oswego
I started using Reese dual cam hitch 39 yrs. ago, still using original purchase. Would not consider any other brand or type of hitch
11-17-2016, 07:02 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I have used the Reese Dual Cam Straight Line hitch for 10 years now on my 25'. I like the hitch. If it comes with the trailer you certainly ought to try it. It will take some reading of the manual and a little adjusting to get the right weight transfer and adjustment. Will be an easy afternoon and you will learn a lot about WD and hitches that you need to know no matter what hitch you end up with. I do not find that the Reese is sensitive to adjustment. Once I got mine set up it never has needed adjustment. That may be because I pull with a 2500 that is not the least bit sensitive to how much load is in it.
11-17-2016, 09:33 AM
2008 19' Bambi
Bandera
Thanks to all for your responses. My current tongue weight limit is 600. Hitch weight of the 23D is 720. My TV specs indicate I can go to 910 with a WD system, so I should be OK, though I would never be able to carry a full load of water. Thanks again!
11-17-2016, 02:22 PM
2015 27' Flying Cloud
Caledonia
, Michigan
A basic Reese Trunion system does not include Dual-Cams. If you don't have the cams, add them as these are needed to control sway. The basic system is only for weight distribution.
Here is a link to the cams:
https://www.etrailer.com/Weight-Dist...e/RP26002.html
11-17-2016, 07:52 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
I have a Reese Dual Cam hitch for sale in Ontario.
It's been used three times and didn't work for me. So..
I went back to the EZE hitch with the Friction bars that Andy installed. It works for me.
The Reese kit is complete and ready to install.
Cost me $1000 plus tax. Make me a reasonable offer.
11-17-2016, 08:23 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
I use the trunion system described above on my '97 31' classic. Simple, easy to set up and hitching up is a snap.(excuse the pun)
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
11-17-2016, 10:44 PM
2005 30' Classic
Box Elder
, SD
We use the Reese Strait Line WD hitch with dual cam sway control with 1,000# bars. We're on our 3rd coach, and it has served us well. We had to use a shank with a deeper drop to level the coach, but once dialed in (it took several iterations) it works great. In addition to Rancho shocks, we have Firestone 500# air bags to add stiffness to our Armada's suspension.
