Old 07-24-2021, 02:39 PM   #1
2021 23' International
P , California
Receiver, shank slop...
Mercedes 2021 GLE 53 SUV AMG with tow package mated to 2021 AS 23FB International. Seems to be a bit too much slop in the receiver causing banging sounds at low speed little bumps. Is this normal? If not, how to tighten things up? Some kind of shim?
The adventure begins when things stop going as planned.
https://youtu.be/Y3Gqm6__860
viking1 is offline   Reply With Quote
Old 07-24-2021, 02:59 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I added three wide flat welds on both sides and bottom of the shank ground to fit.
ID:	400278   Click image for larger version
Tahawus
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 07-24-2021, 03:47 PM   #3
1966 22' Safari
Fredericksburg , Texas
We had slop on our F150 shank. I added a shank stabilizer from Tractor Supply. It took care of the movement. But, we keep the shank and ball on the truck all the time. If you donít, Robert Crossí fix would be better. Good luck
Bubba L is offline   Reply With Quote
Old 07-24-2021, 05:34 PM   #4
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I use a fancy clamp that looks like a u-bolt that pulls up on the shank. I use it with my standard hitch.
I had my WDH shank welded like Robert’s and it is quite snug now. I also moved the hitch pin hole to shorten up the shank projection. Clunking is almost non-existent now.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 07-24-2021, 06:17 PM   #5
2018 30' Flying Cloud
Anchorage , Alaska
I would be concerned that your tongue weight is too low and/or you donít have enough weight distribution torque if itís rattling around on small bumps.
AKNate is offline   Reply With Quote
Old 07-24-2021, 06:38 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Have you measured the dimensions of the receiver hitch under your Mercedes? I wonder if it is built to the international metric units. Also measure accurately the ball mount that you are using. Maybe it is the standard 2 square.
The ball mounts are certainly "slip fit" into the receiver, but it seems like the amount of clearance your photo shows is excessive. Certainly welding and grinding would close the gap.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 07-24-2021, 06:39 PM   #7
Airlock's Avatar
2019 16' Sport
Vista , California
Hitch stabilizer
I bought a hitch stabilizer on Amazon (trailer hitch stabilizer). Search on that term on Amazon and you will see a lot of choices. Works well and doesn't cost much.
Gary
Airlock is offline   Reply With Quote
F250/350 3 inch Hitch and 3 inch Shank SLOP Ray Eklund Hitches, Couplers & Balls 7 06-04-2020 05:21 PM
Receiver Slop or Play Sadie9285 Hitches, Couplers & Balls 13 12-01-2019 04:50 AM
Equalizer Hitch: SLOP of Shank into Receiver Ray Eklund Hitches, Couplers & Balls 98 02-08-2017 07:30 AM
'69 Caravel door lock slop Caddyshack Doors & Locks 3 11-07-2012 08:54 PM
Need a Weight Dist. Shank with more drop!!! JeepinAudiophile Hitches, Couplers & Balls 11 07-19-2004 12:30 PM
