08-21-2020, 10:35 AM
#61
2019 22' Sport
Port Coquitlam
, British Columbia
Further to what Shiny16 is talking about.
In addition to the tongue weight changes, the cargo capacity of the 16 is so tight and good portion of it will go to the bikes and rack. doesn't leave much for food or clothes or water.
Peter.
"Live Long and Prosper \\//" - Spock
08-22-2020, 07:17 AM
#62
2019 27' International
Rogers
, Arkansas
You Are So Right!
Originally Posted by pstetsonc
Nobody recommends anything these days, the world is too litigious. The Kuat bike rack has a very ingenious system that by turning a knob it takes all of the slack out of the hitch coupling. The Bikes rack does not move around with their system. Other older bike racks that I have had are much looser and the bikes are very poorly secured. With the Kuat, nothing is moving or bouncing at the back of the Bambi. To answer the next post, yes i do have a rear view camera.
Trying to get a straight answer from a manufacturer anymore is like pulling teeth. Typically they won't give you their honest opinion in case of true stupidity on the users end, most everyone is afraid of litigation and can't or won't answer a simple question with a simple answer.
08-22-2020, 08:26 AM
#63
2013 19' Flying Cloud
Loveland
Thank you again to everyone that took the time to reply to my post. This Forum is very helpful to e newbie like me. I've decided to have a front receiver hitch installed next week on my 2017 Honda Ridgeline TV. Then I'll probably buy a 2 bike Kuat rack that can handle my wife's 49 pound E bike and my 35 lb townie bike. My mountain bike and road bike go on top of my Leer topper shell. I'll probably get some sort of cover to protect the front bikes from bugs. I'll post some pictures when I get this all sorted out. Thanks again. John
08-22-2020, 01:08 PM
#64
2016 16' Sport
Miami
You can blame it on the lawyers and might be partially correct. Google RV approved bike racks. Several come up. I guess those manufacturers are more confident in their attorneys.
08-22-2020, 01:34 PM
#65
2022 20' Basecamp
1968 17' Caravel
Los Osos
You might want to check with Honda to see how adding 125 pounds plus of receiver, carrier and bikes plus to the front of your Ridgeline will affect handling and cooling, its it safe?
08-22-2020, 02:14 PM
#66
2019 22' Sport
Port Coquitlam
, British Columbia
With mine, I am planning to add 2 short outriggers to my cover and then put bike carriers on each side. I have to outboard of the headache rack angled plate so I can still put the kayaks up there.
That is one of my next projects after my hitch modifications.
The cover is really tough and will support the bike outriggers. This will make loading the bikes easy as they will sit at the bed cover height.
Peter.
08-22-2020, 02:51 PM
#67
2019 16' Sport
Tallahassee
, FLORIDA
I put mine inside
I own a 2012 Bambi 16' Sport that has no rear bumper. Is it possible/advisable to mount a receiver hitch so that I can attach a bicycle rack to the rear of my Airstream? I'd be carrying a max of two bicycles that weighed 100 lbs. total. Thanks for any advice. John
I have the same dilemma, and just took a trip where I put a 63lb folding e-bike, a kids mtn bike, and a adult mtn bike bike inside. Put thick cardboard down on the floor and several towels covering certain points,and some bungee cords holding things together and it worked out just fine. I took the front wheels off two of the mtn bikes and this helped. The majority of the weight was low down over the axle. The other option I'm considering for the mountain bikes is roof racks for the SUV. I'm towing with a BMW X3. Hope this helps.
#68
2022 25' Flying Cloud
2018 16' Sport
1962 22' Safari
Corvallis
, Oregon
I have a front hitch on my Tundra for the bike rack, works great. I did cut the rack down so the bike (a tandem) sits right at the hood level, still have plenty of ground clearance and makes the view better. Make sure your rack sticks out far enough to clear the front bumper, my hitch receiver sits back some (by the tow rings) so you need 12-18 inches to get out in front of the bumper. You look like you have a big cattle pusher on the rig, but loading and unloading is easy and I cable/lock the bikes to the rig frame. Good luck, Rick
Rick & Paula LaMont
2022 Flying Cloud 25’ FBQ
WBCCI #7944
08-22-2020, 03:04 PM
#69
2017 20' Flying Cloud
Williamson County
We have a rack mounted on the front of our 20'. Works fine. I will mention that we only take our old sturdy bicycles camping, they are good for sub 50 mile rides and strong enough for off road trails, importantly they have no real value (maybe $30 each) so we do not worry about them getting stolen. Maintained well, lubed and greased and new tubes every year but we do not worry about surface rust and scratches. Our good bikes would travel in the Airstream if we ever felt the need to take them camping.
2018 GMC Canyon CCSB V6 Mallet Supercharger
2006 Chevrolet CCSB 2500HD 6.6T LBZ
08-23-2020, 05:50 AM
#70
2008 19' Safari SE
Cary
, North Carolina
I had a front rack on my Ram 2500. After buying the hitch, installing, getting the rack, and then modifying so it would sit lower, I found that it blocked my vision driving down the highway and decided not to use it. At night it was impossible to drive as the glare from the headlights off the bikes decreased my vision.
You may want to Do some measuring and simulating to make sure the outcome is what you want before investing the money in a hitch.
Good luck.
08-23-2020, 04:44 PM
#71
Church Point
, NSW
It is certainly possible, but equally inadvisable. Adding weight to the extreme rear of a trailer towed via an overhung will decrease its stability. It may cause that trailer to sway.
The technical explanation is that it increaes the so-called Moment Arm.
Instead, carry them on a rack at the front of trailer, or in/on the towing vehicle.
Collyn
The problem is not so much what people do not know, it's what they think they know that simply is not true.
08-07-2021, 11:57 AM
#72
Powell Butte
, Oregon
Photos and rack info
Originally Posted by Aard
I’m an Airstream newbee about to take possession of what looks like a beautiful 3029 16R. The vehicle has a Stagman bicycle rack mounted in the receiver hitch that is rated to hold two ebikes st 70 each. I can provide closeup photos if anyone wants them - we will get Ms. Bambi in a few days and could post thereafter. Neither the previous owners nor we ever intended to use our ebikes (we have both) - adds about 50-60 lbs more to the tongue weight over regular bikes. Any things about traveling with ebike see should care sbout....beyond security I mean?
Hi, do you have photos and info on the ebike rack, how it s configured and mounted? Thanks!
08-08-2021, 06:04 AM
#73
2014 25' FB Flying Cloud
Tyler
I put a receiver hitch on the back of my 25’ Airstream. I found out that the interaction of the trailer going over the road caused the bicycles to bounce up and down and caused minor skin damage to the trailer. I believe the bikes must be tied at two points to the trailer to prevent this bouncing. Put your bikes on the rack and have someone drive the trailer while you drive behind it and you will see what I mean. That arrangement cost me one bike, a unused receiver hitch, damage to my trailer plus time and money. Go buy a proven solution to haul bikes on the back of a Airstream.
08-08-2021, 09:55 AM
#74
Loveland
Thanks. I added a receiver hitch to the front of my TV and it works great. John
08-08-2021, 09:58 AM
#75
Loveland
I gave up on the idea of a rear mounted bicycle rack on my 16' AS and had a hitch receiver installed on the front of my TV (2017 Honda Ridgeline AWD) and it works great. I just don't drive at night.
08-08-2021, 09:59 AM
#76
Loveland
Send me your email address and Ill send you some photos. John
08-09-2021, 07:04 AM
#77
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Interesting! This is the first case I’ve heard about. Could you share details, and possibly pictures of the skin damage? I have the rear camera on (occasionally) and can see the bouncing. My biggest fear was the handle bar of the closest bike going through the back window. I watch especially when we hit big humps/bumps on the highway. We survived going through Petrified Forest National site this winter. Horrendous roads, and I was hurrying. I’d like to know where to look for skin damage. I already watch the front storage compartment edges, looking for frame separation in the front.
Thanks!
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
08-10-2021, 05:53 AM
#78
Loveland
Send me your email address and I’ll send you some photos. John
08-10-2021, 06:09 AM
#79
Loveland
Photos of my front mount bike rack
Hopefully this reply has photos attached.
