Old 04-19-2021, 07:41 AM   #1
2014 27' FB International
Richmond , Virginia
ProPride 3P Hitch - Propane Cover
We just purchased our new ProPride 3P hitch and decided to install it over the weekend. No real problems with the exception of the propane tank cover. I decided to use spacers under the propane tank tray which raised the tray 3/8”. Problem now is the propane cover doesn’t sit properly on the frame. Has anyone encountered this and found a solution?
2014 International 27' FT
notfartogo is offline   Reply With Quote
Old 04-19-2021, 08:41 AM   #2
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I left the mounting plate on the frame, drilled through the plate and u-bolted through it. I also moved the tanks as far forward as possible and my front cargo hatch clears the towers.
2012 27FB
sheriff1 is offline   Reply With Quote
Old 04-19-2021, 09:40 AM   #3
2017 28' International
Jim Falls , Wisconsin
I used spacers when I installed mine. No big deal. The LP cover doesn't really need to sit right on the frame. It simply needs to be tight enough so that your LP tanks don't move around. And mine don't. You should be good.
My hatch is in the rear. If I had a front hatch I would go with the newer towers that make it possible to open the hatch.
Daquenzer is offline   Reply With Quote
Old 04-19-2021, 09:48 AM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Same as Daquenzer. My tank cover floats a little. No biggie because the tanks keep it snug.
wulfraat is offline   Reply With Quote
Old 04-20-2021, 09:14 AM   #5
2018 30' Flying Cloud
Fort Myers , Florida
I used spacers as well. It drove me nuts having the tank cover floating and I felt like it was more secure with it sitting on frame. I marked the notches in the bracket that holds the LP tanks together and ground them further up, same amount as spacer. Now the tank cover sits back on the A frame again...problem solved.
Wheelestate is offline   Reply With Quote
Old 04-20-2021, 09:21 AM   #6
Sherrif1- I thought about doing this but it seemed like the u bolt would interfere with the bottom of the LP tanks. Have you had any issues with the tanks sitting over the u bolts?
Old 04-20-2021, 09:43 AM   #7
2019 25' Flying Cloud
North-Central , Florida
ProPride’s new Jack towers
Has anyone tried the new ProPride WD jacks (v2) on a FC25 FBTwin? I’m wondering if the new-style jacks will allow the forward hatch to FULLY open.
The legacy jacks have to be mounted such that they preclude opening the hatch from opening more than about 1/2-2/3 of the way.
djbar is offline   Reply With Quote
Old 04-20-2021, 09:54 AM   #8
pjshier's Avatar
2017 27' International
Wasilla , Alaska
u-bolts clear the tanks
in this spring maintenance photo, you can barely make out where the circular bottom of the tank clears the u-bolt. The paint scratch on the u-bolt is from removing and replacing the tank, not from rubbing against the bottom of the fuel cylinder of the tank.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is online now   Reply With Quote
Old 04-20-2021, 10:47 AM   #9
phoenix491's Avatar
1965 20' Globetrotter
2015 25' FB Flying Cloud
Keller , Texas
The rear of my propane cover sits on top of the little guides/arms near the base of each tower, which I didn't love at first ... But now, I don't even notice it. Everything is held down well with the large wing nut at the top of the tank assembly (plus an additional nut that I installed below that, just to ensure everything was tight). My only option appeared to be to notch out the sides of the propane cover, since the towers were in the best location per the PP manual (and the location of my LP lines on the frame), or just deal with it. So, I chose to deal with it.
If anything, I like that the small gap at the bottom of the tank cover gives my power cord a bit more room to move while underway. Now, if the cord were just an inch or two longer, everything would be perfect ...
phoenix491 is offline   Reply With Quote
Old 04-20-2021, 02:24 PM   #10
Senior Member
sheriff1's Avatar
Sparks , Nevada
No problem.
Old 04-20-2021, 02:49 PM   #11
2020 30' International
Denver, NC , North Carolina
I just installed a ProPride P3. I placed spacers under the propane tank base. In raising the base the cover was also lifted. I decided to replace the center rod with a longer (had to shorten a 3 ft) threaded rod from Lowes. Cover sits a little higher and rest in the back on the jacking tower bases. Cover is stable and is not impacted by jack towers.
bbcubed53 is offline   Reply With Quote
Old 04-21-2021, 07:06 AM   #12
Richmond , Virginia
pjshier - I like this option the best so far. I'm also thinking about modifying the LP Tank hold down bar by cutting 3/8 of an inch from the bottom and then cutting new V shaped grooves to hold the tanks down.
Old 04-22-2021, 04:16 PM   #13
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
2015 20' Flying Cloud
2021 25' Globetrotter
small city outside a big one , south of most, north of some
Are the bolts (screws?) on the tank base long enough to put 4 washers under the plate and still use them?
Or did you have to replace the bolt (screw?).
If so what size did you need?
I will have to do this in a campground and would like to know as I would prefer to take everything with me that I need.
renderit is offline   Reply With Quote
Old 04-23-2021, 06:10 AM   #14
Richmond , Virginia
The bolts were long enough but I felt better buying 4 new bolts 1/4" longer than the original bolts.
I used 1/4"-20 x 1-1/2 hex head bolts with a 5/8" nut under the pan opposite the U bolts. The 5/8" nut was the same hight (3/8") as the U bolt. The nut was easier to work with as apposed to washers.
I also ended up cutting 3/8" into the tank hold down bar which now allows the tank cover to sit fully on the frame.
Old 04-23-2021, 07:57 AM   #15
I used a large (not sure of size bolt) as the spacers under the stand same as notfartogo. The bolts size (at least on my AS) was a 5/16 -18. I bought a 1.5 inch stainless bolts because Lowes didn't have 1.25 inch stainless. I believe the original bolts are long enough to use with the spacers installed but they are not stainless.
Old 04-24-2021, 06:36 AM   #16
renderit's Avatar
2014 16' Sport
Thanks all!
Heading down to get bolts to throw in the "delivery must kit".
Propride hitch 3P Hitch-1400 Tsaywers Airstream Classifieds 0 06-01-2019 11:24 AM
Propride Install/Propane Tray? Hans627 Hitches, Couplers & Balls 19 10-03-2018 08:10 AM
electric hitch wiring crimped by Propane cover Anders79 Electrical - Systems, Generators, Batteries & Solar 8 12-11-2014 09:08 AM
