Old 03-15-2025, 11:33 AM   #1
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
Old Airstream hitch systems question
I am trying to find the maker of a hitch system that my father had on his first Airstream. TV was a 1963 Chrysler Imperial and trailer was a 1965 Caravel 17. The hitch was connected to the rear axle of the car and looked like a giant wishbone, and was supported on the rear bumper by chains attached to the wishbone system and a bracket on the bumper. I don't recall any bars going to the A frame of the trailer. Anyone have any recollection of this type of hitch. So far no luck on the internet!
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 03-15-2025, 11:48 AM   #2
2002 19' Bambi
Lafayette , California
Sounds like an early version of the Pullrite Hitch (no longer available).
Tim
Tim A. is offline   Reply With Quote
Old 03-17-2025, 05:27 PM   #3
1988 32' Excella
Robbinsville , New Jersey
Here is a 9 year old classified add for the Pullrite hitch, has pictures to see if it matches.
https://www.airstreamclassifieds.com...ford-van-92765
Old 03-17-2025, 06:28 PM   #4
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
Not even close!! There were 2 long arms that were attached to the rear axle close to the wheel hub, one on each side. I don't remember exactly, but I think the mounts stayed on the rear axle and the two arms connected somehow. The arms were attached to the ball assembly, which was below the rear bumper and held up by a bracket on the bumper and chains. It did not move like the Pull Rite does. Dad quit using it after he got his Reese hitch and it sat against the garage wall for years. The bars going to the axle were about the same size as the tension bars of today. Thanks for the info, but will still keep looking!
ACI #7394
Hensley Hitch
Old 03-18-2025, 10:11 AM   #5
1988 32' Excella
Found something similar to your description for a tractor.
https://www.tractorbynet.com/forums/...g-hitch.86693/
Old 03-18-2025, 12:15 PM   #6
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
That's a similar idea! Thank you!
ACI #7394
Hensley Hitch
Hitch/sway bar systems EddeO Hitches, Couplers & Balls 8 01-10-2024 08:34 AM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
old, I mean, vintage hitch systems wmarsha Towing, Tow Vehicles & Hitches 10 06-16-2012 11:12 AM
Braking systems question? zduke4x General Motorhome Topics 7 03-29-2004 08:05 PM
Question on Land Yacht systems. DaveJ Airstream Motorhome Forums 4 09-11-2003 06:52 PM
