Old 08-28-2018, 09:16 PM   #1
1970 23' Safari
2007 25' International CCD
Fort Worth , Texas
Need advice on new hitch
Just upgraded to a 2007 international 26 CCD from a 1970 safari 23. I've been using the equalizer hitch that came with old trailer which may be original. I have a '99 F250 CC and want to get a new hitch. Wondering if the blue ox is worth the money for the softer ride it claims for the trailer.
Trail Boss is offline   Reply With Quote
Old 08-28-2018, 10:02 PM   #2
PKI
PKI's Avatar
Walnut Creek , California
Yes - however, the PPP hitches are better at stopping sway. The BO needs to move slightly to build the spring tension differential that brings the coach back in line. The PPP holds the coach from moving. The better design does cost more, but it's worth the increase if you travel. If you stay close to home, the BO will be good enough. You may not even notice the BO wiggle from bow waves.
Note - the BO stores a lot of energy in the preload, so stay out of the release path for the spring bars, chains and wrench. Do not lose your grip on the breaker bar as you release the load. Replace the OEM wrench. It is too short and hard on the hands. Get a 1" 6pt impact socket and long handle breaker bar.
Note - also that the EQ has better ground clearance, because it tucks tighter to the tongue than the BO. It's not much of a problem with the ground clearance your 250 has, but don't be surprised if you drag a bit.
Good luck with the new lash-up. Pat
Old 08-28-2018, 10:53 PM   #3
StuartsDad's Avatar
2018 28' Flying Cloud
Fairfield , California
I went with the Blue Ox Sway Pro. Easy to hook and unhook, clean, except for grease on ball, seems to work as advertised. 28RB pulled by 2014 F250.
StuartsDad is offline   Reply With Quote
Need some hitch advice TavnAsh Hitches, Couplers & Balls 1 09-01-2013 08:26 PM
Need advice on best hitch jetjocky Hitches, Couplers & Balls 15 08-05-2011 07:19 PM
Need sway and hitch advice please! gypsymoth Hitches, Couplers & Balls 4 01-07-2008 12:39 PM
need advice on buying a hitch for a 1990 Wagon Vintage Mike Hitches, Couplers & Balls 1 08-21-2005 09:21 PM
Need Hitch Advice for New Owner khollister Hitches, Couplers & Balls 18 04-20-2005 02:13 PM
