Old 05-05-2021, 08:10 PM   #1
Wake forest , North Carolina
Moving tongue Jack and propane tanks back 5 inches
We are towing a 2019 flying cloud 23CB with a 2021 Defender 90.
All works great except the D90 spare tire is too close in a turn to the tongue jack. Looking at adding a new steel plate behind the current plate to remount the jack about 5 inches further back. This would also require adjusting the lid on the battery box to allow the propane tanks to also move back 5 inches.There is room in the box for a two inch height adjustment over about half the lid. All the metal work looks possible and doable to a local welding shop.
Anyone seen this done? Any cautions?
ThanksClick image for larger version
ID:	394972Click image for larger version
Jim Plyler is offline   Reply With Quote
Old 05-05-2021, 08:16 PM   #2
Paradise , Texas
Do you use a stabilizer type hitch? If so, the extra length of the stinger typically allows about 4to 5 inches of extra space
Crackerman is offline   Reply With Quote
Old 05-06-2021, 06:20 AM   #3
Thanks. I use a shocker impact hitch.
Old 05-06-2021, 07:29 AM   #4
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Do you have a weight distributing hitch or just the shocker? If you have the Shocker air equilizer model you can use a weight distributing hitch with sway control and add several inches to your TV- hitch distance. If all you are using is the Shocker, I would highly reccomend a proper WD hitch, with sway control. The post "Airstream overturned on highway" is good place to read what can happen without WD/Sway control. JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 05-06-2021, 10:15 AM   #5
Thanks. Land Rover advises not to use WD with the D90. I am considering adding Reese friction sway control although we have not had any stabilization problems. With or without addition of a Reese sway control bar the length of the ball mount and ball is the same.
Old 05-06-2021, 10:19 AM   #6
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
A ProPride or Henswill solve both the clearance issue and make you much safer at the same time. It will also save your rear tires and air suspension bags.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 05-06-2021, 10:48 AM   #7
Thanks. Reading up on Hensley now.
Old 05-07-2021, 06:30 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Changing to a Bulldog coupler will add a few inches also.
https://www.etrailer.com/A-Frame-Tra.../BD028499.html
Old 05-07-2021, 10:34 PM   #9
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Longer stinger ...
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 05-08-2021, 06:11 AM   #10
2021 27' Globetrotter
Malibu , California
We drive a Mercedes G-Wagon and had the same issue. Since I got the ProPride hitch the problem was solved. The way the ProPride turns and with its main unit giving you another foot in between both vehicles you will be fine.
CMHM is offline   Reply With Quote
Old 05-08-2021, 06:19 AM   #11
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
I just installed a Hensley, wish I had done it a year ago. Don’t spend too much time analyzing the difference between Hensley or Pro Pride. Other than color, they function the same way and are both amazing.
- Stewart
s1000pre is offline   Reply With Quote
Old 05-12-2021, 09:16 AM   #12
Gulliver72's Avatar
2015 25' FB Flying Cloud
Barnstable , Massachusetts
Put the tire on the roof of the Range Rover.
Gulliver72 is offline   Reply With Quote
Old 05-12-2021, 09:19 AM   #13
Luminous
LY007's Avatar
1983 27' Excella
Vesuvius , Virginia
Trade up for a vehicle with an internally stowed spare.
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
Old 05-13-2021, 04:58 PM   #14
2009 23' FB Flying Cloud
Laramie , Wy
IWe have a 23FB Flying Cloud and I have been dealing with the same tongue jack issue for years. The jack does not permit the tailgate on my Tundra to open flat which is a true pain since I travel with dogs in kennels in the bed all through bird season. I am about to address the issue by moving the propane tanks back as part of an upgrade to Lithium batteries. Since the new batteries are going to be installed under the bed inside the trailer, there will be ample room to move the propane tanks once the exterior battery box is gone. Looking forward to both the new battery/solar array and the ability to open the tailgate!
KMM
Keithann is offline   Reply With Quote
Old 05-13-2021, 05:52 PM   #15
SailorSam205's Avatar
South East , Michigan
Personally, I prefer the Propride. No drilling and they just came out with an improved WD jack.
Also, to the OP, both Hensley and Propride will will eliminate sway with zero WD required. My understanding is that most friction only sway devices will require that you release the friction before backing up and if you tow in wet weather, you will have reduced sway control.
Al
2017 29' SOB, 2019 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 05-13-2021, 08:34 PM   #16
2020 23' Flying Cloud
Cape Coral , Florida
Donít over think it!
We also tow a 23FB with a Tundra...get a longer stinger. No special replacement of your propane tanks and you can use the battery box for storing things like gloves, water hose, and the like. And, itís a whole lot cheaper, too. We got a longer stinger after our first trip with our old Caravelle. Donít over think it!
One Smith is offline   Reply With Quote
Old 05-14-2021, 07:23 AM   #17
Laramie , Wy
I started down the route of getting a longer stinger, but the "expert" at the RV shop warned me that every inch you add to the length of the stinger dramatically reduces tongue weight capacity of the TV. He pointed to a warning sign with a red lettered warning sign above the receiver hitch display. But it sounds like you're saying you've had no such trouble. How much did you extend the stinger?
KMM
Old 05-14-2021, 08:52 AM   #18
Mollysdad's Avatar
Berfor a major surgery, I'd look into some options.
First, the Tundra has a deep bed, therefore a taller tailgate. Good for cargo, bad for clearance.
How much do you need to gain to open the tailgate?
Will turning the jack head sideways give you the room?
Plan B is the longer shank. All solid shanks are interchangeable. The holes are 3/4" and spaced 1 1/4" so an Equalizer head will bolt right up to a Curt shank.
The problem is different manufacturers measure differently so a 16" shank from Equalizer might be different than a 16" shank from Reese. Look to video reviews from E-trailer because they put a tape measure next to the shank.
(Common sense says we'd measure from the pin hole to the head bolt holes, but it's not universal.)
Plan C would be a longer shank and drill a new pin hole, or have a machine shop do it. That way you can make it what you need rather than what some manufacturer thought you need.
My Tundra tailgate clears by 1/4" after turning the jack sideways.
I have an extra shank which I'll probably use to gain 2".
Old 05-14-2021, 10:36 AM   #19
dznf0g's Avatar
Oswego , Illinois
He's actually bass akwards. Every inch increase in the distance from trailer axle to receiver mouth DECREASES receiver weight. BUT....every inch increase from TV rear axle to ball increases sway propensity.
-Rich-
Old 05-14-2021, 11:45 AM   #20
Mollysdad's Avatar
Yes, and that's why I'd go the minimum necessary.
But, it's often done and although the 'book' says there's a change, most folks can't feel it.
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 09:34 AM
OEM Super Jack Parts (aka Tongue Jack) Michael_Wild Jacks, Stabilizers, Lifting and Leveling 18 12-19-2016 02:47 PM
Need some 12 inches backing plates and drums VeggieBullet Brakes & Brake Controllers 6 09-04-2014 07:34 AM
jack wheel caster 2 inches (in Uk or Europe) GaŽl Jacks, Stabilizers, Lifting and Leveling 4 08-08-2014 04:24 AM
