03-23-2025, 07:07 PM
2023 22' Caravel
Herndon
, Virginia
How to Raise Receiver 4 inches?
Need some advice.
We just had an awful incident. Driving to our first trip this year, we were on RT5 heading to Chickahominy River Park near Williamsburg VA and multiple deer ran from the trees. It was 2:30 and sunny day. The road is very skinny with no shoulders so the forest comes almost to the road. One of the deer hit the front passenger side of the F150 truck. Lights smashed, wheel well smashed, passenger front door smashed and will not open.
Parts were hitting tire but with help of local Camp Host, John, who just happened to be riding by on the Virginia Capital Trail, we pulled the fender from the wheel and able to limp to the park only 2 miles away, and unhitched the trailer.
Called USAA and F150 truck is at Caliber Collision. But now we need to get the trailer home.
Has anyone used an adapter to “raise” the receiver 3 to 4 inches??
Before getting the truck, we would tow 2023 Caravel 22FB with Acura MDX, keep it on level roads and keep tanks empty. But when we got the Ford F150 it was 4 inches higher so RV techs raised the Equalizer hitch about 4 inches.
If I tow trailer home with the Acura MDX, i need to adjust for this, either put Equalizer hitch back down where it was, or put something in the Acura receiver to raise it.
I see parts like this …
https://www.etrailer.com/Hitch-Adapt.../RM-058-4.html
Has anybody used these and can provide recommendations?
And any other suggestions are welcome. No one was hurt and my wife did a great job of just slowing down and not swerving or jack knifing but we are not sure what to do.
Appreciate any feedback or suggestions.
03-23-2025, 07:25 PM
1995 25' Excella
xxxxx
, xxxxxx
Drop shanks can be flipped over to raise the ball height.
03-23-2025, 08:53 PM
Moreland
, Georgia
Its only two bolts, move the hitch head down. Flip it over if necessary. Remount head, tighten bolts (@260 lb/ft)
Charles
'03 Ram 2500 CTD, 5.9L HO PacBrake six speed std cab long bed Leer top and 2008 BigfootRV 21RB trailer.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
03-23-2025, 09:25 PM
1988 32' Excella
Robbinsville
, New Jersey
Well the one you linked has a 400lb tongue weight limit, not sure if that is enough for your trailer. This one has a 1000lb tongue weight limit which would be better, problem is they both extend the ball much farther back which will hurt handling quite a bit.
https://www.etrailer.com/Hitch-Adapt...x/BLU34TR.html
They may not be rated for use with a weight distributing hitch.
Adjusting the hitch would be safer and cheaper.
Or you may be able to rent a truck to tow it home.
With a single axle trailer you may be able to tow it home with the tongue low without any problems. The single axle trailers don't need to be level like dual axle trailers as long as nothing drags, the biggest concern would probably be changing the amount of weight distribution. Maybe not ideal and wouldn't want to do it for thousands of miles.
03-24-2025, 04:59 AM
2023 22' Caravel
Herndon
, Virginia
Towing trailer home would be only time using old tow vehicle, and we would go back to using truck after it is fixed. It is 150 miles but 120 is on interstate. Thanks for your advice.
03-24-2025, 06:56 AM
2023 22' Caravel
Herndon
, Virginia
Picture of Damage
Wife’s F150
03-24-2025, 08:00 AM
2005 30' Classic
Kingston
How about a picture of your hitch that needs adjusting?
03-24-2025, 08:07 AM
2023 22' Caravel
Herndon
, Virginia
Equalizer hitch
03-24-2025, 08:48 AM
Tampa
Originally Posted by gokayaking
Equalizer hitch
I must be failing to understand the problem. The hole spacing on a shank is 1 1/4". So if you unbolt the head and move it up 4 holes, you gain 5". (allowing for the new tow vehicle to have more sag) 3 holes = 3 3/4".
What about brakes, 7 pin, etc?
Depending on distance I'd rent a truck to pull it home. Probably cheaper than tow service, and you'll know how it was treated.
03-24-2025, 09:07 AM
2019 25' Flying Cloud
Bullard,Lake Palestine
Truck
Borrow a truck
I always keep a supply of stimulant handy in case I see a snake ......which I also keep handy
03-24-2025, 09:22 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Equalizer hitch
Hi
If you need to, unbolt the hitch from the shank, rotate the shank 180 degrees (so the vertical part faces up rather than down). Then bolt the hitch back on the shank.
You will need a brake controller on the "other tow vehicle". Renting a truck that is set up for towing (yes, those do exist) probably is the easier approach.
03-24-2025, 11:46 AM
2007 16' International CCD
Somewhere
Terribly sorry for your misadventure. I suggest, under the circumstances, that you consider using secondary roads instead of a high speed, high traffic interstate. Won’t add much time for such a short drive.
03-24-2025, 02:21 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
VA Route 5 is about as secondary as you can get. Beautiful road for cruising.
Push come to shove, I can help tow you home.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
03-24-2025, 03:22 PM
2018 28' Flying Cloud
Chapin
, South Carolina
Since you used to tow with the MDX, I'll assume it still has the 7-pin and brake controller. Unbolt hitch head, flip shank over, reattach head at required height. Should be no problems.
Sorry for the damage to the truck and the trip. I know that area very well. First 45 years of my life were in Williamsburg. Skied the Chickahomany regularly.
03-24-2025, 09:54 PM
2018 27' Flying Cloud
INDIAN HARBOUR BEACH
Or, rent a truck
03-24-2025, 10:14 PM
2007 27' Safari FB SE
NW Oregon in a nice spot
, Oregon
Maybe I am stupid...but aren't there torque specs when connecting a hitch to a shank...something like 300 ft. pounds? Seems that is what I had to do when I changed mine out for a new hitch? At my age I can't come close to that with a wrench alone.
Basically saying just taking bolts off and connecting with hand tools may not be the best/safest solution?
Overly cautious me....as my son tells me regularly.
03-25-2025, 06:44 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
There really is no other answer here. If the bolts are an issue, head over to a local repair shop. They can do the swap around pretty quick and it should be cheap.
03-25-2025, 07:04 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I use an air wrench when I change the hitch adjustment. It certainly will get it tight enough for a short trip. The really tight nut is the ball and it does not seem like you need to remove the ball. I already had a compressor so buying a a cheap air wrench at Ace Hardware and a couple of sockets for the hitch head was not a big expense. You could take the hitch head to a shop and have it re set. Of course you will have to re set it when the truck is ready. Is paying the campground fee for a month and just leaving the trailer there a good option for you?
03-25-2025, 07:56 AM
Tampa
I use the scientific method. 300 ft/pounds means a force of 300 pounds is applied to a lever at a distance of 1 ft. Can you generate 300 ft. lbs with a breaker bar?
Remember, it's a ratio, so it's also 100 lbs at 3 ft. More doable.
Rotate the shank in the receiver so the breaker bar is rotating DOWN. (in case it slips) Then doesn't everyone carry a 3' section of pipe? I do. Slip it over the breaker bar and step on the end with a force of 100 lbs. Get the wife to stand on it.
Is it a perfect system? It's as accurate as an impact wrench. Probably better.
03-25-2025, 10:32 AM
2023 22' Caravel
Herndon
, Virginia
Thank you all for some much good advice. We got help from caliber collision and they were able to pull quarter panel and parts away from wheel so we can get trailer home with truck and get it repaired at home at a different caliber collision
Learned a lot. I do have torque wrench that goes up to 250 lbs so if I need to tow with mdx again I will try to undo bolts and flip shank. Was nervous doing that first time while away from help
But thank you again to everyone that commented. Going back home Thursday. And chickahominy river park is great
