Old 02-24-2020, 03:37 PM   #1
hopmonster's Avatar
1977 31' Sovereign
Fort Erie , Ontario-Canada
How to make hitching easier?
Hey All
Just pulled the ‘19 Sport 16 out of storage and heading to warmer climate tomorrow.
I almost forgot what a pain in the butt it is getting the hitch to seat properly. It usually takes a fair bit of back and forth with sudden braking to get it to seat so the clasp lock down and holes line up. I was hoping it would get easier over time but almost a year out and it’s still a struggle. I even cleaned out the hutch tongue and greased both pieces nicely.
I have a dealer installed Reese anti sway hitch with 2 5/16 ball.
Does anyone know of a trick to make this easier so I don’t scare the hell out of other campers when I’m trying to seat it?
Many thanks!
Mike
hopmonster is offline   Reply With Quote
Old 02-24-2020, 04:16 PM   #2
2015 25' FB Flying Cloud
Sandy , Utah
Originally Posted by hopmonster View Post
Hey All
Many thanks!
Mike
first I would spray up inside with WD or light oil and move the hitch latch a few times to lube everything up. What I have always done is leave the wheel chocks in place on the front of the trailer tires and gently give it a little tug forward after dropping it on the ball. That has always worked for me. *You should do this before you put any tension on the rigs with the WD hitch*. If you have the trailer set so that it cannot move it really only takes putting the tow vehicle in drive and you will here the hitch lock.
rocco52 is offline   Reply With Quote
Old 02-24-2020, 04:31 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Your coupler may need adjustment. It should sit down on the ball without difficulty. Try letting it down until it just seats and then lock it, don't pull the foot all the way up until it is locked.
There are multiple coupler types. The one on my 25 I would lift up and then lever down. The one on my 30 just slides fore and aft. Make sure you are operating yours correctly.
If you still can't couple it easily, it may need adjustment. Mine has a nylock nut that adjusts the tension. Back the nut out a half turn at a time. Once you get it where it couples easily, put a jack under the tongue while it is latched and make sure it won't come uncoupled. The coupler on my small utility trailer worked perfectly for years and then suddenly started coming uncoupled when hitting a bump. I had to tighten up the adjusting nut.
Al
Al, K5TAN and Missy, N4RGO
WBCCI 1322
Old 02-24-2020, 04:33 PM   #4
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
I usually align the ball slightly forward of the trailer coupler. Then as the coupler is lowered onto the ball, the coupler (and trailer) will move forward a fraction of an inch and fall into place (usually). I think the biggest issue is having the ball aligned too far back on the coupler, interfering with the locking mechanism.
If I run into that situation, I’ll put the Truck into drive and bump it forward with trailer wheel chocks in place. Easy does it. You shouldn’t have to slam anything around too hard.
I hope that helps.
KK4YZ is offline   Reply With Quote
Old 02-24-2020, 06:24 PM   #5
hopmonster's Avatar
1977 31' Sovereign
Thanks everyone! I’ll try the using the chocks to help in the morning, never tried that trick.The tongue seems to move freely in the coupler. I’m not sure if it can be adjusted but I’ll have a look through the manual. It’s just a simple WD Reese unit.
Mike H
2019 Sport
2018 Basecamp (traded in)
'77 Land Yacht (sold)
Old 02-24-2020, 07:29 PM   #6
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
You might want to check out this thread.
https://www.airforums.com/forums/f14...ks-203926.html
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 02-24-2020, 08:16 PM   #7
2004 22' Safari
Comox , British Columbia
The adjustment nut is on the trailer side under the coupler. Stick a mirror under the coupler and you will see it.
Northerngirl is offline   Reply With Quote
Old 02-25-2020, 06:18 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Hitch'n Rods👍
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."Molly Ivins
“Growing Old…being able to think about the things you can no longer remember.” RLC
"Never tow faster than your Guardian Angel can Fly"
Tahawus....🌥
Old 02-25-2020, 07:40 AM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Get a can of white lithium spray grease and *flood* the coupler. If it's not a total mess, you didn't use enough . It will clean out any road grit *and* act as a lube once the cleaning is done. (Yes, you should also put something thicker on the ball)
Once all the guck is off the coupler, take a close look at it in good light. If it's the one that came on the trailer back in 1977, it's lived a long life. Check for bent / broke bits. Take a look at somebody else's coupler to understand what should be there. That way you can also look for "missing" bits.
Assuming all that goes ok, then alignment as you hook up is indeed what's left on the list.
Old 02-25-2020, 10:01 AM   #10
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I installed a backup camera, and use one of these: https://www.harborfreight.com/magnet...kit-69778.html I can hitch up by myself, sometimes with only one try! I keep all the rub points greased up, and the coupler just slides right on
SuzyHomemakr is offline   Reply With Quote
Old 02-25-2020, 10:35 AM   #11
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I would first LUBE the receiver, in and around, on top top, don't be shy, LUBE the heck out of it. Also LUBE your ball. You will need to that several times if you have never LUBE your hitch before.
I promise you will sit better.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 02-25-2020, 10:50 AM   #12
1981 31' Excella II
New Market , Alabama
Most of the time the problem is with the ball being too far back on the hitch. This jams the lock between the ball and the socket. When I get close, I lower the trailer hitch about 1/2-1" below the ball and back up slowly till I hear it pop into the socket. You want to err on the side of the ball being a little too far forward and let gravity help you out a bit as you back up. Make sure everything is lubed well and also that the lock is not too tight. After you do this now lower the trailer hitch till you can lock it in.
Perry
Old 02-25-2020, 10:56 AM   #13
richw46's Avatar
Lexington , Kentucky
I bought a set of those from HFT on our first trip out. Great, simple device to match up without a backup camera. I keep forgetting them, however, especially when I'm picking up the AS from the storage lot. So now I keep some plastic cups in the back of my SUV and stick one on the hitch ball and keep the rear hatch open. I can line up the cup on the ball to the AS hitch without any problem.
I have used wax paper on the ball as a lubricant but I've gone back to a waterproof propeller shaft grease. When hooking up, after dropping the AS on the ball I just drop the SUV in gear (forward then reverse) and the latch drops so I can close it. Then I raise the tongue and set the WD spring arms.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Most of us don't know exactly what we want, but we're pretty sure we don't have it. -Alfred E. Neuman
richw46 is offline   Reply With Quote
Old 02-25-2020, 11:03 AM   #14
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
New coupler
Hi
Original post states the coupler is on a 2019 model...
BambiTex is offline   Reply With Quote
Old 02-25-2020, 02:44 PM   #15
hopmonster's Avatar
1977 31' Sovereign
Update...
Welp cleaned out coupler. Could see anything that can be adjusted in there. Just the tongue or path mechanism. Sprayed with lithium and worked the hasp up and down a hell of a lot. Tried reconnecting and still not seating. Did the chock trick and that wouldn’t seat it either. It gets almost there but the eye holes are off by a few Centimetres.
From new it’s never seated as easily as our Bascamp or old Landyacht.
I used to to have success with installing one of the sway bars and working it up and down to “wiggle” the tongue and ball interface..(that sounds a bit raunchy). When I did this it finally seated and the hasp dropped. So maybe that is the trick until I have the dealer examine if something is off.
We just got into WV for night on way to WDW and Key Largo so I’ll have a few more opportunities to attempt this..
Again thank you for the input and suggestions. See you all on the road.
Mike
Old 02-25-2020, 02:53 PM   #16
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Mike,
Can you identify the mfgr and mfgr number of the coupler? It might be stamped on it, somewhere.
How about trying a different ball, loose hold it in your hand. Coupler open, insert, try to latch. Feel fit/play etc then release and see how it feels.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 02-25-2020, 07:59 PM   #17
QC TORPEDO's Avatar
2017 25' Flying Cloud
Queen Creek , Arizona
Easy Hitching
Best, easiest way: Have the wife do it. Sit back and enjoy.
QC TORPEDO is offline   Reply With Quote
Old 02-25-2020, 10:04 PM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by KK4YZ View Post
I usually align the ball slightly forward of the trailer coupler.Then as the coupler is lowered onto the ball, the coupler (and trailer) will move forward a fraction of an inch and fall into place (usually). I think the biggest issue is having the ball aligned too far back on the coupler, interfering with the locking mechanism.
I hope that helps.
Hi, Bingo!
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-26-2020, 06:38 AM   #19
KK4YZ's Avatar
Hiawassee , Georgia
That’s a good thread although it deals mostly with difficulty unlatching the coupler from the ball. Whether you have the old style coupler or the new DEMCO coupler, the key is getting the coupler and ball in a “neutral” position. That is, with the coupler neither pushing down on the ball or pulling the ball up. You can usually tell when you’re at that point by watching it he ball & coupler as you raise or lower the jack. You will see slight relative movement between the ball and coupler at that point. Then it should be easy to lift the coupler latch.
I know this by struggling with it myself��
Old 02-26-2020, 06:49 AM   #20
Half a Rivet Short
Hi
Poster's "info" states they have a 1977.
A good example of why you need to update your info !!!!
new body lift off method...easier sawdawg1 Repairing/Replacing Floor &/or Frame 7 04-11-2014 07:27 PM
Making Interior Cabinets Easier to Use SRW General Interior Topics 0 05-25-2009 07:05 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
W/D hitch: un-hitching and hitching TennisMan Hitches, Couplers & Balls 6 05-11-2007 07:49 PM
Easier links to. . . maxandgeorgia Off Topic Forum 3 03-02-2007 10:58 AM
