Old 07-09-2020, 03:23 PM   #1
Portland , Oregon
Hitch Pin Locks?
I've read mixed reviews of the effectiveness (or not) of various brands and styles of Hitch Pin Locks.
While I recognize that a determined thief with the right tools can't be deterred from removing the Hitch Pin, I would like to have some level of comfort---even if it is just to deter the "casual" thief---with a locked Hitch Pin versus one that is not.
Any recommendations/suggestions?
Thank you.
Cheers,
Bryan
blacklab is offline   Reply With Quote
Old 07-09-2020, 03:27 PM   #2
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I have used Trimax receiver and hitch coupler locks for over 10 years now. I feel more secure knowing that someone could not just remove a pin when I am parked to cause mischief.
Steamy1 is offline   Reply With Quote
Old 07-09-2020, 03:49 PM   #3
dropped rivet in grass
2019 23' Flying Cloud
Tarzan , Texas
A long shank padlock will give pause to casual mischief-makers and opportunistic thieves.
Tall Grass is offline   Reply With Quote
Old 07-09-2020, 04:32 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I’ve used this one from Amazon on three different tow vehicles. Easy to use and secure: https://www.amazon.com/Locking-Hitch.../dp/B0716SFRLX
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 07-09-2020, 07:09 PM   #5
2017 23' Flying Cloud
Bartlett , Tennessee
I use a Bolt brand padlock and receiver lock. They use my tow vehicle's ignition key, so that is one less key to carry. They also make locks specifically for other towing applications that use your tow vehicle's key.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 07-09-2020, 08:26 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I drill out the hole in the hitch pin and use a padlock.
CRH is offline   Reply With Quote
Old 07-09-2020, 08:29 PM   #7
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Padlocks are EXTREMELY easy to defeat.
sheriff1 is offline   Reply With Quote
Old 07-09-2020, 09:00 PM   #8
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
good topic
Yeah I kinda worry about this as well. I had read on here, long time ago, about a locking hitch pin coming loose and a travel trailer passing a tow vehicle. Yeah, didn't end well. But it was supposedly a locking Hitch pin related issue. Maybe they just didn't get it locked completely?
I used to use Locking hitch pin exclusively and really never had any issues, but looking at the notch and small brass tumbler that locks it, well its small.
Granted the tension/force is pulling straight back and the lock just keeps the pin in place. yeah I don't know. So I threw the baby out with the bath water.
I have been using Grade eight bolts, with double washers on each side, two hex nuts, and a third hex lock nut with nylon insert.
I have my open end wrenches to get those nuts off, takes some time, but its solid. I know it can be stolen, battery powered grinders are readily available but grade 8 is strong steel. I keep an eye on it in the campground.
I know it isn't coming apart going down the highway ! I check it when we stop for breaks or fuel, food.
will be watching this thread. I'd like to know what everyone else uses and new ideas on hitch pins. I'd like a heavy duty lock for sure.
Best regards
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 07-09-2020, 09:02 PM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
A padlock is harder to defeat than a hitch pin clip. That is all that I am after.
Old 07-09-2020, 09:09 PM   #10
Boxite's Avatar
2008 22' Sport
ALL hitch locks are easy to defeat. They only make a locked hitch less attractive than an unlocked one.
But they ALL are relatively ineffective to a determined thief.... who simply has to ignore the hitch and use the safety-chains to pull the trailer to a place they can take their time to remove the lock.
I use a cheap hitch lock. I also use a hardened chain and lock thru both wheels which discourages wheel-theft.
But I recognize these devices only make my trailer less convenient than others nearby.... so I carry insurance.
Old 07-09-2020, 11:58 PM   #11
2014 27' Flying Cloud
Wenatchee , Washington
My Dad used to say that “a lock just keeps an honest man honest”.
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 07-10-2020, 05:10 AM   #12
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
If you are talking about a locking pin for the receiver, then I also recommend the BOLT as it can use your ignition key.
However, if you are talking about locking the coupler as others have said that won't stop a determined thief. A wheel 'boot' might be more effective.
I use a SPOT trace so that I can track the trailer if it is stolen.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 07-10-2020, 06:58 AM   #13
Portland , Oregon
Here is a Receiver Hitch Pin Lock that has gotten good reviews in multiple places.
Made in Canada.
Not inexpensive.
https://www.amazon.com/AMPLOCK-U-HLP.../dp/B00NUNFS6A
Cheers,
Bryan
Old 07-10-2020, 09:26 AM   #14
Mollysdad's Avatar
Yes.
First, I was shocked to see how easy it was to defeat the hitch pin lock. YouTube shows a guy with a 2' section of pipe that slips snugly over the lock. A quick pull sideways and the lock snaps off. Maybe 3 seconds.
However, like all things with locks the goal is to deter. I wanted a lock that was made in the US, so I bought the CT Johnson. After many miles it barely shows any finish wear.
I have a Tundra, and the receiver is so beefy that your standard pin lock is too short. I went with a lock for a 2.5" receiver, and added a couple hose washers so it stays snug. (Hose washers are 5/8"!!)
Old 07-21-2020, 06:26 AM   #15
2020 30’ Globetrotter
Plantation , Florida
Made in Canada.
Not inexpensive.
Cheers,
Bryan
Alright. So I purchased this lock. The all-stainless construction seems top notch and super solid. But I started looking for specs and found that AMP only rates this lock as a Class III, which is only 4000 lbs, not quite enough for our 8800lb 30' AS. I'm a little surprised given that all the Class V hitch pins (and much cheaper hitch locks) are the same 5/8" diameter with a similar shape.
For those that use hitch pin locks, do you remove them and replace with a simple bolt for towing? Am I missing something?
dlfphoto is offline   Reply With Quote
Old 07-21-2020, 07:13 AM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
No...the locks stay in 24/7/365 towing or not.
W/O a lock the "fancy" disappears.😂
BTW...I found with our 1st AS that the 'bent end' pins help with elongating the hitch pin hole. I wouldn't use the "AMP"
ID:	373515   Click image for larger version
Obrigado, é hora de descansar.
Tahawus
Hitch Locks, Trailer Locks MSL Towing, Tow Vehicles & Hitches 39 01-03-2021 06:27 PM
6-pin connector to AS 7-pin eugnicfrlie Towing, Tow Vehicles & Hitches 6 04-15-2009 10:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
Wheel Locks, coupler locks Toasty's Dad Hitches, Couplers & Balls 10 03-06-2008 11:55 PM
