Old 01-07-2019, 11:11 AM   #1
2012 30' International
Key Largo , Florida
Hitch ball receiver lock manufacturer
I recall reading on the forum about a highly rated heavy duty locking device to disable/block out the towing ball receiver on the trailer but cannot recall the brand: think the name may begin with the letter "A" . Can anyone point me in the right direction.
Martin R is offline   Reply With Quote
Old 01-07-2019, 03:26 PM   #2
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Not sure about the one you are asking about but this is the one I use and am very happy with it. It is a bit pricy, but it is as good a trailer tongue lock as I have seen.
https://www.provenlocks.com/
thewarden is offline   Reply With Quote
Old 01-07-2019, 04:25 PM   #3
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
I use a BOLT receiver pin lock.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 01-07-2019, 04:27 PM   #4
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
The Proven Industries lock previously mentioned is fantastic. I actually have basically a brand new one that I am sell. Bought it after I had my ProPride hitch taken off for awhile and wanted to protect the trailer. I put my ProPride hitch back on so can't use it and it does not fit my daughters trailer as it is Airstream specific.
Chuck
silverlabs is offline   Reply With Quote
Old 01-08-2019, 05:57 AM   #5
Key Largo , Florida
Thanks, the Proven lock looks good and solid. It is not the one I had read about before but does the same job.
Old 01-08-2019, 07:03 AM   #6
Sorry for the post about the BOLT pin lock, but I thought you asked about a receiver lock not a coupler lock.
Ray B.
Old 01-08-2019, 09:12 AM   #7
geo
2019 23' International
Vancouver , British Columbia
Have you checked out Coupler Vault Pro?
This is a different brand of coupler lock, but after watching several videos showing failed break-in attempts, I was instantly sold. It’s pretty easy to use.
Megahitch Lock Coupler Vault Pro:
https://megahitchlock.com
geo is offline   Reply With Quote
Old 01-08-2019, 09:18 AM   #8
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
You could also look at MegaHitch Lock Coupler Vault Pro which is quite good
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 01-08-2019, 09:28 AM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
While installing your hitch lock on the trailer, notice the two safety chains. Those can be used in lieu of the hitch ball to steal your trailer.
switz is online now   Reply With Quote
Old 01-08-2019, 09:37 AM   #10
jhrace
2016 27' Flying Cloud
2019 27' Globetrotter
Memphis , Tennessee
California Immobilizer
After checking many, this is the one. California Immobilizer made for Airstream, check out the tutorial.
http://immobilize.com
2016 27 FBQ FC
2016 Yukon Denali 6.2
Blue Ox
2019 Globetrotter / on order FEB del.
jhrace is offline   Reply With Quote
Old 01-08-2019, 10:40 AM   #11
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Built my own and as Lou stated. Remove the safety chains by adding a second hook.
http://www.airforums.com/forums/blog...tch-lock-2944/
http://www.airforums.com/forums/blog...h-lock-2-2945/
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 01-08-2019, 10:59 AM   #12
thewarden's Avatar
Removing the chains is a must for sure. In addition to the Proven Industries coupler lock, we are planning on also using a Denver boot. Bit of a belt and suspenders thing. If you are using the boot you also need a good set of wheel locks as well.
Old 01-08-2019, 11:04 AM   #13
thewarden's Avatar
I wish I had your fabrication skills! I don't believe you can buy a lock that is as heavy duty or as good looking. All I can say is Wow! Nice job!
Old 01-08-2019, 11:49 PM   #14
geo
Secure the coupler AND the chains
A very good point. In addition to the Coupler Vault, I also wrap the chains around the top of the coupler and lock them together underneath with a strong padlock. That should be sufficient to deter most casual thieves.
Yes, a Denver Boot is even more secure, but it’s also heavy and bulky. I would think it would be necessary only for long term storage in an unsecured area.
Old 01-10-2019, 04:47 AM   #15
Key Largo , Florida
Thanks for everyone's suggestions. I tracked down the name I was originally looking for "AMPLOCK". I had my new boat/trailer in mind and will go with a combo of the Coupler Vault and a denver boot type device. Should be enough to slow someone down while the security cams run.....As a side note, if anyone is using the Blink cameras, they are just releasing a beta amendment that enables the user to limit the field of vision that will trigger the camera which for me at least, is very useful for an out door camera prone to being triggered by off property motion.
Old 01-13-2019, 12:49 PM   #16
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
We got a Megahitchlock Coupler Vault Pro, but I was unhappy with the way it seems to barely fit on the coupler - dangling way down in front.
To supplement it got a Brahma wheel lock: http://brahmalock.com/
It's very secure, can't be yanked off sideways with a chain like some other wheel locks, and it comes with what I call the "Pie Plate" to cover the lug nuts or lug bolts. Without that someone can just unbolt the wheel....
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 01-13-2019, 02:01 PM   #17
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
we use three locks
  • a lock to prevent the latch from opening when driving and when parked to hold the 7 pin to prevent usage
  • a wheel lock when parked
  • a meg hitch ball lock
ID:	331610   Click image for larger version
waninae39 is offline   Reply With Quote
High Rise Hitch Ball compatible with equalizing hitch setup? PA BAMBI II Hitches, Couplers & Balls 3 05-23-2018 08:56 PM
Vintage TT ball receiver wave1957 Vintage Kin 15 09-19-2012 07:03 AM
Pro Series Hitch manufacturer????? crispyboy Hitches, Couplers & Balls 2 06-21-2007 12:58 AM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
glass dealer,manufacturer ALANSD Link Archive 0 09-02-2002 07:37 AM
