03-11-2023, 12:27 PM
2023 23' International
Calgary
, Alberta
Hitch Ball Lubricant
What lubricant is best for hitch balls? We are using a Blue Ox Sway Pro.
Anyone have experience with this product?
03-11-2023, 12:48 PM
Kensington
, Maryland
Keep your money! Any solid lubricant will do and most of us have something on the shelf. Wheel bearing grease if fine for instance.
Wipe the hitch with a clean rag, grease holds dirt, than reapply as needed.
If you want to get fancy....resist!!!
03-11-2023, 01:03 PM
2013 27' FB International
El Dorado Hills
I like the Equal-i-zer brand grease, mainly because its packaged into a compact spill proof toothpaste tube like container. Most grease is the spray type, which splatters everywhere, or the tub with the snap on cover that seems to snap off while on the road and spill everywhere.
https://www.amazon.com/Equal-i-zer-9.../dp/B007HRGZDK
03-11-2023, 01:26 PM
Tampa
I've used this for years, a little on the ball and it comes apart like butter.
03-11-2023, 01:37 PM
2020 25' Globetrotter
Santa Rosa
High quality, water resistant. I also use this on the contact points of my Equalizer hitch. I transferred the contents to a sturdy plastic container with a twist on lid so no chance of it coming off while traveling.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
03-11-2023, 01:42 PM
2022 27' Globetrotter
DALLAS
, TX
I spray this on the ball each time before I hook up the trailer. Works great. Not messy once it dries and it only takes a couple of seconds to dry.
CRC® DRY GRAPHITE LUBE, 10 WT OZ
I don't know why the product image isn't loading ...
I think I fixed the image upload problem
03-11-2023, 02:25 PM
Bethlehem
, Pennsylvania
Wax lubricant
grease is great but it’s super messy! I got sick of getting grease on my pants so I switched to this for the hitch/receiver connection.
https://www.amazon.com/C-R-Laurence-...ps%2C84&sr=8-3
I cleaned the hitch with brake cleaner spray and simply rubbed on the wax lubricant. No more globby grease on my pants.
03-11-2023, 05:46 PM
2002 25' Safari
Dewey
I use this...
Richard
03-12-2023, 06:36 AM
1977 23' Safari
Niagara on the Lake
, Ontario
Any grease will work,
I keep a small plastic container of grease in the trailer. When I have extra grease from other jobs, like when pack bearings and have a big glob of grease leftover I add that to my trailer container.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
03-12-2023, 06:57 AM
2019 30' International
Pennsylvania
, Pennsylvania
Same here.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
03-12-2023, 07:46 AM
2022 25' Flying Cloud
Northern
, Ontario
I have used it as well as Blaster White Lithium Grease in a spray can. Both worked well. I like the fact that you can simply spray it on the hitch ball. Just a bit more conviennent in my opinion.
03-12-2023, 07:48 AM
Trailer Sold, Waving
2019 26' Flying Cloud
Stettler
, Alberta
Love it when the spray lubricant cap comes off and the nozzle gets depressed, lubricating everything within range, usually my tool/spare parts box. Tubed grease rocks.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
03-12-2023, 07:54 AM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Another satisfied user of Reese TowPower hitch ball lubricant. I have utilized the Reese products starting with my first travel trailer in 1980 when it was called On the Ball hitch ball lubricant. It has always come in a convenient package that is well sealed and easy to use. I do keep one of the hitch ball covers on my hitch when it isn't in use to help reduce the amount of dirt attracted to the lubricant.
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
03-12-2023, 08:03 AM
2017 16' Sport
N/A
, N/A
What are people using on ball of a Hensley installation, the ball is not accessible on a daily basis?
03-12-2023, 08:07 AM
1987 25' Sovereign
Fort Collins
Bought a tube of Yamalube 10 years ago. For off-road biking, so it's supposed to not pick up so much grit. I don't know if that's true, but still have over half the tube left and it's worked well. It is a grease, so I use a rubber glove to wipe it on -- and try to avoid the ball when walking by ...
Alumacoot
“We are confronted with insurmountable opportunities.”
03-12-2023, 08:29 AM
Evergreen
Originally Posted by azflycaster
I use this...
That’s the same one I used with my Airstream.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
03-12-2023, 08:43 AM
2008 22' Safari
Spicewood (W of Austin)
I don’t use anything at all now for almost 50 years of towing and never suffered failures of any kind….and no soiled pant-legs…. until I walked over to talk to another camper wanting help getting unhitched who had slobbered grease all over his hitch.
I did observe one camper who took an old plastic milk-jug and cut the bottom corner out…placing it over his hitch. He claimed it worked great.
Another used the bottom cut out of a water bottle … using another one each time he hitched-up.
03-12-2023, 08:51 AM
Evergreen
I started using hitch grease because I noticed some galling on my hitch ball after my first couple of trips. The key to avoiding a mess is a light application. I always put a rubber hitch ball cover on the ball after unhitching.
Dennis
Past:
Newmar Ventana 3715
03-12-2023, 09:12 AM
Tampa
Yes, grease is...greasy.
You all cover your hitch ball, right?
03-12-2023, 09:19 AM
DALLAS
, TX
I can no longer resist...
I usually keep my balls covered and generally don't lubricate them.
[emoji6][emoji1787]
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
