02-15-2025, 12:25 PM
thousand palms
Hensley Question: Spinning down the Jacks w/Drill?
I'm a new Hensley user. Ours has the spin-down jacks. I thought I could use a cordless on them, but my lightweight home utility cordless was not powerful enough. We therefore used a 1/2 ratchet, which is pretty tedious.
Just wondering if anyone does use a cordless, and if so, what model? I feel like it ought to be possible, but then again, I think most things are possible!
As always, I'm looking for "less work!"
Cheers to all,
Mark
02-15-2025, 02:51 PM
2022 33' Classic
Chesapeake
, Virginia
Mark,
I have a Propride, and I'm not familiar with your hitch jacks. From the web, they appear similar to mine. I am hesitant to use any tool other than a jack ratchet wrench on mine. I've read about damage occurring from using power tools.
https://hensleymfg.com/products/jack...wrench-3-4-7-8
I guess if you were brave, you could buy an electric impact wrench, and you could also use that to loosen lug nuts. Good luck!
Bill
02-15-2025, 03:28 PM
1994 30' Excella
alexandria
, Kentucky
I have used a Milwaukee 18v cordless drill for the past 14 years. Quick and simple. I also Use the drill for the stabalizers. Don’t use an impact driver. They can tear up a jack and are very noisy.
2009 Dodge 2500, 6 Speed Auto, CTD, Quad Cab, Short Bed, ARE cap, Bed Rug
Propride 3P Hitch
WBCCI # 3072 Airstreaming since 2008
02-15-2025, 04:42 PM
1988 32' Excella
Robbinsville
, New Jersey
Using the tongue jack to raise up the back of your TV will reduce the amount of force it takes to adjust the jacks dramatically. You would need a very strong drill to adjust the jacks all the way while the tongue jack is off the ground.
02-15-2025, 04:54 PM
thousand palms
Ahhhh.....yes, I see now. We essentially did a "dead lift!" It was a LOT of work to ratchet those bars several inches up. DUH!
One lesson at a time..........we're getting there.
Thanks Wazbro!
Cheers!
Mark
02-16-2025, 09:15 AM
Retired paddler
1993 29' Excella
Brighton
, Ontario
I’ve had our 29’ Excella for 18 years now and have always used only a speed wrench to extend and retract the jacks. I find it quick, efficient and quiet.
Cathy and Hans
1993 Excella 29' w/Hensley
2011 GMC SIerra 2500HD SLT
02-16-2025, 10:36 AM
2012 23' FB International
Woodstock
, Ontario
Have always used a drill to pull up the Hensley bars. You might have to raise the tongue with the jack to ease the work of the drill.
02-16-2025, 12:13 PM
1996 30' Limited
Colorado Springs
I have used a cheap harbor freight cordless for at least 10 years. I also use it to run down the stabilizers. No problems.
02-16-2025, 11:20 PM
2007 25' International CCD FB
Glen Allen
, Virginia
Hello
I use a Makita 18v (Non impact) for both the PP and the stabilizers. It works fine.
02-17-2025, 11:25 AM
thousand palms
Indeed. I also went for a $59 Harbor Frieght 20V drill. Seems really powerful! I think I will be happy with it.
Cheers,
Mark
02-23-2025, 09:32 AM
2005 34' Classic
tucson
I have the same set up, I use an 18v cordless. Mine is Dewalt but if you are going to get one just for the trailer I'd hit Harbor Freight and save $100.
02-23-2025, 11:08 AM
2021 25' Globetrotter
Kinnelon
, New Jersey
I use a 20v Dewalt but as stated above you should tighten the jacks before lowering the tongue jack. And vice versa when you release them.
02-23-2025, 05:53 PM
South East
, Michigan
I use a Dewalt drill/driver on my PP v1 jacks. I understand that using an impact driver on them has the possibility of breaking the shear pin. My understanding is that for PP's v2 jacks, that they make in-house, they can be run up with an impact driver.
With that said, I always set the jacks before pulling up the tongue jack. I've figured out my go to tension and always use the same setting. To quickly get to my preferred tension, each spring I run the jack all the way down, spray paint the inner tube with a non-black paint, then run the jack to my go-to setting and over paint with black gloss.
Al
2017 29' SOB, 2024 Platinum F-150 SCrew, ProPride
02-25-2025, 05:53 AM
2016 30' International
redondo beach
3/8 inch extended reach electric ratchet from Milwaukee.
We use it for everything. including the hitch jacks. Great tool.
The advantage over using a drill motor for us old guys is it saves your wrists. The final torque you do manually. There is no leverage with a drill motor.
Top shelf tool gets a lot of use. We also carry a 1/2 " drive standard socket wrench for a spare. Lots of options.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
02-25-2025, 01:18 PM
thousand palms
WOW! I never heard of an electric ratchet! I will look into that!
Thanks!
Mark
02-26-2025, 10:01 AM
redondo beach
Thanks!
Mark
Don't tell anybody but I have a 3/8" and a 1/4" that get a lot of use. They are like the older speed wrenches that ran on air pressure.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Stablizer jacks replacement with scissor jacks
spoonplug |
Jacks, Stabilizers, Lifting and Leveling |
21 |
01-01-2021 05:15 PM |
Goin' down, down, down...
Aironius |
Axles |
12 |
08-23-2014 08:09 AM |
BAL jacks and electric drill
idroba |
35 |
05-13-2013 03:19 PM |
Solar to drill or not to drill-HELP
Orson |
Electrical - Systems, Generators, Batteries & Solar |
2 |
08-24-2012 08:03 AM |
Drill Baby, Drill! Mount external antenna
TropicGuy |
Computers, Internet & Satellite |
5 |
04-17-2010 03:02 PM |
