07-26-2022, 10:51 AM
2002 30' Classic S/O
Fleming Island
Handle for ProPride Stinger
Some time ago, on some forum, I responded that I had built a handle for my ProPride stinger. Someone asked for pictures. Was it here? Was it you? If so please reply or PM me, I finally got a picture taken.
07-26-2022, 01:11 PM
2007 22' International CCD
Corona
Please go ahead and post it here!
Have Propride need handle…
07-26-2022, 01:41 PM
2009 25' FB International
2018 27' Globetrotter
Hanover
, Pennsylvania
I’d like to see it as well!
Thanks.
07-26-2022, 01:47 PM
2022 25' Flying Cloud
Tualatin
, Oregon
Here's my 2¢. I think it was a 5/8" threaded rod inside whatever tubing I could find. Photo also shows the stinger "caddy" made from some 2 x 4 to keep it manageable when not towing.
Steve
07-27-2022, 10:23 AM
1964 26' Overlander
Milton
, ON
I recently described my solution for a Hensley stinger in this post.
07-28-2022, 06:23 PM
Registered User
2016 28' International
Birmingham
, Alabama
I use a battery carrier from an auto parts store.
07-28-2022, 09:06 PM
Fleming Island
When I promised the picture I was responding to a post about using a battery carrier. I used one for my Equalizer and transferred it to my ProPride. It was a rubber strap with sheet metal ends that connected to pinch clamps on the battery posts. I took off the pinch clamps and bolted it to the hitches. After a while I noticed the sheet metal parts tearing. I'm glad I spotted that before it broke while I was carrying the hitch.
Here's a picture of my all metal version. I recently saw one made where the handle was a long bolt through a piece of PVC pipe. I like that better than mine, but I had already used the aluminum rod I had laying around.
07-29-2022, 12:40 AM
Hollis
, New Hampshire
I use this with a bolt thru one of the holes…cheap, works great! https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
07-29-2022, 06:56 AM
Registered User
Birmingham
, Alabama
I always check the metal clips that are connected to the stinger and always carry it so it is never over my feet. I just replaced it this year for $6.00
11-27-2022, 06:49 AM
2023 27' Globetrotter
Charlotte
, North Carolina
Originally Posted by OrangeCrush
Hey Orange,
I'm just getting back to post. Took delivery of our rig a couple weeks ago. Looking at your pictures, does using that hole for the handle interfere with the pivot of the stinger?
Our dealer installed our P3 prior to delivery of our Globetrotter and the stinger is configured in the highest position like yours.
11-27-2022, 10:00 AM
2017 25' Flying Cloud
Longmont
Originally Posted by AppFan
Hey Orange,
No problem for 2 reason. 1) Once everything is torqued down on the hitch bar there is nothing pivoting. 2) I used a nylon lock nut on the bolt for the handle so it is not tight and can pivot.
It has worked fine for me and makes moving and lifting onto the truck much easier. My only concern is the upper hitch bar bolt might abraid the handle fabric over time. For that reason I may re-do it with a longer bolt and more washers to get the handle eyelets out past the bolt heads.
11-27-2022, 11:38 AM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Originally Posted by reinergirl
Serves dual purpose as a carrying handle and a place to run the umbilical cord when traveling
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
04-22-2023, 06:21 PM
2022 27' Globetrotter
Seattle
Finally found an solution!
Great solutions posted earlier here. I tried a few but I barely have 2 inches of clearance for the tailgate to clear the PP Stinger.
However, I got these "BEADEN Ergonomic Pull up Handles Neutral Grip D Handle Cable Attachment Lifting Workout Handles Exercise Grips" https://www.amazon.com/gp/product/B0BLLPT7K9/.
Just loop the straps into one of the holes and you are good to go!
BogeyPro
Seattle, Wa
2022 Globetrotter 27' FBQ
2021 Ford F-150 XLT 4x2 Powerboost
06-06-2023, 10:26 PM
2019 25' International
Issaquah
Grab handle for PP hitch
I ordered this and the bolt is bigger than the eye loops. How did you get the bolt to fit through the grommets?
06-06-2023, 10:30 PM
Issaquah
I ordered this and the bolt does not fit through the grometts. How did you attach it to the hitch?
06-20-2023, 08:34 PM
Corona
Suggest using a smaller diameter bolt that fits through the grommets and hitch, then a couple fender washers to keep the bolt neatly in place. If it rattles in the holes in the hitch it matters not.
08-23-2023, 11:55 AM
2020 23' Flying Cloud
Portal
Please send me a shot also. Just got mine for our airstream and it is an issue getting it on. Workasplay@vtc.net
08-23-2023, 01:01 PM
South East
, Michigan
Sort of related, the Lay's brand Stax potato chip containers make a great cover for the singer. Being plastic, they hold up well and are the perfect size to slip on. If you put any lube on the stinger, it will cover it up.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
