07-31-2021, 10:18 PM
2016 16' Sport
Miami
Grand Cherokee L
Anyone have a new 2021 Grand Cherokee L ? I need to install a brake controller quickly. I can’t find a listing on Tekonsha’s site for the L. I’m thinking it’s the same as the Grand Cherokee.
07-31-2021, 10:45 PM
2016 16' Sport
Miami
I was looking at the plug and play cable for the Prodigy controller. If I order the one for a 2020 Grand Cherokee and it doesn’t do I just need to use the wire that comes with the car and splice it to the controller?
08-01-2021, 12:47 PM
1979 23' Safari
1954 29' Liner
Orange
Is the listing for the Durango the same as the Grand Cherokee? The Durango is a 3 row Grand Cherokee.
Just my personal opinion
08-01-2021, 03:38 PM
2016 16' Sport
Miami
Yes the 2021 Durango uses the same as the 2021 Grand Cherokee. So it’s probably the same as “L”. If not hopefully it will have a pigtail in the glove box when I pick it up on Wednesday morning.
09-23-2021, 12:24 AM
palo alto
Did that work out for you? Just curious, did your Grand Cherokee L not come with the towing package and 7-pin connector?
09-23-2021, 06:20 AM
2016 16' Sport
Miami
My L came with a factory hitch so it did include the 7 way pin connector. What was in question was a brake controller. If it helps anyone purchasing an L the prewired adapters offered by several manufacturers are the same as any Grand Cherokee 2015 to 2021. Most manufacturers will not have a parts number listed yet for the L.
09-23-2021, 06:52 AM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
OK just an old fart question.
What is with the adapter?
Is that just a plug that the tow vehicle manufacture already has installed in the vehicle?
All that I needed to do was connect 4 wires. Power, ground, stop light signal, and power to the trailer brakes.
What, if anything has changed?
Couldn't you just remove the what I assume to be a plastic adapter, extract the wires and determine which wire does what function, and just wire it in yourself?
09-23-2021, 10:22 AM
2016 16' Sport
Miami
Yes you could or you could just plug it in assuming you have correct adapter. Usually there is a plug under the dash somewhere in the harness. Other cars I’ve owned alway came with the female part of this connection that had bare wires or a pigtail. Most brake controller manufacturers offer a kit so there is no splicing.
