Old 01-15-2024, 08:24 AM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Front End Separation (FES)
I watched this video and thought it gives some insight to what causes this issue. Also how it can be corrected.
Old 01-15-2024, 08:30 AM   #2
2022 33' Classic
Chesapeake , Virginia
Thanks for posting. Has me researching Airsafe again. The video is great, but does not go deep enough down the rabbit hole. Airstream used to make a better frame, stopped doing so in the 80s. FES also happens to more than FB models. KYD puts a lot of miles on their rig.
I am considering going with an Airsafe, just need to control sway. I wonder how it compares to a Propride?
BGClassic is offline   Reply With Quote
Old 01-15-2024, 09:26 AM   #3
r3z
Los Angeles , California
This video also got me thinking if the investment in an air safe hitch is worth it.
To answer Bgclassic, I would assume you can use the air safe with the propride since it provides a cushion between your tow hitch and your chosen wdh or ball.
r3z is offline   Reply With Quote
Old 01-15-2024, 09:48 AM   #4
2022 33' Classic
That's a good idea, had not thought it was possible to combine the two. Thanks.
Old 01-15-2024, 09:54 AM   #5
Mollysdad's Avatar
enlightening.
Vinnie is the man.
KYD gets special treatment (free)
Old 01-15-2024, 11:00 AM   #6
2022 33' Classic
Per the company, you can not combine the two. "The Air Safe Hitch does not work with the ProPride system. The best choice for your information is the Class 6 or Class 7.
If you are using Weight Distribution System, then the tongue weight of our Receiver Air Hitches must be reduced by 25%, exampleÖ Class 4 Ė 900 tongue weight reduces to 675 lbs , Class 5 Ė 1,400 tongue weight reduces to 1,050 lbs, Class 6 Ė 2,000 lbs to 1,500 lbs."
Old 01-15-2024, 12:34 PM   #7
2019 22' Sport
High River , Alberta
When Inland Andy was still around, he often weighed in on the cause of front (and rear) separation. This is from a post in 2016:
"What causes the vibration ??
Excess rated tow vehicle.
Excess rated hitch bars.
Unbalanced running gear.
Bad rubber rods in the axle/axles.
Anyone or more of the above will cause cracks typically in the front of the shell and near the axles in the chassis.
That has been happening during my 50 years with Airstream."
Vinnie talks about "overigging"; perhaps he means bars that are too stiff.
I watched the video. The front hatch design is a compromise, and so is the attachment point at the front of the frame. However, aggravating factors that are evident are carrying bikes on a rack attached below the trailer bumper, using an Equal-i-zer hitch, and towing with a one ton truck.
Axles are probably fine in this case because the trailer is not that old, but if you have an axle with worn out/stiff rubber rods, there is no "spring". The suspension effectively bottoms out on minor bumps and transmits shock to the vehicle constantly. Andy also harped constantly on the need to have balanced tires on the trailer.
AlbertF is offline   Reply With Quote
Old 01-15-2024, 03:36 PM   #8
2022 33' Classic
Guilty, tow with a F350. I have balanced tires, and added Centramatics. I find it amazing that I read about an owner on here getting FES from towing with an Audi Q7.
Old 01-15-2024, 04:31 PM   #9
2023 25' Globetrotter
Ancient City , Florida
I recently added a shocker hitch. It doesnít have near the range of movement that the airsafe hitch does. But it does make a different. Expounding with the AirSafe derating info, it is easy to overload the Shocker. 1500lb bars are too much for it. In talking with an AS tech, he questioned the bars I had and recommended 800-1000lb bars.
I was surprised to see a large AS dealer had hitch parts by kit and didnít have different bars to test. Had to order bars to test. Or they were just stuck in the logic box.
G8trwood is offline   Reply With Quote
Old 01-21-2024, 09:22 AM   #10
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Interesting video. I watched it a few days ago. Anyone know if this fix is significantly different from what AS is doing in JC?
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19í Bambi, and (11) FC 23FB
GettinAway is offline   Reply With Quote
Old 01-21-2024, 11:30 AM   #11
GB
gblackburn's Avatar
2016 27' International
1997 34' Limited
Saint Cloud , Florida
following
Following FES Vinnie vs JC
Gil
"Everyone buys on emotion and justifies with logic.
That is why I own 2 Airstreams... I needed them."
gblackburn is offline   Reply With Quote
Old 01-21-2024, 11:32 AM   #12
GB
gblackburn's Avatar
1997 34' Limited
AirSafe vs Gen-Y The Boss
Has anyone compared the AirSafe to the Gen-Y The Boss.
Gil
Old 01-22-2024, 07:06 AM   #13
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
JC Fix is Similar
I just had my 2019 27'FBT repaired in JC last June. They did install a very similar brace as to what Vinnie did. Although mine is somewhat visible inside the front compartment.
I have about 5000 miles on this new fix with no sign of any issues up front. So, I would say the JC fix is acceptable and working as promised.
Mikebrady62 is online now   Reply With Quote
Old 01-22-2024, 07:42 AM   #14
GettinAway's Avatar
Wildwood , Missouri
Excellent! Iím going to have our local dealer look at my 25FBT. Itís got the dimples, and now it looks like a couple of rivets are pulling out. They have an excellent repair shop, and say they have repaired many (FES). I hope they use same techniques as JC.
2020 25GT FBT
Old 01-23-2024, 03:57 AM   #15
Rogers , Arkansas
If you are referring to Reliable in Springfield, I would be very cautious. I had a list of 5 small items and the FES issue to them and in 4 weeks only fixed 2 of the 5 properly, claiming they took care of all 5. The repair consultant claimed that he had never heard of the FES issue with AS. Months later when they finally said they had approval to fix the FES, there was no way I would let them touch it. So I made the trip to JC.
Old 01-23-2024, 07:42 AM   #16
GettinAway's Avatar
Wildwood , Missouri
Nope, I havenít been to the Springfield AS dealer. Iím going to the St Louis AS dealer, Bill Thomas. Iíve had very good results with their service department. Havenít had a lot of luck with the sales side due to higher pricing, but service is great. Had a tree limb drop on our 19í Bambi, the repair was flawless. They are just really busy, so I have to schedule visits pretty far in advance. Way easier than going to JC.
2020 25GT FBT
Old 01-24-2024, 04:58 AM   #17
Rogers , Arkansas
Good to Know
I'm glad you have had good luck there. That would be way more convenient for me rather than making the trip to JC.
Old 03-17-2024, 08:20 AM   #18
2024 28' Flying Cloud
Palos Heights , Illinois
Factory tour front end separation question asked
Hello forum.
I'm a few days out from a VIP factory tour which while on the line and inside some partially built units I addressed this issue with an engineer I was talking with.
While touring the inside of a 25' FB, I was shown in detail the supports that have been added on both sides of the front compartment doors. To me they looked like an either very heavy duty aluminum, but I was leaning towards maybe a stainless steel corner bracket, along with many ties down into the composite floor. I was told that Airstream came up with this reinforcement for the 2023 models, and going forward.
In my humble opinion as a tradesman for 31 years between the composite floor, and all the structural supports including the new corner brackets it appears that Airstream has addressed this potential problem in a very positive way going forward.
John
Sweet27 is offline   Reply With Quote
Old 03-17-2024, 10:08 AM   #19
2017 25' Flying Cloud
Jacksonville , Oregon
Originally Posted by Sweet27 View Post
Hello forum.
John
Well being a tradesman also & IMHO, not making the same mistake twice is expected. Going back fixing the mistakes you made is much more admirable and would be expected of any company worth it's salt.
AS put in sub par brackets that break, they did it year after year knowing they will break. And they will do nothing to help the thousands of there broken brackets that are out of warranty. We have a 5 year old trailer that now needs 4K repair costs to fix. Last week JC AS told my wife that that FES is a user problem not an AS problem caused by bottoming out the trailer or using a WDH. Our trailer has never been "bottomed" out the under carriage looks new, and we use a hitch that the AS dealer recommends and sells.
It's not even funny how JC customer service will lie about FES separation cause to avoid any responsibility. But have completely changed there brackets and repair FES under warranty, IMHO that is very slimy business.
2link2 is offline   Reply With Quote
Old 03-17-2024, 11:12 AM   #20
Woodinville , Washington
Hello forum.
John
I agree with you. Sounds like they fixed the problem properly with a well engineered solution. Thanks for sharing.
Kevin
2024.5 Globetrotter 27
2021 F150 Powerboost Limited
kmayer is offline   Reply With Quote
Takeaways from the front end separation (FES) saga Hermes Towing, Tow Vehicles & Hitches 124 06-28-2024 11:05 AM
Is this the dreaded "Front End Separation"? bdravet Community Polls 8 09-17-2021 04:51 AM
1992 Excella Front End Separation Repairs Re-Pete Ribs, Skins & Rivets 10 07-07-2020 02:33 PM
Front End Separation? Advice sought for front end skin repair. Re-Pete Ribs, Skins & Rivets 22 05-16-2020 10:08 PM
34' Front End Shell Separation oldfulltimer Repairing/Replacing Floor &/or Frame 6 04-06-2014 04:34 PM
