Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 03-06-2021, 06:54 PM   #1
2021 25' Globetrotter
Palm Coast , Florida
Equalizer wad hitch with GENY torsion flex WD shank
Has anyone tried the configuration of equalizer hitch with GEN Y torsion flex shank? Your thoughts please
CaptMojito is offline   Reply With Quote
Old 11-10-2021, 11:42 AM   #2
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Anyone ?
Old 11-11-2021, 05:11 AM   #3
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
Yes I have both on a 33 Classic. Very happy with both. Gen Y really improved (smoothed out) the ride. Only down side it is heavy (100lbs). So I leave it in the truck when on the road. Made a cradle for it out of harbor freight transmission jack to remove it when not traveling. Yes I have the front storage compartment and yes I had the notorious crinkles in the corners. Repaired out of warranty by JC. This was done before I got the Gen Y hitch. Some will blame the EQ WD set up. I don’t believe that is what caused the crinkles but it’s the natural flex point in the frame of the coach. I also don’t believe Airstream would repair so many under warranty if it was a result of the WD system folks are using. I would have liked to have the Gen Y from the start. I lot cheaper and better customer service than AirSafe. Just my thoughts and experiences since you asked.
JDG is offline   Reply With Quote
Old 11-11-2021, 06:45 AM   #4
2020 27' Globetrotter
Greater Salt Lake City , Utah
We purchased the Boss Torsion Flex 10K hitch with 2.5 in shank in August 2020 and have put 3,000+ miles on our 27 ft Globetrotter since. Love the smooth ride, much better. Our TV is a 2020 Ram 2500………although we have the Equalizer WD/Anti Sway, I haven’t used it.
No sway issues across Utah, Arizona, California, Nevada and Colorado travels.
It is heavy as noted. But worth it to me when traveling over rough roads.
Steve
ExploreUT is offline   Reply With Quote
Which Gen Y Torsion Flex pontzdav Towing, Tow Vehicles & Hitches 8 08-17-2021 08:14 PM
Anybody use the Gen-Y Torsion Weight Distribution Shank primepower Towing, Tow Vehicles & Hitches 7 07-03-2020 08:36 AM
320 ft/lbs torque for Equalizer hitch shank bolts? D44 Hitches, Couplers & Balls 33 09-17-2019 09:38 AM
Equalizer Hitch: SLOP of Shank into Receiver Ray Eklund Hitches, Couplers & Balls 98 02-08-2017 07:30 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
