Old 07-22-2023, 11:07 PM   #1
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Equalizer carnage on bottom
I flipped the hitch head today and wow was I shocked!
The gouges that are on both sides are cavernous .
Any advice as to what I can do other than buy a new hitch head
Laurence
LAWBC is online now   Reply With Quote
Old 07-23-2023, 12:27 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
You don't need to replace anything.
Hi, if the hitch runs dry they will do this. Take it all apart, turn it upside down, use a sander or grinder to remove the rough edges. These hitches will do this. Periodically these hitches need to be taken apart [remove the spring bar sockets] clean and re-grease these parts. Some people never take them apart. My Equal-I-zer hitch is 18 years old and still works great.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 07-23-2023, 07:36 AM   #3
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Looks Normal
Here are pictures of my equalizer after 18K miles. It doesn't look anything different from yours. Keep it clean. I regrease mine twice a year.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 07-23-2023, 07:43 AM   #4
Mollysdad's Avatar
Regularly, I grease the ball with white lithium grease.
At the same time I swing the bars far to the side and put a dab of grease on the upper and lower surfaces. As the bars move it distributes the grease.
The only place to avoid grease is on the "L" brackets, they need friction.
Old 07-23-2023, 07:44 AM   #5
kscherzi's Avatar
El Dorado Hills , California
Images: 24
That's normal wear. It looks ugly but isn't out of the ordinary. My hitch head looks the same, and close to 50k on it. The Equalizer hitch works by friction. Even when greased there's a lot of metal on metal friction by design and wear is expected. As the years go by, and wear continues you may need to add another washer to compensate.
I do a deep clean at least annually and often dab additional grease mid trip when over 1 or 2k miles, or it begins to get noisy.
kscherzi is offline   Reply With Quote
Old 07-23-2023, 12:19 PM   #6
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
I agree I put on the plastic gloves and clean off and lube the hitch areas every day of pulling. Another concern make sure you do no have to much weight distribution applied
Life is a Highway is offline   Reply With Quote
Old 07-30-2023, 02:33 PM   #7
Moreland , Georgia
https://www.equalizerhitch.com/manua...-owners-manual
Scroll down to regular maintenance and look at the illustration and the text.
This line comes from the section titled Spring Arm Setup... Never tow with loose socket bolts. Tighten socket bolts to a minimum of 60 ft-lbs torque before each towing session.
So, take it apart, buff out the roughest areas, clean it, regrease it and reassemble it and torque the bolts to 60 lb/ft and check before every tow.
My personal opinion is this is a horrible hitch, way too much work to initially adjust it, and way too much work to maintain it.
Charles
'03 Ram 2500 CTD, 5.9L HO PacBrake six speed std cab long bed Leer top and 2008 BigfootRV 21RB trailer.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 07-30-2023, 03:05 PM   #8
2019 30' International
Pennsylvania , Pennsylvania
I've been using the same Equalizer hitch for 7 years now. I don't know how many miles are on her, but I'd guess 75,000.
I just towed 7,000 miles the past two months with no issues. I did remove the sockets, clean them, clean the hitch head where the sockets ride, and regreased three times in those 7,000 miles.
I probably remove the sockets, clean 'em inside and out, clean the entire area where they ride, and regrease at least every thousand miles or so, give or take. I like to grease. Having run farm equipment, front end loaders, skid loaders, dump trucks and such, I've learned to grease stuff on a pretty regular basis.
Maybe I'm a bit overboard with stuff, but I clean up the bolts, washers, and nuts too. I'll make sure the threads are clean, don't want a bunch of grit and gunk there.
Then there's the socket opening where the bars go in. I'll put a small dab of grease on my finger and wipe it on the lower edge/corners of where the bars go in, so when I slide that bar in there, she's got some grease...not much, but enough to keep her quiet.
Ya, I grease my ball. I clean that thing off real good, then grease it. I also clean out up under the receiver, take a rag and clean that out of old grease, before hitchin' up.
I always torque the socket bolts to 60, some times 62, tried 65 but wasn't happy with that, believe it or not.
I also always run the sockets, and bars, on the same side of the hitch....never switch 'em to the other side.
I carry a tub of grease in the airstream, if y'all need any
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 07-30-2023, 03:44 PM   #9
2019 25' Flying Cloud
Sequim , Washington
Our Equalizer hitch has served us for nearly 100,000 miles with both our 23' and 25' FC in all kinds of conditions in 49 states & 9 provinces. I wipe off old grease and add new grease (Equalizer's brand) every time I hitch up. Last year I cleaned and repainted the hitch and bars. Equalizer sent me new labels at no charge so everything looks great. Of course, I check torque at least annually and change the cotter pins occasionally.
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 07-30-2023, 05:55 PM   #10
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Same here-18 yrs. Can’t even guess how many miles. Best hitch investment we ever made. A little lithium grease now/then…that’s it. Our Equalizer hitch has lived a rough life, and has never failed us.
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 07-30-2023, 06:19 PM   #11
Very nice! Now you have me thinkin' about paint
Old 07-31-2023, 07:36 AM   #12
2004 25' Safari
2006 31' Classic
2020 26' Flying Cloud
Lake Saint Louis , Missouri
Contact Equalizer. They have a lifetime warranty and might send you a new Hitch Head. They will have you submit a claim with pictures. Not sure about this condition, but I had a hitch head crack and they gave me a new one.
richarus is offline   Reply With Quote
More road carnage Lance M Tow Vehicles 48 08-14-2015 07:10 AM
Let the carnage begin!!!!! lewster Off Topic Forum 6 05-25-2010 08:41 PM
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 11:23 AM
seal the bottom edge trim pieces? CindyH Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 09:18 AM
