Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 11-07-2017, 02:12 AM   #1081
Cedartown , Georgia
I'll give that a try.
BBecker is offline   Reply With Quote
Old 11-16-2017, 07:26 PM   #1082
ksteve06's Avatar
mcdonough , Georgia
Do you think I need to transfer more weight to the front axle? Truck and trailer near perfectly level. Maybe add one more washer.
Equalizer hitch with 5 washers.
Truck only
Steer axle 5000
Drive axle 3680
WDH not engaged bars in bed of truck
Steer axle 4560
Drive axle 5120
Trailer axle 7900
WDH engaged
Steer axle 4720
Drive axle 4920
Trailer axle 7960
ksteve06 is offline   Reply With Quote
Old 11-17-2017, 03:35 AM   #1083
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Truck only
Steer axle 5000
Drive axle 3680
Steer axle 4560
Drive axle 5120
Trailer axle 7900
WDH engaged
Steer axle 4720
Drive axle 4920
Trailer axle 7960
My truck weighs 5,100 pounds..... I think that in every instance above your truck has enough weight on the front axle.
Old 11-18-2017, 05:45 AM   #1084
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Your rear axle may not have enough weight. The weight on the rear axle holds the tires in firm contact with the road to counteract any force coming from the trailer on an emergency stop or maneuver. Too little weight and the rear can break free of the road, and the trailer will jackknife.
The old guidance when setting up the hitch was to get equal squat on the trucks front and rear axles. This could lead to not enough weight on the rear. The new guidance says to bring the front squat, half-way back to where it was before the trailer tongue weight was applied.
Before this past summer travels, I reset my hitch using this guidance. I ended up with the front of the truck slightly higher (less than an inch) than unweighted, and the Airstream running almost level (1/4 inch down in front). On the scales, we were almost at the GAWR on the rear axle, but below the GAWR on the front and trailer axles. Both truck and Airstream were below their GVWR and the combination was well below the GCWR.
8,000 miles of safe, no worries, towing.
Randy
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
SilverCabin is offline   Reply With Quote
Old 11-29-2017, 05:55 PM   #1085
billrector's Avatar
2017 27' Flying Cloud
Fort Worth , Texas
Switching Trucks
Hi....I am moving from a Toyota Tundra to a Ford F-250. My AS is a 27' Flying Cloud FB. The trailer is in storage, so I am unable to get there to measure the hitch height.
I believe the F-250 receiver is higher than the Tundra. I put the Equalizer hitch into the receiver and the top of the ball is about 25" above the ground. My issue is that it looks like the hitch is set on the lowest setting, so how would I lower it? If I need to get something else, can you point me in the right direction? What height should the ball be?
billrector is offline   Reply With Quote
Old 11-29-2017, 06:59 PM   #1086
ksteve06's Avatar
mcdonough , Georgia
I have a F350 and got the shank model # 90-02-4300
Shank 2" shank, 12" long, 6" drop, 10" rise
Old 11-29-2017, 07:10 PM   #1087
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
You need to buy a hitch shank with more drop, the ball height for your flying cloud should be around 18 inches. Equalizer or etrailer should be able to help you select the right shank.--Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 11-30-2017, 03:39 PM   #1088
billrector's Avatar
Fort Worth , Texas
Do you know how high your receiver is on your truck? Equalizer had me measure to the top of the inside edge and I got 24" for my F-250. Based on an 18" AS height, Equalizer said I need a 90-02-4400 shank which is the longest they make. He said I'd still be 1" high at the truck?? He said the 90-02-4300 would leave me 4" high. Maybe the 4300 is safer but I know the truck will drop some when I have the trailer hooked up and the bed loaded with the wife's stuff
Confused!!!!
Old 11-30-2017, 03:59 PM   #1089
ksteve06's Avatar
mcdonough , Georgia
I’m not sure but I know that with the airstream level the height of coupler on our airstream was higher than what the book said. We have a 30ft Classic.Here is a picture of the truck and airstream with the 6” drop shank installed. [ATTACH]
Old 11-30-2017, 05:42 PM   #1090
billrector's Avatar
Fort Worth , Texas
Thanks for your help, this is all very confusing.
To add to the confusion, Equalizer has a "Shank Size" calculator on their website. I entered a ball height of 3", receiver height of 24" (stock F-250), and hitch height of 18" (based on airstream literature). The site comes back and tells me that they don't have a shank that will work for this setup. WHAT???
Am I the only person using an Equalizer hitch on stock F-250 with a Flying Cloud Airstream??
Bill
Old 12-01-2017, 11:48 AM   #1091
2014 27' FB International
Lewisville , Texas
I have a stock 2017 F250 and the receiver height is 24". My trailer should be the same as yours, a 2014 27FB International Serenity.
The EQ 4" drop shank was an inch or so too high on the lowest setting. I calculated the 6" drop would be about 3/4" too low. Until you actually set up a new shank and measure your trailer you will not know for sure.
I use an 18" long shank and EQ does not make a six inch drop in the 18" length. So I opted for this shank: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
The mounting holes on the Curt shank are 5/8" off of the EQ shank and that met my height problem right in the middle. My EQ head bottom bolt is mounted in the third hole from the bottom of the Curt shank.
You can see the measurements of the Curt shank on E-Trailer here:
https://www.etrailer.com/Accessories...rt/C17122.html
Please be advised the diagram on E-Trailer shows the drop part of the shank as being 10" long, that is incorrect, the holes measure 10" apart, the actual length of the drop part is 12", also notice the Curt is rated for 1500 pounds.
An 18" shank allows my tailgate to open with out hitting the trailer jack and allows for a little tighter turning radius.
Again, until your actually set up a new shank their is now way to tell for sure.
Good luck.
NO NOIZE is offline   Reply With Quote
Old 12-05-2017, 06:17 AM   #1092
billrector's Avatar
Fort Worth , Texas
Good luck.
Thanks for sending this. I already ordered the one that Equalizer recommended but I never thought about being able to lower the tailgate?? Now we're talking!! I like that idea. Ordering!
Old 12-05-2017, 08:14 AM   #1093
Mollysdad's Avatar
E-trailer's web site has very good videos in the "shank" section. They take each shank and put a tape measure on it so you can see what a 12" shank really measures. It seems there is no standard between manufacturers.
My shank is the standard Equalizer (I think) and is about 9" between the pin and hitch holes. I'd like to go to 12" for the tailgate, but not 18". So far I can't find one with that length and the correct drop. I considered drilling a second hole, but there's a welded gusset that prevents that.
Old 12-06-2017, 01:18 AM   #1094
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
12"s was too short and 18"s was too long.
Hi, With the standard Equal-I-zer shank, I couldn't fully open my tailgate. After lots of looking, I bought an 18" shank with the same drop. I then had a new hole drilled 2"s back and so it would completely go through my receiver, but not hit my spare tire, I had 1" cut off of the end. I also plugged the original pin hole so it couldn't be accidentally used.
Name:	18 inch shankA.jpg
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 12-06-2017, 04:51 AM   #1095
billrector's Avatar
Fort Worth , Texas
What's wrong with just using 18"? Why are you guys drilling (or thinking about it) new holes to make it shorter. Shorter may be a little stronger, but can't be much??
Bill
Old 12-06-2017, 09:26 AM   #1096
2007 27' International CCD FB
San Diego , California
^Because shorter is always better.
It comes back to wheelbase. Or specifically, wheelbase to rear overhang ratio. Using a longer stinger worsens this ratio. Such that stability, sway, and weight distribution are all negatively affected. Inches here matter.
I actually took my original stinger, and cut it down as short as possible (by ~3") for fitment on my LX570, in order to maximize stability on a relatively short wheelbase vehicle. Not that it needed it, but it's well known this is a critical dimension for enhanced stability.
pteck is offline   Reply With Quote
Old 12-06-2017, 09:38 AM   #1097
The most straightforward fix is to get a stinger with more drop.
Though I went a different direction with my setup. My tow vehicle has a relatively high hitch, along with larger 33.5" tires that lift the overall rig. This would have necessitated a 3" lower drop. I decided to lift the AS 3" with dexter lift blocks. I really disliked constantly dragging the trailer tail at gas stations and uneven transitions. The lifted AS fits with profile of my tow vehicle better this way as well.
Perfectly level now.
Old 12-06-2017, 10:46 PM   #1098
Salem , Oregon
Images: 18
Bill
Hi, for me, a 16" shank would work great, but I couldn't find with the other measurements that I needed.
Old 12-07-2017, 03:37 AM   #1099
Captain Hank's Avatar
Summerville , South Carolina
pteck,
I agree you have to be careful when towing the trailer across dips. However, raising the trailer raises the center of gravity. Have you noticed any instability in high winds or heavy trucks passing?
Captain Hank is offline   Reply With Quote
Old 12-07-2017, 08:10 AM   #1100
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
I also did the 3” lify on my 23D. No difference in towing. It’s an easy mod for the DYIer. And well worth it.
Troutboy
Troutboy is offline   Reply With Quote
