03-15-2020, 10:11 AM
2019 23' International
Portland
, Oregon
Equal-i-zer and Ram 1500
Finally replaced the 2005 Yukon XL with a 2020 RAM 1500. I didn't have time to wait for the dealer to be able to adjust the equal-i-zer for the new height, because I needed to move the trailer, so I went to a local place.
The RAM is 2" higher than the Yukon at the hitch unloaded. When the local RV place attached the trailer without any changes, the trailer and the truck both ended up level. They said it's all good and didn't charge me.
Issue is that the ride, especially with the fresh tank full, is rough and bouncy and really magnifies any bumps in the road.
The equal-i-zer manual says to start with the ball at a different height than where it's at with the trailer off and level, and then go through the whole procedure
Will going back and doing the procedure as in the manual be the right thing to do?
Not sure I can generate the torque required to tighten the bolts, so before I spend money I'd like to get an idea if re-doing it will help. If not, I guess it's an even worse problem.
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
03-15-2020, 12:01 PM
2019 25' Flying Cloud
Walnut Creek
I just went through this recently when we bought a 2019 RAM 2500. After observing the hitch installation done by the AS dealer and working with their technicians to make a few adjustments, I lost confidence in them and decided to do it myself.
I am glad I decided to go this way. I followed all the steps outlined in the Equalizer Manual and/or their YouTube video, and it was easy.
Yes, handling those big 1-1/8" shank bolts is difficult. You will need an Impact Wrench. I ordered this one from Amazon. For tightening of the bolts with the precise torque this can be used. I understand that these tools get a bit pricey, but in the end, the peace of mind you get is priceless.
You may need to make the adjustments a couple of times before you end up with a setting you like, but once you have the above tools in your toolbox, making those adjustments is a breeze.
2019 25FB Flying Cloud
2021 Range Rover HSE
2019 RAM 2500 Hemi
2012 Mercedes GL450
03-15-2020, 12:18 PM
Portland
, Oregon
thanks!
03-15-2020, 12:30 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
That 'Dealer' sux...
The Ram ball is 2" higher?
Yes...you need to get a lower stinger so he ball height unhitched and level is the same on both the TV & AS
Then the TW will lower the rear of the TV which you will restore with the weight distribution bars.
After doing so, you can return to the dealer and give them a much needed lesson.
I知 done with 疎dulting着Let痴 go find Bigfoot.
03-15-2020, 12:46 PM
Portland
, Oregon
Thanks. I already have the longer shank (long story). Guess I'll order a high-torque torque wrench and get on it.
03-15-2020, 01:15 PM
Portland
, Oregon
Thanks again.
After watching a few videos and doing some RTFM I guess I'm relieved that the problem is fixable and I probably didn't buy the wrong TV. Ordering the torque wrench and sockets. I already have an impact wrench.
03-19-2020, 03:31 PM
Portland
, Oregon
Funny it痴 almost right. I知 waiting for the torque wrench and socket to arrive and pass quarantine. As it is:
Truck only 36 5/8
Trailer without WD 36 1/2
Trailer with WS 36 3/8
That could be right in theory but I知 gonna guess (and hope) that geometry is a factor
03-19-2020, 03:43 PM
Portland
, Oregon
WD not WS
03-19-2020, 03:44 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Is the trailer level in that photo?
That IS the strangest looking "ball set-up" I've ever seen.Modified EQ?
Modified/ball welded?
It does need to be dropped quite a bit.
03-19-2020, 04:03 PM
2002 30' Classic S/O
Fleming Island
Originally Posted by leedav
Funny it’s almost right. I’m waiting for the torque wrench and socket to arrive and pass quarantine. As it is:
Truck only 36 5/8
That could be right in theory but I’m gonna guess (and hope) that geometry is a factor Attachment 363531
I'm confused by your numbers. First, I don't know where you are taking your measurement. Second, taking the truck without the trailer as a reference point, typically the front fenders will rise and the rear fenders will drop when the trailer without WD is hooked up. Then when WD is applied, the front will go back down and the rear will rise with the amounts depending on how much WD you crank in. The amount of "restoration" of the front axle desired varies depending on the instructions in your TV manual (if there are any) and individual desires. My F-150 squatted a lot and I restored the front height to the level it was without the trailer. With my Ram 2500 the front doesn't rise much and I can't restore it. Weighing indicates, however that my load is balanced and I am within my axle limits. After all that gets dialed in you can adjust the ball height to get the trailer level. With the WD dialed in properly, the truck should be level.
My personal opinion is that you do not want the hitch ball to be at the same height with and without the trailer. That would imply that the rear axle load is unchanged, which is typically lightly loaded with the truck empty. Both of my trucks were high in the rear when not loaded and there was way more capacity left on the rear axle than the front.
Al
添ou cannot reason someone out of a position they have not been reasoned into"
03-19-2020, 04:07 PM
Portland
, Oregon
[emoji631]
Those numbers are from the ground to the front fender as instructed in the EQ manual. I think that AS-NW just turned the shank upside down for the Yukon when we got the 23FB.
Current setup is unchanged because the local non AS dealer thought it didn稚 need anything.
The trailer is level.
I have the longer shank already. Just waiting for tools.
03-19-2020, 04:13 PM
Portland
, Oregon
Al
Not exactly at the same height to start but I知 thinking to follow the manual at first. As I recall you start out a lot closer that what I have here
03-19-2020, 04:14 PM
Portland
, Oregon
And the ride as it is is miserable.
03-21-2020, 03:08 PM
Portland
, Oregon
Update: the longer shank didn稚 drop it all the way to the level of the trailer. But I went ahead anyway and set it up according to the manual. The ride is enormously improved. When I take it into the dealer at the end of the month for the other work I値l just have them verify the set up but I知 thinking I nailed it
03-21-2020, 06:14 PM
2000 30' Excella
GTA
, Ontario
Pictures?
I thought the trailer tung height with the trailer level and the ball height should be close before hitching, then adding tension to "restore" that height and move the rear axle load to the front axle
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2020 GMC Denali 1500 Duramax 3.0l Diesel, ProPride3 WDH.
previous tow vehicles 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement, 2005 Ford F150 Lariat 5.4L
03-21-2020, 06:27 PM
2000 30' Excella
GTA
, Ontario
"The RAM is 2" higher than the Yukon at the hitch unloaded. When the local RV place attached the trailer without any changes, the trailer and the truck both ended up level. They said it's all good and didn't charge me."
So that would mean the hitch angle could be wrong ( as you know the height is off) but the tension is close to correct
See article here
https://www.canamrv.ca/blog/post/hit...l-mount-angle/
Can Am RV, has a lot of articles on setting up a weight distribution hitch and dialing it in
Cheers Ultra
03-21-2020, 08:12 PM
Portland
, Oregon
Originally Posted by Ultraclassic
Pictures?
That is true. I was able to drop it about an inch and a half. Not all I wanted but I think enough
03-25-2020, 10:06 AM
Tampa
I went to Harbor Freight and bought a couple of the longest breaker bars (24") in 1/2" drive. Then a couple 1 1/8" deep sockets and a 1 1/8" box end wrench (Those bolts are long!)
A 3' pipe will slip over the end of a breaker bar giving you super human torque. You can always flip the shank in the receiver so you're pushing down on the pipe to tighten. (just in case it slips, don't bash the tailgate!) Use your foot for leverage. Equalizer specs 320 ft/lbs. So 100 lbs at a bit over 3' gets you there. If you weigh 160 pounds, just stand on the end of the 2' breaker bar!
It's easier than you think, and the Equalizer is so adjustable, I guarantee you will make changes eventually no matter who installs the hitch!
All those wrenches ride under the back seat in my truck.
Looks pretty much like mine.
The Equalizer head is shaped like that.
Although the shank looks shorter than the standard shank. Hole spacing is 1 1/4" in the shank and it looks like you can only drop one hole.
Keep in mind that the washers on the 'rivet' determine the angle of the ball and thus the amount of pressure on the bars. More washers move more weight off the ball, vs. moving the head up or down a hole vs. moving the 'L' brackets up or down a hole.
03-25-2020, 11:53 AM
Lake George
Be chary of dealer advice. Yours may be an exception, but generally speaking they are clueless. At best! Just my opinion.
