Old 03-31-2020, 06:49 PM   #61
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Always lube and grease those balls :-)
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-19-2020, 09:48 AM   #62
2019 25' Flying Cloud
Houston , Texas
This is a follow up after our warranty service and getting the dealer's reply to our coupler issue. All they have done is lube the coupler. I believe that the rear securing mechanism was pretty tight and this is what caused my problem. While I had considerable experience with Bulldog couplers, I had none with the Atwood coupler that is on pre-2020 Airstreams. My difficulties have gotten better with use. The suggestions by several to have the ball at the front of the coupler helped and now works about half the time. What has always worked is closing the coupler lever (with it being not fully closed because the pin holes do not line up) and then jerking the truck forward with the trailer wheels chocked. After doing that, the coupler either closes or if you cycle it, it will close.
DCPAS is offline   Reply With Quote
Old 08-19-2020, 11:05 AM   #63
2021 20' Basecamp
North Royalton , Arizona
Hello,
If you’re using an X-chock between the tires when your hitching the coupler to the ball, the coupler lock would not line up unless you remove it. I used my other set of rubber chocks on the front and back of the tires and no problem since. Still a newbie (2nd yr. AIrstreaming) but learning. I found out when I was installing the Hensley hitch main body to the coupler.
Marvin
Melucy2airs is offline   Reply With Quote
Atwood coupler won't latch cwf Hitches, Couplers & Balls 6 08-07-2013 09:31 PM
coupler latch pin SPAN? (measurement please) Astroboy Hitches, Couplers & Balls 4 06-24-2010 10:11 PM
"coupler latch pin size" (help please) Astroboy Hitches, Couplers & Balls 9 06-22-2010 07:28 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Coupler latch when to replace? LI Pets Hitches, Couplers & Balls 6 10-10-2009 03:16 PM
