Old 11-14-2023, 03:37 PM   #1
1961 16' Bambi
2015 27' FB Eddie Bauer
San Diego , California
Coupler came off ball
Ball hitch came out of coupler when removing weight distribution torsion bars. Trailer was hitched up to truck. Used hitch jack to lift up truck to remove torsion bars on Blue Ox hitch. Ball popped out of the coupler.
Is my coupler broken or worn out? See photo. This is a 2015 27’ Eddie Bauer I bought used last year. Would like to see others coupler mechanism to compare wear on mine.
ID:	438754   Click image for larger version
sandiego is offline   Reply With Quote
Old 11-14-2023, 06:04 PM   #2
2017 25' International
Joliet , Illinois
It's quite possible that it wasn't completely latched. Sometimes I have to get down and look to see if the tab is locked in correctly.
Have you already tried to hook up and raise the vehicle again? If it stays unhook and try a couple more times.
Your coupler looks like it could use some grease or some type of corrosion protection on it.
bel73 is offline   Reply With Quote
Old 11-19-2023, 07:51 PM   #3
JJTX's Avatar
2018 19' Flying Cloud
South of Austin , Texas
I put my money on it wasnt latched completely.
Try it again, confirm by looking uunder it and getting a pin through the hole to lock it, and see if it does it again...
JJTX is offline   Reply With Quote
Old 11-19-2023, 09:52 PM   #4
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
There is a small spring at the top of the underside of the coupler. See if it needs to be lubricated or cleaned. Watch a you tube video on hitching and unhitching an airstream. Be sure the video is from the 2015 time frame. AS transitioned to a different coupler in 2019/2020.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 11-20-2023, 08:46 AM   #5
Mollysdad's Avatar
First, it sure looks like a lot of rust in the coupler.
Best to always keep it greased, I keep a tube of white lithium grease in the truck.
The bad news is your style of coupler, I call the Attwood, is no longer available. The new coupler design is by Demco. But it requires removing the old coupler and replacing the entire assembly to the A-frame. (Welding!)
Perhaps someone is selling a repair kit for the old Attwood, but I'm not aware.
Before I went to get the cutting torch, I'd make sure it really failed. If the clamp is not seated back enough, it can ride on top of the ball when hitching. Then the latch won't close, and it will come loose.
Try it again, try to align the ball slightly forward, so the coupler has to pull forward to drop on.
Old 11-20-2023, 06:13 PM   #6
1988 32' Excella
Robbinsville , New Jersey
Another way to check it is to latch the ball in the couple while not connected to TV and then try to wiggle the ball in the couple to see how much play there is.
Old 11-21-2023, 05:54 AM   #7
2019 30' International
Pennsylvania , Pennsylvania
I've seen both sides of the grease argument. Having worked around heavy equipment on occasion, I'm on the 'grease it' side of that debate.
First thing I'd do with that coupler is oil it up, down through the latch, up underneath, all around in there.....then I'd work it, and check the spring and latch from underneath to see what's going on in there.
I always grease the ball, and keep the coupler clean, inside and out.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 11-21-2023, 06:39 AM   #8
dznf0g's Avatar
Oswego , Illinois
I am too. I have a Propride, so the ball stays in the coupler 24/7 365. I drop it a couple times a year (every 7-10k, or so), hit the ball and coupler with BrakeClean, and regrease.
-Rich-
Old 11-25-2023, 11:08 AM   #9
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
At least you didn't do like this guy did ...
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 11-27-2023, 06:30 AM   #10
JJTX's Avatar
From the look of the gouges, it needs cleaned and greased way more often. I clean and grease every two weeks, three weeks.
Old 11-27-2023, 06:35 AM   #11
2022 20' Caravel
Southeastern , Pennsylvania
That coupler is a mess. I'd replace it or thoroughly clean it with a dremel or drill and wire brushes, then fully lubricate it. In the future, you need to keep it clean and lubricated.
RickBullotta is offline   Reply With Quote
new never used proven industries trailer coupler lock 2 5/16" Trailer Coupler Locks Model 2516 AS jackvosney Airstream Classifieds 2 08-17-2020 11:26 AM
Hitch ball came off while driving holmestk On The Road... 17 10-05-2009 07:33 AM
Replace ball coupler on 22ft Safari Killo1 General Repair Forum 1 04-24-2008 03:27 PM
couldn't get coupler off the ball qqq Hitches, Couplers & Balls 20 10-02-2003 02:00 PM
