03-05-2020, 09:04 AM
#141
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
August 2nd 2019 was it for me. Why did I wait so long? Love it. Sending this from Florida. AC is on in the AS!
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
03-05-2020, 09:15 AM
#142
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by rmkrum
PS: Down to 21 work days before retirement. My smile never leaves my face [emoji4]
Congratulations! I didn’t know there was an app for that!
I’ve already retired once, got dragged back to work, and now I can retire again any time I want to. Just stay busy, active, and keep learning new things.
An idle mind tends to go away quicker than you would expect.
I retired once also...now I'm tired 24/7.
No links, no chains, just marks for different loads.👍
03-06-2020, 06:18 AM
#143
2019 27' Globetrotter
McHenry
rmkrum, thanks! And yes, "there's an app for that"!
To your point about idle time, we talked to a financial advisor a few years ago and he asked what we wanted to do in retirement. Hadn't thought about that! My DW and I love photography and visiting National Parks - now we have the Airstream.
My only concern now is what will I do when I run out of projects to do to the trailer? I enjoy making improvements to the trailer so there's a small budget included in our new financial plan - keeps me from getting carried away! Installing a Victron 712 Battery Monitor this weekend...
Cheers!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
03-06-2020, 06:20 AM
#144
McHenry
GettinAway, I aspire to be like you! So glad you're doing well and enjoying retirement + the new Globetrotter.
2018 FC23FB
WBCCI# 10258
RETIRED!
03-08-2020, 12:15 PM
#145
Wildwood
, Missouri
Update. I tightened the weight distribution by one link. Never could find a really level place to get a pic. Definitely added a curve to the weight distribution bars. Did not change the level of the truck or the AS. Which is fine with me.
It did make quite a bit of difference on the ride in the Tundra. Much smoother ride, same on the sway.
Just came across the causeway into St Petersburg FL from the south. Had high wind warnings. No sway. I did slow down just in case. Strap is to kayak on the truck.
2020 25GT FBT
03-08-2020, 01:04 PM
#146
2020 27' Globetrotter
Fredericksburg
, VA
Attachment 362850
Sounds like you have it dialed in! Seat of the pants during high wind is a great way to confirm proper adjustment. Great job [emoji106]
03-12-2020, 07:01 AM
#147
Wildwood
, Missouri
On somewhat level ground. Finally took a pic. I don’t want to add more tension to the bars as I don’t want to raise the front of the trailer any more. Ride is smoother with less feel of tongue weight. Still little or no sway at all. Feels great.
2020 25GT FBT
03-12-2020, 09:05 AM
#148
2000 30' Excella
GTA
, Ontario
If you raise the rig with the tung jack, it allows you to put the chains at the correct links, I also put cable ties on the next link so I didn't have to count every time, then lower the jack and good to go. No sweat involved. I also do this in loading the bars too. But not every time
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2020 GMC Denali 1500 Duramax 3.0l Diesel, ProPride3 WDH.
previous tow vehicles 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement, 2005 Ford F150 Lariat 5.4L
03-12-2020, 09:15 AM
#149
2000 30' Excella
GTA
, Ontario
On somewhat level ground. Finally took a pic. I don’t want to add more tension to the bars as I don’t want to raise the front of the trailer any more. Ride is smoother with less feel of tongue weight. Still little or no sway at all. Feels great. Attachment 363116
GettinAway
I am on the mobile app so forgive me if you said this already.
Are you using BlueOx, and if so 1000lb bars, and if so how many links from the loose end before and after.
Thanks Ultra
03-13-2020, 09:07 AM
#150
Wildwood
, Missouri
Blue Ox SwayPro 1000 vs 1500 lbs spring bars
Yes. 1,000 lb bars. 8th from the loose end. 9th from the bars.
I was on 7 and 10. Had a bit more sag and rear bounce.
2020 25GT FBT
03-14-2020, 04:43 PM
#151
2000 30' Excella
GTA
, Ontario
03-15-2020, 06:48 AM
#152
Wildwood
, Missouri
Looking at the pic above, it looks like I can go one more link tighter? I’ll definitely have to find another way to ratchet the tension bolt open and closed. I already raise the tongue jack up quite a bit to hook up and unhook, but that little tool BO gives you still about breaks my wrist when I’m unhooking. I think I’ve got a long handled ratchet with a 1” socket up at the farm.
2020 25GT FBT
03-15-2020, 08:49 AM
#153
2019 22' Sport
High River
, Alberta
Try a half link - overlap 2 links on each chain and slip a 7/16 or ½ “ bolt in there. The nut only needs to be finger tight - seriously, it won’t come loose.
The thing I don’t like about your setup is the ball mount being so far back from the receiver. This offsets the long wheelbase of the truck.
03-15-2020, 09:15 AM
#154
McHenry
I picked up a 30” half-inch drive breaker bar and a 1” deep socket. Raising the jack does help a lot.
2018 FC23FB
WBCCI# 10258
RETIRED!
03-16-2020, 06:45 AM
#155
Wildwood
, Missouri
I think I follow the half link idea. I’ll try that.
The ball mount distance is set by the length of shaft of the BO hitch, correct? I’m not sure how I could change it..
Edit. This shaft on the BO is longer than what was on the EZ hitch I had before. I couldn’t open the tailgate on the Tundra before, and now I can. It it just this BO hitch I have, or all BO hitches?
2020 25GT FBT
03-17-2020, 06:13 AM
#156
2019 28' Flying Cloud
Dripping Springs
My BO hitch/ball looks the same. Personally I like the ball distance, allows me to open my tail gate. Also gives more clearance when doing tight turns, otherwise I'd likely rub the corner of my truck against the camper. I've experienced no adverse effects when towing.
03-17-2020, 07:15 AM
#157
2019 22' Sport
High River
, Alberta
You may not be able to change it because of the way the shank has been fabricated. I see a couple of substantial gussets in the photo. With an Eaz-Lift, someone with a drill press and a ⅝” drill can easily drill another hole in the shank to shorten things up. The ball mount I use is an old style welded unit, and the head is about a half inch from the back bumper of the car.
The ratio of rear overhang - axle centreline to pivot point - to tow vehicle wheelbase is more important than tow vehicle wheelbase by itself. Every inch that you can gain by moving the ball closer to the truck is like adding 2 to 3” to the truck’s wheelbase. You are reducing the leverage that the trailer has over the truck.
This doesn’t matter with a Hensley or ProPride because those hitches use a trapezoidal system to project the pivot point ahead, maybe even as far as the rear axle. This should result in straight line stability similar to that of a fifth wheel.
It’s a choice - convenience, or optimum stability and handling. Price is a factor too.
On edit - shortening the overhang also reduces the tension needed to achieve optimum weight distribution.
03-17-2020, 07:28 AM
#158
2018 27' Globetrotter
Apollo Beach
If it were my rig, I'd lower the ball height by one set of holes and crank more weight distribution in to level the truck more. I ran with the 11th link from the loose end of the chain in the slot and 1-1/2 links showing under the latches when hitched with my 25' Airstream and Blue Ox and never felt any sway, push-pull from passing vehicles. It handled like it was on rails and removed the heavy feel of the tongue weight from the truck. You need a long breaker bar and a 1" socket to crank the bars that hard and you need to raise the truck with the power jack fairly high to achieve the 11th link. I ran my 25' Airstream 40,000 miles on that setting with 1000# bars.
Also, do not drill a new hole to shorten the ball distance on a cast shank because it will crack. You must have a solid steel shank to make modifications (drill or cut) . The picture GettinAway posted has a cast shank.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
03-17-2020, 07:39 AM
#159
Wildwood
, Missouri
Ok. Got it now. Since it’s pulling very well. I think I’ll leave it alone as far as the distance of the ball to the truck.
Thx
2020 25GT FBT
03-17-2020, 07:48 AM
#160
Wildwood
, Missouri
Airmiles, what you are saying makes sense. I’ll look at lowering the ball by one hole. Still looking at lifting the trailer by 3” so it’ll need to be reset at that time. It’s funny on sway, there is zero push pull when an semi goes by me. (Either way). But when a car or minivan goes by me at 30+ mph difference, I feel that. Not much, but it rocks the truck. Could have something to do with the kayak too. When I went up a link on the chain to more tension, the heavy feel of the tongue weight.
I appreciate the feedback. It’s definitely a cast shank, and I won’t be drilling into it..
2020 25GT FBT
