Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 09-28-2020, 11:19 AM   #1
2022 25' Flying Cloud
Charlevoix , Michigan
Blue Ox bar weight advice
Newbies here, first post, need advice on Blue Ox Swaypro bars. We have a 2020 Ram 2500 CTD and are awaiting delivery on our 2021 Flying Cloud 25' FBT. After reading many related threads my question is given the actual tongue wt of around 1000# and having a 3/4 ton truck, do we go with 1000# or 1500# bars and why? Thanks in advance
Yardbird54E is offline   Reply With Quote
Old 09-28-2020, 11:25 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have 1000# bars and a Tundra which provides a smooth ride. Going with stiffer bars on a 3/4 ton ride would be too stiff, IMO. I would suggest 1000#
Richard
Old 09-28-2020, 11:32 AM   #3
Thanks, I'm going to talk to the Blue Ox folks soon and wanted a few opinions first
Old 09-28-2020, 12:12 PM   #4
Antsville , FUBAR
Welcome Aboard 👍
It's an informed guess without knowing actual TW...but I also would also start with 1k bars.
We have a 1200lb TW and move 720lb with 1k bars on our Hensley Arrow.
Old 09-29-2020, 10:46 AM   #5
2021 28' International
Knoxville , Tennessee
My dealer suggested 1000lb. bars for my 25ft. FC. No sway at all, crossing OK in a 40 mph wind.
Gibson3798 is offline   Reply With Quote
Old 09-29-2020, 11:06 AM   #6
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
I have had a Ram/Cummins 2500 and now have a Ram/Cummins 3500 for my AS 27 FB. I used and now use 1K Blue Ox Bars for both, and they worked and work fine. No problems --- altho I have eliminated the bar crank-up system and now use the strap method (Lippert Straptek), which I find to be a lot easier and safer.
Alta & Richard, Olympia, WA --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 09-29-2020, 11:08 AM   #7
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Yardbird54E, congratulations on your new Airstream! I have both 1000 and 1500# BlueOx bars for our 27’ Globetrotter and RAM 2500. I got the 1500# bars to try and shift more weight on our former tow vehicle.
I have towed with both on our RAM 2500 + GT and found the 1000# bars set to the 9th link from the loose end works just fine (3 1/2 links showing on the latch). Tongue weight on the Sherline scale is around 1100 lbs. loaded.
NOTE: I did have to get a longer drop shank to level the trailer when moving up to the RAM 2500. I got a Curt 2.5” from eTrailer since the 2500 uses a Class V hitch (no sleeve needed). I trimmed off the bottom part I didn’t need to shorten it up.
This setup has done a great job for us - no sway with passing semis or wind.
Good luck and happy camping!
ID:	379695   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 09-29-2020, 04:46 PM   #8
The Silver TARDIS
Kevinshortnh's Avatar
2018 30' Classic
Hillsboro , TX
We have a 2014 RAM 2500 Cummins and 2018 Classic 30.
We use the "Blue Ox BXW1506 1500 lb Hitch (Clamp-On Latches, 11 Hole Shank)" and it works great for us.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
Kevinshortnh is offline   Reply With Quote
Old 09-29-2020, 07:46 PM   #9
1993 21' Sovereign
2016 28' Flying Cloud
Bradenton , Florida
When I bought the 28’, the previous owner had 1000# bars. I replaced them with 1500# bars; the result was much improved weight distribution checked at the CAT scale. My tongue weight is 1200#. The rig does not bounce around now. There is a tight secure feeling.
KevinFH is offline   Reply With Quote
Old 09-29-2020, 08:41 PM   #10
VeloBuckeye's Avatar
2018 27' Flying Cloud
Easton , PA
1000 v. 1500 bars - experiment
I was also on the fence when I confirmed that my tongue weight was 1050 lbs, and not the 780 lbs Airstream advertises.
I had started with 1000 lb bars for my FC27, which I had from my previous rig. They worked fine using the 9th link from the end (3 full links showing).
I decided to try the 1500 lbs bars and found I use need one less link (8 links from end - 4 links showing) to get the same weight distribution. On the road, the heavier bars are clearly better for me.
My TV is a F150 diesel which I'm sure has something to do with my situation. I plan to move to a F250 next year and sense backing down to the 1000 lb bars will be better. We'll see...
VeloBuckeye
2018 Flying Cloud 27FB - "The Shoe"
VeloBuckeye is offline   Reply With Quote
Old 10-12-2020, 10:24 AM   #11
Teton22
2017 23' Flying Cloud
Jackson , Wyoming
I am also using a Blue Ox.
Ii bought my 23’ from folks w/a 2wheel drive truck. They had the hitch on the 4/6 holes. I drive a GMC Denali and had to have the service people drop the hitch down as low as they could..5/7 holes ..and the trailer still tilts back (too high at the hitch). When I spoke to the BO people they observed from my photos that I have 500# bars ( one dimple) and need to switch to a set of 1000# bars due to the hitch weight being 750#.
My question is this: Doesn’t the trailer need to be level in order to pull at optimum? And, if so, will the heavier sway bar level the trailer?
I started out thinking that I needed a hitch w/ 10 holes so I could lower the front end of the trailer but the BO rep didnt address that issue...only said I needed a heavier bar.
Any thoughts and opinions??
Teton 22 is offline   Reply With Quote
Old 10-12-2020, 10:54 AM   #12
2018 25' International
Slidell , Louisiana
No the heavier tension bars will not improve geometry to any significant degree. Yes, it should be level for several reasons. First to more evenly distribute weight to both axles. Also so that inertial forces are aligned with structural components and don't induce pitch moments including during braking, cornering, and accelerating. Suspension response is more correct and balanced as well.
Blue Ox makes a nine hole shank also but it sounds like even that is too high. The Blue Ox ball mount does fit the industry standard shank geometry so you don't have to use their shank. The 500# bars were a bit light so the upgrade is/was warranted.
Brian
Old 10-13-2020, 06:56 AM   #13
Thanks All
Thanks all for the good advice and well wishes. After consideration of said advice and talking to the Blue Ox rep on the phone I went with the 1000# bars. I upgraded the shank to the 9 hole, 2 1/2 inch to fit the class V receiver on the Ram, and was pleasantly surprised that the dreaded stamped metal wrench has been upgraded to a full socket breaker bar type wrench. Also just modified my garage door to 11ft high so I will have full indoor storage which comes in handy here in northern Michigan. Now just the wait for the Airstream...ETA December
DC Bus Bar Box - Question - Loose bar free in box JennyJakeNH Electrical - Systems, Generators, Batteries & Solar 1 07-16-2019 06:37 PM
Demco Excali-Bar tow bar Denis4x4 Airstream Classifieds 0 05-03-2015 02:39 PM
grey bar and red bar compound capt ken Cleaning, Stripping & Polishing 4 10-03-2013 12:17 AM
Seeking Advice on Spring Bar Weight Daystreamin Towing, Tow Vehicles & Hitches 6 03-10-2013 03:36 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 07:11 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
