Old 06-29-2023, 01:12 PM   #21
CRH
1995 25' Excella
xxxxx , xxxxxx
An inexpensive friction sway control will do with the OP wants.
CRH is offline   Reply With Quote
Old 06-29-2023, 03:46 PM   #22
aftermath's Avatar
Spokane , Washington
I agree. While not a fan of a friction bar "only" because I do believe that almost all setups need some WD, I will also agree that in this case, you simply don't need all the WD. I certainly would not suggest spending close to $1K when you don't need it. Get the bar and give it a try. I think you will be fine. There are MANY out there that use these safely.
aftermath is offline   Reply With Quote
Old 06-30-2023, 12:57 AM   #23
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
You might try these. https://www.amazon.com/Pro-83660-Val...8107921&sr=8-3
You'll need a hitch on the truck for the front of the friction bars to attach to. Here's one. I recommend having a friction bar on both sides of the trailer, that would be a different model https://www.etrailer.com/Trailer-Hit...URT/C45WR.html
It's amazing that every site and everyone jumps to some fancy "weight distribution" thingy when you say Friction Sway Control.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-30-2023, 02:07 PM   #24
JJTX's Avatar
2024 23' International
South of Austin , Texas
I would only say to be careful about using a tow vehicle that is too rigid. The Movement up/down, is a way of buffering the shock to the trailers frame. Using a tow vehicle that is ultra rigid can have some real bad affects on the trailer structure and contents. I think some of the models specifically state not to use certain heavy duty trucks for towing If my mind is remembering things right. This is mainly for someone thinking about using a 3500 dually to tow a 19 foot CB like mine. Bad idea.
I think your 23 has enough tongue weight to allow the rear of the 3500 to move enough to not beat up the AS. Which is the reason I wouldn't use any W/D hitches, so it has that weight to work the rear truck suspension.
I have seen trailer hitches that only have the arm that mounts to the trailer frame for sway control. I think curt has one.
JJTX is offline   Reply With Quote
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Equal-i-zer Sway Control Hitch vs Blue Ox Sway Pro airstreampek Hitches, Couplers & Balls 31 06-18-2014 10:56 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
